ble enabled trinket, single AA powered trinket
- glennalgie
Can you discuss and illustrate how one can add BLE to a trinket? This leads to a question: will adafruit soon offer an integrated bletrinket, I will take a dozen to start??? Also what is minimum add on hardware config to power trinket from single AA battery?
- adafruit_support_rick
Re: ble enabled trinket, single AA powered trinket
The trinket does not have enough memory space for the BLE library.
You can't power a trinket from a single AA.
- glennalgie
adafruit_support_rick wrote:The trinket does not have enough memory space for the BLE library.
Bummer, its a big opportunity to differentiate. My program and business case fits nicely in trinket dont need a full duino overhead.
Thats not the answer i was looking for. I recall the adafruit founder was famous for a stepup voltage regulator design.
- Franklin97355
That does not negate the fact that you can't run a Trinket from a 1.5v source. If you want to add a stepup circuit you can run a Trinket from a stepup device powered by a 1.5v source though.I recall the adafruit founder was famous for a stepup voltage regulator design.
