Power for Peltier Module + Heat sink
Our weekly LIVE video chat. Every Wednesday at 8pm ET!
bryceh
Post by bryceh »
Before I short-out or burn up my new 12V 5A Peltier module with 12V 5A heat sink, could you confirm that I can operate the entire assembly from the single 12V 5A switching power supply that I purchased (from Adafruit)? That is, do I (can I) join the power leads from the Peltier module and fan (and similarly their grounds) before attaching them to the transformer?
I watched the Adafruit Youtube video closely, but the connection to the power supply was always just out of view.
And one more question as long as I've already disturbed you: Is one power supply sufficient to run the heat sink *and* create 30ish deg C temp differential in the Peltier?
Thanks in advance,
Bryceh
Mankato MN
Re: Power for Peltier Module + Heat sink
You can connect this directly to the 12v/5A power supply. The temperature differential you are able to achieve will depend on how effectively you can insulate the cold side.
Return to “Ask an Engineer! VIDEO CHAT (closed)”
