DC motor does not work
Our weekly LIVE video chat. Every Wednesday at 8pm ET!
sazmi
Post by sazmi »
This is a test sketch for the Adafruit assembled Motor Shield for Arduino v2
It won't work with v1.x motor shields! Only for the v2's with built in PWM
control
For use with the Adafruit Motor Shield v2
---->	http://www.adafruit.com/products/1438
#include <Wire.h>
#include "utility/Adafruit_PWMServoDriver.h"
// Create the motor shield object with the default I2C address
// Or, create it with a different I2C address (say for stacking)
// Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x61);
// Select which 'port' M1, M2, M3 or M4. In this case, M1
Adafruit_DCMotor *myMotor = AFMS.getMotor(1);
// You can also make another motor on port M2
//Adafruit_DCMotor *myOtherMotor = AFMS.getMotor(2);
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Adafruit Motorshield v2 - DC Motor test!");
  AFMS.begin();  // create with the default frequency 1.6KHz
  //AFMS.begin(1000);  // OR with a different frequency, say 1KHz
  // Set the speed to start, from 0 (off) to 255 (max speed)
  myMotor->setSpeed(150);
  myMotor->run(FORWARD);
  // turn on motor
//  myMotor->run(RELEASE);
  uint8_t i;
  Serial.print("tick");
  myMotor->setSpeed(200);
  // turn on motor
  delay(1000);
This code does not make the DC motor run on adafruit motor shield but the DC motor works independently.
Need suggestions.
Last edited by Franklin97355 on Thu Jan 22, 2015 12:49 pm, edited 1 time in total.
Reason: Added missing [code] tags
adafruit_support_rick
Re: DC motor does not work
You haven't soldered any of the header pins on the shield. The pins won't make an electrical connection without solder.
https://learn.adafruit.com/adafruit-gui ... ring/tools
Return to “Ask an Engineer! VIDEO CHAT (closed)”
