Hi
I was wondering how I could get FONA work with FLORA.
I now have
FONA FLORA
Vio 3.3V
Rx Rx
Tx Tx
Key GND
Rst D6
GND GND
and running sample code from example, and change the line to match pin number on Flora
#define FONA_RST 6
but when I open up serial port window, message says
Couldn't find FONA
I tried power cycle on both board and reset button on Flora, but those did not change anything.
Note, Flora is powered by USB cable and FONA is powered by 3xAAA battery pack
Not sure what I am doing wrong.
FONA work with Flora
- Franklin97355
Re: FONA work with Flora
If you are trying to communicate on these you need Rx - Tx and Tx - RX also make sure you have a ground connected between all your devices.Rx Rx
Tx Tx
Hi
I swapped Tx Rx connection, still got Couldnt find FONA message.
- Franklin97355
OK then please post clear, large pictures of your boards, both sides and the code you are runningusing the code button as shown below.
Here is the sample code I am using, and I changed FONA_RST from 4 to 6 cause I am connecting RST to D6
#include <SoftwareSerial.h>
#include "Adafruit_FONA.h"
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 6
// this is a large buffer for replies
char replybuffer[255];
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
Adafruit_FONA fona = Adafruit_FONA(&fonaSS, FONA_RST);
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
Serial.begin(115200);
Serial.println(F("FONA basic test"));
Serial.println(F("Initializing....(May take 3 seconds)"));
// See if the FONA is responding
if (! fona.begin(4800)) { // make it slow so its easy to read!
Serial.println(F("Couldn't find FONA"));
while (1);
Serial.println(F("FONA is OK"));
printMenu();
void printMenu(void) {
Serial.println(F("-------------------------------------"));
Serial.println(F("[?] Print this menu"));
Serial.println(F("[a] read the ADC (2.8V max)"));
Serial.println(F("[b] read the Battery V"));
Serial.println(F("[C] read the SIM CCID"));
Serial.println(F("[U] Unlock SIM with PIN code"));
Serial.println(F("[i] read RSSI"));
Serial.println(F("[n] get Network status"));
Serial.println(F("[v] set audio Volume"));
Serial.println(F("[V] get Volume"));
Serial.println(F("[H] set Headphone audio"));
Serial.println(F("[e] set External audio"));
Serial.println(F("[T] play audio Tone"));
Serial.println(F("[f] tune FM radio"));
Serial.println(F("[F] turn off FM"));
Serial.println(F("[m] set FM volume"));
Serial.println(F("[M] get FM volume"));
Serial.println(F("[q] get FM station signal level"));
Serial.println(F("[P] PWM/Buzzer out"));
Serial.println(F("[c] make phone Call"));
Serial.println(F("[h] Hang up phone"));
Serial.println(F("[N] Number of SMSs"));
Serial.println(F("[r] Read SMS #"));
Serial.println(F("[R] Read All SMS"));
Serial.println(F("[d] Delete SMS #"));
Serial.println(F("[s] Send SMS"));
Serial.println(F("[S] create Serial passthru tunnel"));
Serial.println(F(""));
Serial.print(F("FONA> "));
while (! Serial.available() );
char command = Serial.read();
Serial.println(command);
switch (command) {
case '?': {
printMenu();
break;
case 'a': {
// read the ADC
uint16_t adc;
if (! fona.getADCVoltage(&adc)) {
Serial.println(F("Failed to read ADC"));
} else {
Serial.print(F("ADC = ")); Serial.print(adc); Serial.println(F(" mV"));
break;
case 'b': {
// read the battery voltage
uint16_t vbat;
if (! fona.getBattVoltage(&vbat)) {
Serial.println(F("Failed to read Batt"));
} else {
Serial.print(F("VBat = ")); Serial.print(vbat); Serial.println(F(" mV"));
break;
case 'U': {
// Unlock the SIM with a PIN code
char PIN[5];
flushSerial();
Serial.println(F("Enter 4-digit PIN"));
readline(PIN, 3);
Serial.println(PIN);
Serial.print(F("Unlocking SIM card: "));
if (! fona.unlockSIM(PIN)) {
Serial.println(F("Failed"));
} else {
Serial.println(F("OK!"));
break;
case 'C': {
// read the CCID
fona.getSIMCCID(replybuffer); // make sure replybuffer is at least 21 bytes!
