I am working a project using a low energy bluetooth and am not satisfied with the results. Looking to switch to your breakout module for small production and then ?? I use a serial 9600 baud signal and transmit up tp 16 ASCII characters from my micro-processor to a bluetooth ble 4.0 device (RADICOM) master to slave and back. If I change to your device I will need to reprogram the micro for I2C operation. The master unit is an iPhone 4S. If I reprogram I just send the ASCII data via I2C to your module and it sends it out bluetooth to the iPhone. What service characteristic does it use and what attribute protocol plus is verification required? Do you have a straight serial device in low energy 4.0 bluetooth.
Ray
nRF8001 bluetooth low energy
- adafruit_support_rick
Re: nRF8001 bluetooth low energy
It's a UART data link with an RX and TX characteristic.
We have a sample iOS app that demonstrates this:
https://itunes.apple.com/us/app/adafrui ... 25974?mt=8
The source is here:
https://github.com/adafruit/Bluefruit_LE_Connect
The source is here:
- RayMan6
Great. Thanks for the response. I clicked on the source link signed up but can't see where you can download the source.
Ray
Ray
There's a "Download as Zip" button on the right.
Hi !
I just receve my nRF8001 and finish the first tutorial but nothing happen !!!
Whene i start open the serial monitor i have this : Adafruit Bluefruit Low Energy nRF8001 Callback Echo demo
but no *advertising started ???
itry to search UART with my android and i can't see it !
could you help me ...
Thank's
Thank's
Please post clear, detailed pictures of both sides of the nRF8001, showing your soldering.
thanks for your response, I put some pictures to see you my soldering but i think it's correct ...
I wait your judgement and council
Have a good day
Romain
Have a good day
Romain
- IMG_5061.JPG (882.29 KiB) Viewed 1013 times
- IMG_5057.JPG (908.28 KiB) Viewed 1013 times
- IMG_5056.JPG (813.96 KiB) Viewed 1013 times
Do you have a voltmeter? See if you have 3.3v at the 3vo pin. Also, see what the voltage is at the RDY pin.
Next, try some different jumper wires, and try a different spot in the breadboard for the nRF8001
I watch it but without voltmeter i use a led and result is :
- i have power at the enter
- i have power at 3vo (lower)
- i have nothing o RDY
What did you think doctor ...
Could be defective. Please email [email protected] with a link to this thread for a replacement nRF8001
ok i do this but i'm realy sad ...
Hi, I am having the same issue.
I used a voltmeter and found I have 3.6 volts at my 3Vo pin and 4.15 on my rdy pin. I have checked that all of the bread board is functional and that none of my wires are faulty. I am using the downloadable examples given by the company and yet I am having the same issue where the device is not "advertising". Any help would be very much appreciated.
I recive my new board and now i have the right in out on the board but nothing change for the programe. on the serial monitor i have : Adafruit Bluefruit Low Energy nRF8001 Print echo demo. But nothing more, no * Advertising started, no * Connected, no * Disconnected or advertising timed out !!!!!!
What can i test for give u a way ?
My board is a leonardo, i'm on windows 7 an i use arduino 1.0.5.
thanks
thanks
@airsolid: How is the nRF8001 connected to the Leonardo? Can you post a picture showing all the connections?
@MaxOlsten: Please post clear, detailed pictures of both sides of the board, showing your soldering. Also, post a picture showing your connections to the Arduino
