Inverter voltage
Inverter voltage
I am interested in purchasing an electroluminescent panel but I don't need the inverter. Can I buy one without the inverter?? Thanks, Ross
- adafruit_support_bill
Re: Inverter voltage
Yes. We have them in Aqua, Blue and White: http://www.adafruit.com/products/625
I need one about 10X20 cm. Do you stock one this size?? If so, how can I order one. Thanks, Ross
We have 15x20 in Aqua. These can be cut down to 10x20 if needed. They come with a matching 12v inverter. http://www.adafruit.com/products/414
- Moe_99
For the EL tape, can you cut it into sections and solder together to use in different areas? Also, how could one go about bending it to shape a small curve?
Lastly, the EL Panel... it says it can be cut as long as the JST cable is attached... can you cut a hole in the center?
We have not had much luck solering connectors to EL tape. That is why we have our supplier attach connectors to both ends at the factory. You can cut it into two pieces. If you cut any more, we can't guarantee that you will be able to get the extra pieces to light up.
You can cut holes in the panel. As long as all the parts you want to light up are still connected to the part where the wire is attached.
- Moe_99
Thank you and I apologize for the double post... I thought this post may have been in the wrong area.
Thanks again for the info.
- Moe_99
Another question... (I messed up). Is there a contact email for the sales/shipping department at Adafruit?
I inadvertently ordered the wrong color panels (I ordered blue instead of aqua) and I need to change the order. I tried the tech support link on the website, but it wouldn't allow me to type in my username/info.
Any help would be appreciated!
If you contact [email protected] with a link to this thread and your order number, they may be able to catch it. Once they get pulled for shipping though it is too late to change.
- Moe_99
Thank you Bill,
The order was voided and I placed the new order this morning. I appreciate your help.
