i have a plate rotating at a rpm of 500 - 600 rpm. Over this plate heated air is flowing. I am considering a dozen points over the surface of the plate . the air heated upto 100-120 degree celsius. One of my friend suggest to use Xbee with arduino to find the teperature readings.How can i use Xbee with arduino for the same. Also he said by changing the temperature sensor with pressure sensor , can get pressure also at different points.?
Is it possible to connect the temperature sensor with arduino without any amplification?. Here am using T type thermocuoples.
What will be specification for the arduino and xbee?.If amplification needed , what will be its specifications ?
rotational measurements
Re: rotational measurements
Please do not double post. Your questions have been addressed here: http://forums.adafruit.com/viewtopic.php?f=48&t=46493