Serial.print(F("SIM CCID = ")); Serial.println(replybuffer);
break;
case 'i': {
// read the RSSI
uint8_t n = fona.getRSSI();
int8_t r;
Serial.print(F("RSSI = ")); Serial.print(n); Serial.print(": ");
if (n == 0) r = -115;
if (n == 1) r = -111;
if (n == 31) r = -52;
if ((n >= 2) && (n <= 30)) {
r = map(n, 2, 30, -110, -54);
Serial.print(r); Serial.println(F(" dBm"));
break;
case 'n': {
// read the network/cellular status
uint8_t n = fona.getNetworkStatus();
Serial.print(F("Network status "));
Serial.print(n);
Serial.print(F(": "));
if (n == 0) Serial.println(F("Not registered"));
if (n == 1) Serial.println(F("Registered (home)"));
if (n == 2) Serial.println(F("Not registered (searching)"));
if (n == 3) Serial.println(F("Denied"));
if (n == 4) Serial.println(F("Unknown"));
if (n == 5) Serial.println(F("Registered roaming"));
break;
/*** Audio ***/
case 'v': {
// set volume
flushSerial();
Serial.print(F("Set Vol %"));
uint8_t vol = readnumber();
Serial.println();
if (! fona.setVolume(vol)) {
} else {
break;
case 'V': {
uint8_t v = fona.getVolume();
Serial.print(v); Serial.println("%");
break;
case 'H': {
// Set Headphone output
if (! fona.setAudio(FONA_HEADSETAUDIO)) {
} else {
fona.setMicVolume(FONA_HEADSETAUDIO, 15);
break;
case 'e': {
// Set External output
if (! fona.setAudio(FONA_EXTAUDIO)) {
} else {
fona.setMicVolume(FONA_EXTAUDIO, 10);
break;
case 'T': {
// play tone
flushSerial();
Serial.print(F("Play tone #"));
uint8_t kittone = readnumber();
Serial.println();
// play for 1 second (1000 ms)
if (! fona.playToolkitTone(kittone, 1000)) {
} else {
break;
/*** FM Radio ***/
case 'f': {
// get freq
flushSerial();
Serial.print(F("FM Freq (eg 1011 == 101.1 MHz): "));
uint16_t station = readnumber();
Serial.println();
// FM radio ON using headset
if (fona.FMradio(true, FONA_HEADSETAUDIO)) {
Serial.println(F("Opened"));
if (! fona.tuneFMradio(station)) {
} else {
Serial.println(F("Tuned"));
break;
case 'F': {
// FM radio off
if (! fona.FMradio(false)) {
} else {
break;
case 'm': {
// Set FM volume.
flushSerial();
Serial.print(F("Set FM Vol [0-6]:"));
Serial.println();
if (!fona.setFMVolume(vol)) {
} else {
break;
case 'M': {
// Get FM volume.
uint8_t fmvol = fona.getFMVolume();
if (fmvol < 0) {
} else {
Serial.print(F("FM volume: "));
Serial.println(fmvol, DEC);
break;
case 'q': {
// Get FM station signal level (in decibels).
flushSerial();
Serial.println();
int8_t level = fona.getFMSignalLevel(station);
if (level < 0) {
Serial.println(F("Failed! Make sure FM radio is on (tuned to station)."));
} else {
Serial.print(F("Signal level (dB): "));
Serial.println(level, DEC);
break;
/*** PWM ***/
case 'P': {
// PWM Buzzer output @ 2KHz max
flushSerial();
Serial.print(F("PWM Freq, 0 = Off, (1-2000): "));
uint16_t freq= readnumber();
Serial.println();
if (! fona.PWM(freq)) {
} else {
break;
/*** Call ***/
case 'c': {
// call a phone!
