AR1100 Android
AR1100 Android
Well here's my issue, I own the AR1100 touch screen controller, bought it about a month ago for an android car PC project. Got all the parts together and just assembled everything. For some reason the controller doesn't seem to work with my android TV stick however it does function properly with my PC and the configuration tool. Is there firmware update or something that can help make this work properly with my android device? Also if I have posted this in the wrong section I am sorry. Thank you in advance for any help anyone may have!
- adafruit_support_rick
Re: AR1100 Android
That would probably be something that needs to happen on the android side. The AR1100 just looks like a standard USB mouse - there's nothing OS-specific about it.
Re: AR1100 Android
Thanks for your quick response, already put in a ticket to Microchip. It's not compatible with any of my android devices so they are looking into it. When it's fix I'll post the fix up here for other users.
Re: AR1100 Android
I have bought the AR1100 module and have tested that it work in the linux. But my intention is to run with android OS on ICS onwards. But so far i did not manage to do so, any assistance is welcome.
- pman124
Re: AR1100 Android
Hey. My android phone works with a USB mouse via otg. Is it safe to assume that this should work with a liliput touchscreen? My android phone has both HDMI out and supports otg. I'm trying to use my phone as my head unit. It has everything I need for in car infotainment.
Re: AR1100 Android
Didn't work with my android stick or android x86. Android 4.4.2 has absolutely no idea how to properly use the device.
Re: AR1100 Android
jc7119 wrote:Didn't work with my android stick or android x86. Android 4.4.2 has absolutely no idea how to properly use the device.
did you use "getevent utility" and pushed to the android target idc file, which describe your touch device ?
Re: AR1100 Android
I too am tying to get the AR1100 to work with an android device. Any luck?
Re: AR1100 Android
No luck, ended up creating my own wire harness that switched the X and Y axis on my stock egalax touch controller. Sadly that wasn't the best solution as this would have been better, but I had no luck at all with this controller
Re: AR1100 Android
that's BANNED. I find it hard to believe that this doesn't work just like a usb mouse. Did the company that makes this ever get back to you? Thanks for the reply I found this product but its pricy. http://www.ebay.com/itm/Android-Touch-S ... 0941518009
Re: AR1100 Android
I actually contacted microchip directly and since that phone call the product description changed on there website to no longer include Android. Now this was 6 months ago and they could have updated the firmware since then
- damienlazareth
Re: AR1100 Android
Have anybody solved this problem?
I´ve bought this thing here and it doesent work like they tell... :(
I can see the device in /poc/bus/input/device and i can communicate over other apps...
But I have no MOUSE!
Re: AR1100 Android
As I've written in my topics exist solution to switch AR1100 from mouse to digitizer and back.
Of course, I've checked mouse and digitizer with android - result ok.
- zwanni
Re: AR1100 Android
I had the same problem and afer a lot of searching I found a solution in another forum.
- Download the AR Configuration software from microchip to your windows PC.
- Connect the AR1100 to your PC.
- Start the software and run the manual setup wizzard
- Choose: AR1100 USB Digitizer, 4-wire, 9-Point Calibration and follow the configuration steps. You can't calibrate in Digitizer mode. The wizzard automaticly switchs to Generic HID device for calibration, so thats the easiest way.
- Connect the AR1100 to your Android device. You have a working TouchScreen in stylus mode at this point (maybe after reboot).
- Download the attachment and extract the *.idc file. Put it in your adb directory on your PC "...\adt-bundle-windows-x86_64\sdk\platform-tools"
- Connect your Android device to your PC with debugging mode
- Enable write access on /system with ES-File Explorer or similar app
- Open command line on your pc and change directory to your adb path "...\adt-bundle-windows-x86_64\sdk\platform-tools"
- write "adb remount" (mostly necessary to get access on /system path)
- write "adb push Vendor_04d8_Product_0c03.idc /system/usr/idc" to transfer the file on your device
- write "adb reboot" to reboot your device
- after reboot you have a working touchscreen
- Attachments
- Vendor_04d8_Product_0c03.zip
- (393 Bytes) Downloaded 1744 times
- Slash88
Re: AR1100 Android
I bought this controller because I would like to controll my android device. But in mouse mode it doesn't work at all. The only way to have some effect is switch it on digitizer mode, but it is quite useless. Is there any other way to make it working?
