Controlling servos with Adafruit 16-Channel PWM Servo HAT
Our weekly LIVE video chat. Every Wednesday at 8pm ET!
dpersh
Post by dpersh »
I'm building a robot that needs to control 4 servos. I'm using Tower Pro MG90S (Micro Servo High Torque Metal Gear[ID:1143]) with Adafruit 16-Channel PWM Servo HAT.
Sometimes those servos would have trouble settling in for the required angle and would start buzzing and stuttering. I wonder if there a way to disengage a servo without cutting the power to it? All of my experimentation with configuring PWM driver to shut servos of were fruitless so far. I tried setting individual channels to [on = 0, off = 4096] (should kill PWM completely), tried setting all the channel to off in the same manner, tried putting PWM controller chip to sleep and even issuing SWRESET command - nothing makes any difference.
Generally, servos keep staying engaged once I've sent any meaningful PWM signal to the them. And they would stay engaged until the power if cut off completely.
Is this an expected behavior?
Denis
Re: Controlling servos with Adafruit 16-Channel PWM Servo HA
Try on = 0, off = 0.
dpersh
Post by dpersh »
Nope, doesn't help
adafruit2
Post by adafruit2 »
one more, try off = 0, on = 4096 ? can you see the signal on an oscilloscope?
dpersh
Post by dpersh »
Unfortunately I do not have access to the oscilloscope. However, trying one of those servos with Arduino I get the same result as with the Pi's Servo HAT. I loaded up Servo/Sweep example into my Uno and servo did what was expected, yet it would stay engaged even when I physically disconnect signal wire from it. It's only when the power or the ground leads are disconnected servo goes limp.
So, I'm guessing this is the property of Tower Pro MG90S servos. Since I bought those from Adafruit I wonder if you can reach out to the manufacturer to clarify on this topic.
Interesting. I have not seen that behavior with the MG90S before. But Tower has made other changes to this model over the years. I'll have to look into that.
adafruit2
Post by adafruit2 »
it might be a digital servo. perhaps digital servos 'hold'? :/
dpersh
Post by dpersh »
How can I tell? Is there a workaround?
The MG90S is not a digital servo - at least not the ones I have here. I will order up a couple from from current stock and do a tear-down on it to see what is inside.
bkaemmereit
Post by bkaemmereit »
Hi there!
I have similar issues with the Torcster Servo NR-645 MG BB.
The code runs pretty fine with the Graupner C 507.
My wiring
Any ideas?
I'm not familiar with that brand of servo. I'd check with your servo supplier.
bkaemmereit
At the moment i try to figure out in which value ranges the servo might run
Is it basicly correct?
servoMin = 0
servoMax = 4096
freq = 50
pwm.setPWMFreq(freq)
while True:
    freq = freq + 1
    print "setPWMFreq: %d" % freq
    pwm.setPWM(0, 0, servoMin)
    print "servoMin: %d" % servoMin
    time.sleep(1)
    pwm.setPWM(0, 0, servoMax)
    print "servoMax: %d" % servoMax
    print  "-------------------------------"
    time.sleep(1)
Franklin97355
Post by Franklin97355 »
What is the output when you run that code?
bkaemmereit
You mean in the console?
pi@raspberrypi ~/projects/lasi.us/test $ sudo python servotry06.py
setPWMFreq: 51
servoMin: 0
servoMax: 4096
setPWMFreq: 52
servoMin: 0
servoMax: 4096
setPWMFreq: 53
servoMin: 0
servoMax: 4096
setPWMFreq: 54
servoMin: 0
servoMax: 4096
setPWMFreq: 55
servoMin: 0
servoMax: 4096
The servo itself is just twitching - sometimes a not reproducable movement...
dpersh
Post by dpersh »
You probably do not want to change PWM frequency much as that's global for all of the PWM channels on Servo HAT. Essentially, setPWMFreq sets your duty cycle where 50~60Hz is generally a recommended freq range for servo control (AFAIK)
So, basically you set your PWM freq once and then find the range of your servos relative to it. You manipulate On and Off values passed to pwm.setPWM(Channel, On, Off) where:
On is the tick number at which signal goes High
Off is the tick number at which signal goes Low
You have total of 4096 ticks (0..4095) to work with.
Setting On = 4096 (special value) would instruct PCA9685 to go all *high* on the given channel throughout the duty cycle
Setting Off = 4096 (special value) would instruct PCA9685 to go all *low* on the given channel throughout the duty cycle
Read up on PCA9685 - datasheet explains it all.
Also, I would appreciate if you do not hijack this thread as I'm still hoping for the resolution of my original problem :)
Return to “Ask an Engineer! VIDEO CHAT (closed)”
