Hi
What to buy?
I have a 120watt, 10 amp, 12volt water heating element. But I don't want it to be available to the arduino in an on / off mode only.
I want the element to just be warm, a little. So i need to regulate the voltage digitally.
Please tell me - What can I buy at adafruit to do this ?
Best regards
Dean
arduino voltage regulator - buy what?
Re: arduino voltage regulator - buy what?
You can use one of the PWM pins on the Arduino to drive a power MOSFET like this one: https://www.adafruit.com/search?q=mosfet&b=1
Using the AnalogWrite function, you can control the PWM duty cycle from 0% to 100% with a resolution of 255 steps.
If your heating element is inductive, you will probably need to add a snubber diode to protect the MOSFET from the reverse inductive spike.
- Deansmithok
Hi
Thank you so much for the gem of help. Saved my many days.
But you have scared me to death on that reverse inductive spike. Please could you post a link to that buy item, and tell me what should be on either side of the diode- like MOSFET gate and arduino.. I'm not so sure :)
Best regards
Dean
Best regards
Dean
This circuit is for a solenoid, but will work for any inductive load:
And here are some diodes: https://www.adafruit.com/product/755
