AAA power inverter noise
- klerk
just received my 4xAAA battery powered power inverters, and they both emit a high frequency noise when all 4 batteries are placed. one makes the noise much more loudly when powered on. i'm using the batteries that came with the shipment. what am i doing wrong?
- adafruit_support_bill
Re: AAA power inverter noise
This is normal for inverters. The inverter is converting the ~6v DC from the 4xAA cells to ~100v AC at around 1-2KHz. The combination of the voltage boost and high-frequency switching creates audible vibrations in the inverter components.
Although it sounds pretty loud operating on a tabletop, if you stick it in your pocket you will barely hear it.
- klerk
unfortunately my application is for wall art....and the sound is an issue. i've never experienced this sound with any other battery powered device. is there a different inverter you can send me that doesn't squeal when the batteries are inserted?
They all do that to some degree. Some have had luck reducing the sound by wrapping them in foam and/or opening the case and filling the voids with hot-glue.
- klerk
if i cannot silence the inverter to an acceptable level, can i return my order for a full refund? i received it yesterday.
We can accept returns on unmodified products only, so I'd try the wrapping solution first.
- klerk
how would a 3V inverter compare to the 6V that came with the kit (that i'm having problems with)? will it result in a dimmer strip?
The 3v inverter will be somewhat dimmer using the same length of strip.
- klerk
how do i make a return? Do i need a return authorization number? please provide details. thanks.
Please contact [email protected] with a link to this thread and they will help arrange the return.
- Rothmj
Does filing the void cause any heat issues and is it as simple as filing the entire void with glue from a glue gun?
These don't run very hot to begin with, so the glue does not seem to cause any problems.
Filling the void should attenuate the noise noticeably, but probably not silence it completely.
