BEST RECHARGEABLE BATERY
Our weekly LIVE video chat. Every Wednesday at 8pm ET!
asantanilla
Post by asantanilla »
Hello!
I am looking to power a light using a solar panel and rechargeable battery. i am looking for the most efficient way to do this! I need to know more about what kind of solar panel to use and as well what are the best batteries in the market that last long and are efficient.
If you have any advice it would be great! even references to articles or other things.
THANKS!
Re: BEST RECHARGEABLE BATERY
What kind of light and how long does it need to run?
LiPo batteries are some of the most efficient ones out there. And you will need an efficient charger to go with them. This guide discusses some of the design decisions behind an efficient solar charger: https://learn.adafruit.com/usb-dc-and-s ... sign-notes
asantanilla
Hello I need to power around 6 LED Sequins 3.3V. I need to run it only for a couple of hours by turning it on and of every now and then. As well i want to try to be efficient and use a solar panel to recharge it, do you recommend this? THANKS FOR YOUR HELP AND YOUR QUICK RESPONSE !!
6 sequins needs about 120mA max. A 500mAh LiPo like this: https://www.adafruit.com/products/1578
will give you 3-4 hours on a full charge.
For solar charging, you would need a solar charger: https://www.adafruit.com/products/390
And a solar panel. If this is a wearable project, something like this flexible solar panel might be good: https://www.adafruit.com/products/1485
You would need about 1 hour of full sunlight to re-charge after each hour of use.
asantanilla
Thank you! your help has been very helpful really and i have learned a lot of things! i wanted to ask you one last thing i am looking for something more efficient less charging time more battery time something like less time in the sun more power. is this as much as i can get? thanks
There are solar panels which can charge much faster. This one will charge your battery in 1/5 the time of the flexible panel.
https://www.adafruit.com/products/1525
Return to “Ask an Engineer! VIDEO CHAT (closed)”
