PiGrrl + Retropie/Emulationstation
Our weekly LIVE video chat. Every Wednesday at 8pm ET!
b1tsentry
Post by b1tsentry »
Hello engineers.. sorry if this question has been asked already but I have a huge interest in the PiGrrl project and plan on building one. I really reeally wanna try to make this to work with Retropie and emulation station so I can run other emulators and have a slick interface. Is this possible with the current hardware design of PiGrrl and is Adafruit planning on making any Retropie images that might support it? Or maybe a tutorial on how to make the necessary config changes ourselves?
pburgess
Re: PiGrrl + Retropie/Emulationstation
Post by pburgess »
EDIT: oops, I'm sorry, my response below specifically refers to the GPIO-to-keyboard-input software part. I actually have no idea whether Retropie is compatible the PiGrrl, and would be somewhat skeptical of it working, actually. A lot of emulators favor OpenGL for graphics, which isn't compatible with the PiTFT display. So I'd file this under "possible but not likely."
Apparently it can work with Retropie 1.9 but not 2.0. This has to do with the 'retrogame' program that converts GPIO button inputs into simulated keyboard presses. Currently being discussed on Github.
If you'd like to be a guinea pig, I think I have a fix to make it work with Retropie 2.0.
Chrom3Dome
Post by Chrom3Dome »
I volunteer myself as tribute!
wolpak
Post by wolpak »
I'd be interested in volunteering also if possible.
dj505Gaming
Post by dj505Gaming »
A picture of the RetroPie menu (you can see the Sega Genesis to the side)
2015-02-02 15.png (249.9 KiB) Viewed 4829 times
Hello there! I see this is an old post and information posted now may not help, but I figured out how to run RetroPie on my PiGrrl! When I figure out how to run FBCP on the Pi's startup, I can post a writeable .img you can download and write to your Pi like a normal OS. The rc.local method of running programs on startup doesn't seem to be working, and neither does the .bashrc one because I have to actually end emulationstation with f4 and login without any display on the screen, any idea how I can get it to work? All i need to do is run a script on startup such as
fbcp &
before Emulationstation begins. That way, the output from HDMI is capured on the Adafruit 2.8 inch TFT. It lags quite a bit and the controls aren't working because there's no set input to configure the controls because retrogame doesn't seem to be compatible with FBCP and I don't know how to fix any of those problems, but it's funcional.
EDIT: I suppose the CupCade system uses fbcp AND retrogame for controls, so I might build the image off CupCade if I can figure it out.
If you want to make this work yourself, instead of waiting for me to link you to a finished, ready to go,image, then I'll give you some instructions below.
First, you have to burn RetroPie to your SD card. I'm sure you know how to do that, so I'll move on.
SSH to your Pi with putty (Windows) or your terminal (Mac). If you can't find the IP, hook up your Pi to the HDMI, exit Emulationstation and it should say beside the ASCII mushroom with a ton of stats beside it.
Next, you have to install the dirvers for your screen. If you're using the 2.8 inch TFT, this will work. If you're using the 3.5 inch one, I'm not completely sure it will, but you can try it. Press F4 to exit Emulationstation and type this next series of commands to download the driver:
cd ~
wget http://adafruit-download.s3.amazonaws.com/libraspberrypi-bin-adafruit.deb
wget http://adafruit-download.s3.amazonaws.com/libraspberrypi-dev-adafruit.deb
wget http://adafruit-download.s3.amazonaws.com/libraspberrypi-doc-adafruit.deb
wget http://adafruit-download.s3.amazonaws.com/libraspberrypi0-adafruit.deb
wget http://adafruit-download.s3.amazonaws.com/raspberrypi-bootloader-adafruit-20140917-1.deb
You should have all the files downloaded. Then run
sudo dpkg -i -B *.deb
to install your kernel. It may take a few minutes.
After it finishes, shut down your pi if the screen isn't on, shut down your pi with "sudo shutdown -h now", put the screen on, and tun it on again. If you happen to have the screen attatched already, just "sudo reboot".
Then enable the dirvers with:
sudo modprobe spi-bcm2708
sudo modprobe fbtft_device name=adafruitts rotate=270
export FRAMEBUFFER=/dev/fb1
If it works, the screen should now be black instead of white.
