Hi! I am trying to successfully wire an OLED to an Electric Imp, like this, the idea being that the OLED is completely powered by the Imp, I guess that is possible? I couldn't find any demo online, (I checked youtube, hackster.io, Google, etc etc) for this particular OLED, so I started following this demo--
http://www.hackster.io/viccarre/electri ... scoreboard
However my ultimate goal is to have the imp change the picture or supershort video on the OLED when I tell it to at a distance using my iphone, not necessarily to update text as per the above demo, rather, more, to update images (or draw images mathematically)(probably just display them, perhaps from a folder of different ones that are on the OLED's SD card).
But basically I'm just looking to get this thing up and running, and wired correctly right now.
Can you help explain to me the exact wiring, using the total of 11 pins on the Imp's GPIO, and the total of 11 pins on the OLED? Any way to give me an exact picture of what gets hooked up where? (Again assuming I'm a pure beginner)
Thank you so much!
(PS I also have another post here that I'm still stuck on, and hoping to continue bouncing ideas off of one of you all :)
viewtopic.php?f=45&t=70733
Very Sincerely,
Sarah
Wiring an Electric Imp to OLED SSD1351
- lahtisarah
- IMG_4516.JPG (98.27 KiB) Viewed 366 times
- IMG_4518.JPG (112.69 KiB) Viewed 366 times
- IMG_4514.JPG (93.92 KiB) Viewed 366 times
- adafruit_support_rick
Re: Wiring an Electric Imp to OLED SSD1351
You haven't soldered any of the header pins. It won't work without solder.
Unfortunately, I'm not familiar with the electric imp. You'll have to discover which GPIO pins support SPI. You'll also need SPI driver software to run the oled.
