am2315 for raspberry pi in python
Our weekly LIVE video chat. Every Wednesday at 8pm ET!
ydna
Re: am2315 for raspberry pi in python
Post by ydna »
I hooked it up to my Pi and i2cdetect didn't show it was connected. What should I do?
adafruit_support_rick
Post by adafruit_support_rick »
Good question. Mine is doing the same thing - I just got it yesterday, and this is the first chance I've had to play with it.
My sensor is working on Arduino, but it's not showing up on the Pi. At this point, I don't know what the problem is.
ydna
Post by ydna »
What are the pullup resitors for? I didn't use them for my arduino and it worked, perhaps the Pi needs them ? :?:
Vince8134
Post by Vince8134 »
Mine doesn't show up either among my i2c devices.
I connected 3.3 and 5V to the HV and LV of the i2c level shifter.
The SDA and SCLof the Pi on the A1 and A2. SDA and SCL of the sensor on the B1 and B2.
GND of the Pi on the GND of the left (A side), GND of the sensor on the GND of the right (B side).
But i2cdetect is missing it, whereas I got all my other i2c devices detected :(.
What can I do ?
ydna wrote:What are the pullup resitors for? I didn't use them for my arduino and it worked, perhaps the Pi needs them ?
Yours came with pullup resistors? Mine didn't come with any, but I tried it with pullups anyway - didn't help.
The Pi already has weak pullups on SDA and SCL. The Arduino has no pullups on those lines and it works, so the am2315 must already have internal pullups.
I'm stumped.
Post by adafruit »
The AM2315 is pretty weird, it doesn't use standard I2C command styles and it may not be true I2C. not sure it works with the Pi at all :(
Vince8134
Post by Vince8134 »
I've got the same as here :
http://forums.adafruit.com/viewtopic.php?f=19&t=42649
i.e: You have to issue i2cdetect twice to have it show up on the list of devices.
I got it detected now. Kind of strange.
Aha! Yes, that gets mine to show up as well.
The Arduino library essentially does the same thing - it issues all commands twice. I have my python code doing that, but it blows up on the first command because the am2315 doesn't respond to it.
I may have to hack the Adafruit_I2C library to do the double-bang thing, so that it doesn't throw an error.
NerdWorld
Post by NerdWorld »
Now that I can communicate with the AM2315, I'm having a little trouble understanding the control logic for the sensor. This is what I __think__ is needed, based on my decifering the arduino code. Could somebody please confirm this?
To read the humidity & temperature, you must:
1. Write 0x03 into register 00 (at SMB addddress 0x5c) to signify that a read is desired
2. Write 00 into register 01
3. Write 04 into register 02 (this tells the sensor to return 4 bytes of data)
4. Read register 00 (at SMB address 0x5c). If it does not match 0x03, then try again, since the data is not valid
5. Read register 01. It should be 04 to indicate 4 bytes returned. if not try again since the data is not valid
6. Read register 02 for Humidity high byte (unsigned integer)
7. Read register 03 for Humidity low byte
8. Read register 04 for Temperature high byte (signed interger)
9. Read register 05 for Temperature low byte
10. Divide temperature by 10 to get correct scale
Is this correct?
The docs for the AM2315 seem to show that register 0 & 1 are for humidity and 2 & 3 are for temperature. This seems to differ from what I think the arduino code is doing.
Could somebody confirm the logic for me? TIA!
The logic looks right. The Arduino code also does a divide by 10 on the humidity, I believe.
It also repeats steps 1, 2, and 3 before moving on to step 4.
NerdWorld
Post by NerdWorld »
My logic might be correct, but my code stinks <grin>.
Here's what I've tried to do to get data from the AM2315. I'm getting data, but it's not correct. Can you help me spot what I'm doing wrong?
(BTW, the forum is wrecking my indentation, so please assume standard Pyhton indents)
#!/usr/bin/python
# -*- coding: utf-8 -*-
# AM2315.py
#  A test program to debug getting data from a AM2315 Temperature/Humidity sensor on the Raspberry Pi
# Load needed python modules
import smbus	# Be able to read the SM Bus (i2c)  (apt-get install python-smbus)
import time	# Needed for sleep routine
BusNumber	= smbus.SMBus(1)
BusAddress	= 0x5c
TrialNumber = 0
MaxTrials 	= 3
while TrialNumber <= MaxTrials:
   try:
      # Start the measurement process by sending 0x03 to the device at register zero & asking for 4 bytes back
      BusNumber.write_i2c_block_data(BusAddress, 0, [0x03, 0, 4])
      # Allow for the measurement to be conducted by the sensor
      time.sleep(.15)
      # Now read the data
      SensorData = BusNumber.read_i2c_block_data(BusAddress, 0, 8)
      break
   except:
      TrialNumber = TrialNumber + 1
print SensorData
Humidity 		= float(SensorData[3]*256 + SensorData[3])/10
TemperatureC	= float(SensorData[5]*256 + SensorData[4])/10
TemperatureF 	= (TemperatureC * 1.8) + 32
print Humidity
print TemperatureF
Use the code tags (at the top of the edit pane) for posting code.
You're not indexing your data correctly:
Humidity       = float(SensorData[2]*256 + SensorData[3])/10
TemperatureC   = float(SensorData[4]*256 + SensorData[5])/10
NerdWorld
Post by NerdWorld »
Doh! You're correct about my indexes, but the data I'm getting back still isn't correct.
Here's the data I ALWAYS get.
[0, 5, 128, 115, 48, 0, 0, 0]
The first character should be 0x03
The second character should be 4
The last 2 should be a checksum.
I'm doing somethin' wrong somewhere. <sigh>
You're going to do four read attempts. Is that what you get on every attempt, or just what you get on the fourth attempt?
NerdWorld
Post by NerdWorld »
Every read attempt (that doesn't error out) yields the same 8 bytes.
I figure I am having one (or both) of these 2 problems;
1. I'm not initializing the AM2315 properly due to improper use of the i2c write command, so I'm gettng default data during the read operation
2. I'm not reading the registers properly due to improper use of the i2c read command, so I'm picking up some garbage data.
Return to “Ask an Engineer! VIDEO CHAT (closed)”