After that, do:
sudo nano /etc/modules
and add "spi-bcm2708" and "fbtft_device" without the "" under what's already there.
Now do
sudo nano /etc/modprobe.d/adafruit.conf
and paste in
options fbtft_device name=adafruitts rotate=270 frequency=32000000
Then you need to install fbcp by Tasanakor on GitHub.
Enter these in order.
sudo apt-get install cmake
git clone https://github.com/tasanakorn/rpi-fbcp
cd rpi-fbcp/
mkdir build
cd build/
cmake ..
make
sudo install fbcp /usr/local/bin/fbcp
fbcp should be installed. Just run
fbcp &
and you should see everything that's on HDMI on your piTFT. Then all you need to do is figure out how to run fbcp when you turn on your pi automatically, make retrogame (a program that converts GPIO signals to keypresses like CupCade does automatically) work, and you should be set.
If you need any help, message me! Hope this helped anyone following this tutorial!
spelexander
Post by spelexander »
Hey great tutorial, just wondering, in another thread you posted that you found the FBCP .man file with the copy rate. Would you be able to post the exact location of this file and directory.
Also did decreasing the value (25 * 1000) make any significant difference to performance? Because you would think lowering the time between each frame copy would increase fps.
Thanks in advance :)
dj505Gaming
The fbcp.main file was located in the downloaded rpi-fbcp file, so the directory would be <whereever you downloaded fbcp from github>/rpi-fbcp/main.c. Changing the values didn't make much difference for me, but I was able to slow it down instead of speed it up. Might make a difference for you tho! Good luck!
Edit: after editing main.c you'll have to rebuild and reinstall fbcp. Example:
Sudo nano rpi-fbcp/main.c
Cd build
Cmake ..
Make
Sudo install fbcp /usr/local/bin/fbcp
spelexander
Thanks for the reply, however still no luck finding the file unfortunately, i tried what you said and entered the command:
sudo nano https://github.com/tasanakorn/rpi-fbcp/main.c
however it just creates a new file. Is there anything you can see that i might be doing wrong?
dj505Gaming
What you did is you tried to edit the file through the URL to download the file. What you have to do is go "git clone http://github.com/tasanakorn/rpi-fbcp" and then do sudo nano rpi-fbcp/main.c
Your problem was you didn't have fbcp downloaded in the first place, you were trying to edit a nonexistent file through a web address :P good luck getting your PI working!
spelexander
Oh no! i do have the file downloaded and installed as i can run fbcp fine using fbcp & (although i can't get auto load to work), however i just can't locate the main.c file :(. I can't locate it with this command either:
sudo nano /rpi-fbcp/main.c
was that the specific command you used to edit it? Its unfortunate i don't have ssh or something else set up where i can look for the file more easily. Thanks for the help!
dj505Gaming
<accidental duplicate post>
dj505Gaming
<accidental duplicate post again (my phone was having issues)>
dj505Gaming
If you type "ls" or "dir" in the command line it lists all the files in the directory. Just do that until you find the file! Should work :)
bluenazgul
Post by bluenazgul »
fbcp &
cd ~
After that, do:
Now do
and paste in
cd rpi-fbcp/
mkdir build
cd build/
cmake ..
make
fbcp &
@dj505Gaming If you have an writeable image for RetroPi one the PiGRRL it would be perfect, i just received all my Adafruit Components today and plan to use the Adafurit Hardware Part and Guide complete but use RetroPi on it coz i think its the better Software
albill
Post by albill »
I followed this (and other posts here) and got emulation station working with my Pi 2 and a 3.5" PiTFT screen.
To get ES to launch on start, I did:
sudo nano /etc/inittab
and in inittab, I made sure I had:
#1:2345:respawn:/sbin/getty --noclear 38400 tty1
1:2345:respawn:/bin/login -f pi tty1 </dev/tty1 >/dev/tty1 2>&1
so the 'pi' account logged in on start.
I then did:
sudo nano /etc/rc.local
and put:
/usr/local/bin/fbcp &
before 'exit 0' at the end.
Since I added retrogame (I have a cupcade controller), I added:
/usr/local/bin/retrogame &
to make it:
exit 0
Now ES starts up and shows on my display when I start and I was able to configure my analog joystick and buttons on the cupcade in ES
Return to “Ask an Engineer! VIDEO CHAT (closed)”
