LED Belt Windows 7 driver install issue
Postby KaleidoJL » Sat May 05, 2012 6:17 pm
Hello! First time poster, quite happy playing with the loot from my first Adafruit shipment. The LED Belt is soldered and assembled, however the Windows 7 driver install process seems entirely different than the one in the tutorial. Same outcome on two separate WIndows 7 boxes--I don't have any XP builds around here.
A pop-up from the auto-install says: "Device Driver was not succesfully installed; AVR CDC Bootloader; X No driver found".
Right-clicking "atmega32u4cdc.inf" then selecting Install results in "The INF file you selected does not support this method of installation".
Control Panel -> "Add a device" doesn't find it either upon USB connect or after booting the board by pressing the white button. Connecting to USB elicits the recognition tone, but stumbles after that. Seeking a manual install feature, I go to "My Computer", right-click the AVR CDC icon then dig into Properties and "Update Driver". I set it to look at the Desktop for the driver but alas, "Windows could not find driver software for your device."
Any ideas on how to proceed? Much obliged.
KaleidoJL
Re: LED Belt Windows 7 driver install issue
Postby newmexelectron » Sat May 05, 2012 11:34 pm
I am having a similar issue with Windows 7 Driver for the Adafruit- USB/Serial Backpack...
I got a very detailed response from Support- viewtopic.php?f=47&t=28259
but I still haven't had any luck with getting the Driver to install. I am going to post details of what I have tried on that thread.
I know it isn't the same Driver that you need, but it may be the same issue with Windows7 and both drivers.
Good luck.
newmexelectron
Postby adafruit_support_bill » Sun May 06, 2012 6:00 am
Make sure that the INF file was saved as "atmega32u4cdc.inf" and not "atmega32u4cdc.inf.txt". By default, windows 7 hides the file extension, but the file type should be shown as "Setup Information" not "Text Document".
Postby KaleidoJL » Sun May 06, 2012 11:00 am
Thanks for the quick reply & weighing in, both of you! However, the file type is indeed "Setup Information". I'll try re-saving it manually per your instructions in the newmexelectron thread... (viewtopic.php?f=47&t=28259)
The control panel > add a device ... etc approach still cannot find the driver on the desktop or in a new folder. Tried on each USB port to no avail. The red LED remains solid on, and the green LED breathes patiently. What else might work?
KaleidoJL
Postby adafruit_support_bill » Sun May 06, 2012 12:56 pm
Does the device show up anywhere in Control Panel? Likely places to check are: COM ports, "Unknown" devices and "Other" devices.
Postby KaleidoJL » Sun May 06, 2012 3:16 pm
Indeed, through the Control Panel and into the device drivers (with the tree fully expanded) it's under: /Me_Gusta/Other devices/AVR CDC Bootloader
However, when going "Action > Update Driver Software..." it cannot locate the driver even when pointed to the download directory. All this effort is pointed towards the "Lightning in a Bottle" festival in a few weeks. I'm upgrading my "Kaleidoscopic Man" costume to v2.0.
KaleidoJL
Postby adafruit_support_bill » Mon May 07, 2012 4:46 am
Have you unzipped it, or is it still in the compressed archive?
Postby KaleidoJL » Mon May 07, 2012 10:33 am
It doesn't look like it comes zipped to begin with: http://www.adafruit.com/datasheets/atmega32u4cdc.inf
Viewing the text of the INF shows there are sections for both "Windows 2000/XP/Vista-32bit" & "Vista-64 bit". Does that mean the driver file requires a Windows 7 update/tweak?
KaleidoJL
Postby adafruit_support_bill » Mon May 07, 2012 10:55 am
No. Vista/64 drivers work on Win-7/64 (& that driver has been tested on Win-7/64.). I'll see if I can reproduce your symptoms here.
Postby KaleidoJL » Tue May 08, 2012 12:52 am
Thanks :) The atmega breakout board hasn't been too heavily worked, either. Just the header, power & ground wires. My backup solution is trying to find some laptop with XP. Right now I don't have time to convert to a dual-boot. The arduino IDE opens up and "Tools > Serial Port" is grayed out.
Perhaps I should also mention that a previous auto-detect on this driver crashed my computer with the BSoD and I ended having to go back to a previous Restore point.
KaleidoJL
Postby KaleidoJL » Wed May 09, 2012 1:32 am
Well cut my legs & call me Shorty! In desperation after much troubleshooting I made a very minor change to the driver file per this thread: viewtopic.php?f=19&t=19075&p=144446&hilit=REV_0002#p144446
I do not know why changing REV_0001 to REV_0002 in two locations seems to have worked, but it does and I'm running with it. For anyone else searching this thread, this is what I did: copy-pasted "atmega32u4cdc.inf" back onto the desktop as "a.inf" and changed the text to this:
; Vendor and Product ID Definitions
; When developing your USB device... (etc)
[SourceDisksFiles]
[SourceDisksNames]
[DeviceList]
%DESCRIPTION%=DriverInstall, USB\VID_239A&PID_0001&REV_0002
[DeviceList.NTamd64]
KaleidoJL
Postby adafruit_support_bill » Wed May 09, 2012 4:56 am
Thanks for the feedback on that. Not sure why that works, but it does in some cases. Still trying to get to the bottom of it...
Postby Mack6225 » Thu May 17, 2012 2:53 am
I am having the same problem == and followed the past posts results :
A dialog from the auto-install reports : "Device Driver was not succesfully installed; AVR CDC Bootloader
atmega32u4cdc.inf in desktop folder where it should be
Device Manager reports /Other devices/AVR CDC Bootloader
Have uninstalled com port 51 where arduino lives
Thanks to KaleidoJL (05 May 2012 22:33) I have made the changes to .inf file
[DeviceList]
no help
have uninstalled most all USB drivers using USBdeview no help
ran hdwwiz in a run prompt no Help
Environment is WIN7 382GB free space 8MB mem 4MB unused - all usb ports available = wifi -- currently no com ports or LPT ports in use (wiifi printer) 2.4ghz keyboard and mouse monitor is HDMI OS/PC is one year old no problems no crash no lock.
I am old man Crippled, Half Blind & crazy.
Ideas criticize prayers / Welcome!
What am I overlooking??
Mack6225
Postby adafruit_support_bill » Thu May 17, 2012 7:39 am
* Does the 32U4 show up in Device Manager? If so, what is it displayed as?
* Have you tried updating the driver in Device Manager? If so, what error message did you see?
Postby Mack6225 » Thu May 17, 2012 8:30 am
As stated in line 5 of my previous post :
Yes I did try to update by right click in the device manager and the dialog reports :
Thank you for your prompt response - still no go this AM
Mack6225
Next
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
Users browsing this forum: mibignistinly and 7 guests
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
