Hi all,
this topic about has two sections
first section:
I recently bought TFT 5.0 touch screen with RA8875 breakout to connect the tft with arduino, but when I try to calibrate the touch screen the points of calibration keep changing. i.e. when the first piont is pressed the second is pressed by itself and move to the third one which yield to inaccurate reading for the touch coordinate
so is the touchpad has some issues ? or did I do something wrong ?
Second section
This section about RA8875 itself.
what is the minummum voltage for the Vin of this chip ? should I use 5V volt exactly or more to obtain better result?
Regards
TFT 5.0 with RA8875
- adafruit_support_rick
Re: TFT 5.0 with RA8875
What are you using for a touch controller?
Run the RA8875 on 5V only.
- Hussam
thank you for your replyadafruit_support_rick wrote:What are you using for a touch controller?
I am currently trying to calibrate the touch screen because when I am trying any example which including touch function I noticed that thouch is not accurate
for example when using test example from the librery the touch circls repeat themself inaccurately.
if you want me to uplaod a video showing whats going on I don't have any problem
Yes, a video would be good. Thanks!
- Hussam
thank you for your replyadafruit_support_rick wrote:Yes, a video would be good. Thanks!
here is the link for my video
https://drive.google.com/file/d/0B3pv8E ... sp=sharing
I prefer to download it
That's weird. Let's try replacing the screen.
Please email [email protected] with a link to this thread for a replacement TFT
