Stepper Motor
Our weekly LIVE video chat. Every Wednesday at 8pm ET!
trujillo522
Stepper Motor
Post by trujillo522 »
I purchased a Neam 17, and an Arduino Motor shield V2. I am trying to used them on a project, and on change of direction the motor binds at times, all it does is vibrate, and gets hot. Removing the power for about a minute or so seems to free it up. I tried it with an original motor shield I had laying around, but it does the same thing.
#include <AFMotor.h> //<callout id="code.curtainautomation.includes"/>
//START:defines
  #define LIGHT_PIN         0  //<callout id="code.curtainautomation.defines"/>
  #define LIGHT_THRESHOLD 800
  #define TEMP_PIN          5
  #define TEMP_THRESHOLD   72
  #define TEMP_VOLTAGE    5.0
  #define ONBOARD_LED      13
//END:defines
//START:variables
int curtain_state  = 1; // <callout id="code.curtainautomation.variables"/>
int light_status   = 0;
double temp_status = 0;
boolean daylight   = true;
boolean warm       = false;
AF_Stepper motor(100, 2);
//END: variables
//START:setup
void setup() { //<callout id="code.curtainautomation.setup"/>
  Serial.begin(9600);
  Serial.println("Setting up Curtain Automation...");
  // Set stepper motor rotation speed to 100 RPMs
  motor.setSpeed(100);
  // Initialize motor
  // motor.step(100, FORWARD, SINGLE);
  // motor.release();
  delay(1000);
//END:setup
//START:curtain
void Curtain(boolean curtain_state) {   //<callout id="code.curtainautomation.curtain"/>
  digitalWrite(ONBOARD_LED, curtain_state ? HIGH : LOW);
  if (curtain_state) {
    Serial.println("Opening curtain...");
    // Try SINGLE, DOUBLE, INTERLEAVE or MICROSTOP
    motor.step(800, FORWARD, SINGLE);
  } else {
    Serial.println("Closing curtain...");
    motor.step(800, BACKWARD, SINGLE);
//END:curtain
//START:main_loop
void loop() {  //<callout id="code.curtainautomation.mainloop"/>
  // poll photocell value
  light_status = analogRead(LIGHT_PIN);
  delay(500);
  // print light_status value to the serial port
  Serial.print("Photocell value = ");
  Serial.println(light_status);
  Serial.println("");
  // poll temperature
  int temp_reading = analogRead(TEMP_PIN);
  delay(500);
  // convert voltage to temp in Celsius and Fahrenheit
  float voltage = temp_reading * TEMP_VOLTAGE / 1024.0;
  float temp_Celsius = (voltage - 0.5) * 100 ;
  float temp_Fahrenheit = (temp_Celsius * 9 / 5) + 32;
  // print temp_status value to the serial port
  Serial.print("Temperature value (Celsius) = ");
  Serial.println(temp_Celsius);
  Serial.print("Temperature value (Fahrenheit) = ");
  Serial.println(temp_Fahrenheit);
  Serial.println("");
  if (light_status > LIGHT_THRESHOLD)
      daylight = true;
  else
      daylight = false;
  if (temp_Fahrenheit > TEMP_THRESHOLD)
      warm = true;
  else
      warm = false;
  switch (curtain_state)
  case 0:
      if (daylight && !warm)
      // open curtain
        curtain_state = 1;
        Curtain(curtain_state);
      break;
  case 1:
      if (!daylight || warm)
      // close curtain
        curtain_state = 0;
      break;
//END:main_loop
This is the sketch I am using, also if I use the "motor.release();" command the motor does not spin free as it does with power off
Last edited by adafruit_support_bill on Sat Jun 07, 2014 6:13 am, edited 1 time in total.
Reason: please use the </> button when submitting code. press </>, then paste your code between the [code] [/code] tags.
Franklin97355
Re: Stepper Motor
Post by Franklin97355 »
Try editing your post and enclosing your code with
 tags to make it readable.
Re: Stepper Motor
What are you using to power the motor?
Does the motor work with the stepperTest example in the library?
Try changing the step mode from Single to Double.
Return to “Ask an Engineer! VIDEO CHAT (closed)”