char number[30];
flushSerial();
Serial.print(F("Call #"));
readline(number, 30);
Serial.println();
Serial.print(F("Calling ")); Serial.println(number);
if (!fona.callPhone(number)) {
} else {
Serial.println(F("Sent!"));
break;
case 'h': {
// hang up!
if (! fona.hangUp()) {
} else {
break;
/*** SMS ***/
case 'N': {
// read the number of SMS's!
int8_t smsnum = fona.getNumSMS();
if (smsnum < 0) {
Serial.println(F("Could not read # SMS"));
} else {
Serial.print(smsnum);
Serial.println(F(" SMS's on SIM card!"));
break;
case 'r': {
// read an SMS
flushSerial();
Serial.print(F("Read #"));
uint8_t smsn = readnumber();
Serial.print(F("\n\rReading SMS #")); Serial.println(smsn);
uint8_t len = fona.readSMS(smsn, replybuffer, 250); // pass in buffer and max len!
Serial.print(F("***** SMS #")); Serial.print(smsn);
Serial.print(" ("); Serial.print(len); Serial.println(F(") bytes *****"));
Serial.println(F("*****"));
break;
case 'R': {
// read all SMS
for (int8_t smsn=1; smsn<=smsnum; smsn++) {
// if the length is zero, its a special case where the index number is higher
// so increase the max we'll look at!
if (len == 0) {
Serial.println(F("[empty slot]"));
smsnum++;
continue;
break;
case 'd': {
// delete an SMS
flushSerial();
Serial.print(F("Delete #"));
Serial.print(F("\n\rDeleting SMS #")); Serial.println(smsn);
if (fona.deleteSMS(smsn)) {
} else {
Serial.println(F("Couldn't delete"));
break;
case 's': {
// send an SMS!
char sendto[21], message[141];
flushSerial();
Serial.print(F("Send to #"));
readline(sendto, 20);
Serial.println(sendto);
Serial.print(F("Type out one-line message (140 char): "));
readline(message, 140);
Serial.println(message);
if (!fona.sendSMS(sendto, message)) {
} else {
break;
case 'S': {
Serial.println(F("Creating SERIAL TUBE"));
while (1) {
if (Serial.available()) {
fonaSS.write(Serial.read());
delay(1); // add a delay required for some reason?
if (fonaSS.available()) {
Serial.write(fonaSS.read());
break;
default: {
Serial.println(F("Unknown command"));
printMenu();
break;
// flush input
flushSerial();
while (fonaSS.available()) {
void flushSerial() {
while (Serial.available())
Serial.read();
char readBlocking() {
while (!Serial.available());
return Serial.read();
uint16_t readnumber() {
uint16_t x = 0;
char c;
while (! isdigit(c = readBlocking())) {
//Serial.print(c);
Serial.print(c);
x = c - '0';
while (isdigit(c = readBlocking())) {
Serial.print(c);
x *= 10;
x += c - '0';
return x;
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout) {
uint16_t buffidx = 0;
boolean timeoutvalid = true;
if (timeout == 0) timeoutvalid = false;
while (true) {
if (buffidx > maxbuff) {
//Serial.println(F("SPACE"));
break;
while(Serial.available()) {
char c = Serial.read();
//Serial.print(c, HEX); Serial.print("#"); Serial.println(c);
if (c == '\r') continue;
if (c == 0xA) {
if (buffidx == 0) // the first 0x0A is ignored
continue;
timeout = 0; // the second 0x0A is the end of the line
break;
buff[buffidx] = c;
buffidx++;
if (timeoutvalid && timeout == 0) {
//Serial.println(F("TIMEOUT"));
break;
delay(1);
buff[buffidx] = 0; // null term
return buffidx;
Another note
I also used Arduino mega to connect FONA as well.
still got couldnt find FONA message. and I have got two FONA boards, swapped them and same results.
- adelineyiqi
Vio needs to be connected to the same level as controller digital high, i.e. 5V when you are using USB to power Flora. I had this problem at the beginning as well.
Good luck!
Adeline
Good luck!
Adeline
