The product description says that it can be used as either a "normally open" or "normally closed" switch. By any chance can it be used as both simultaneously? I have an application where I need to close one solenoid and open another when the foot switch is pressed. When I release the switch the reverse should happen. Basically I want to use the foot switch to determine which of the two solenoids is engaged.
Thanks,
Question about Foot Switch (PRODUCT ID: 423)
- daveharper
- adafruit_support_bill
Re: Question about Foot Switch (PRODUCT ID: 423)
Yes. It has a 3-wire cable. One wire is common, the other two are NO and NC.
