Stepper Motor Mount with Hardware - NEMA-17 Sized
- brightmoonyu
I need a step motor bracket to mounting the motor onto the plate of linear stage. But I hope to make sure whether this product can meet my need.
Re: Stepper Motor Mount with Hardware - NEMA-17 Sized
It is a very sturdy steel right-angle NEMA-17 mount. Without knowing anything about your linear stage design, I can't really comment on whether it will fit.
- brightmoonyu
Yes, the dimensions information of the step motor and linear stage has been attached. Thanks a lot for your help.
- Step Motor.png (68.18 KiB) Viewed 1012 times
- Linear Stage.png (189.45 KiB) Viewed 1012 times
- brightmoonyu
For the two 30mm long 30 mm apart slots, when I attach this to the linear stage, can the screws fix this part onto the linear stage firmly? Since it is a slot not a hole, will it slide ?
The M3 hole spacing should match. And 4 screws should hold it tight. The slots are to allow for adjustment of the drivetrain alignment. In operation, most of the forces acting on the bracket will be at right angles to the slots.
- brightmoonyu
Ok, thanks a lot. What kind of screw do I need for the mounting between step motor and this bracket? Could you please offer that to me?
The bracket comes with mounting hardware:
https://www.adafruit.com/product/1297
Comes with one mount and a bag of hardware for attachment:
4 x 34mm long M4 Pan head
4 x M4 washer + lock (spring) washer + hexnut
4 x 9mm long M4 Pan head
4 x 8mm long M3 Pan head
4 x M3 washer and lock (spring) washer
- brightmoonyu
Ok, thanks a lot. How long it will take for this item to be shipped to 90007, Los Angeles, CA, USA
There should be several shipping options available to you at checkout - including 'next-day' shipping if you need it quickly.
