LED Belt Windows 7 driver install issue
Re: LED Belt Windows 7 driver install issue
Postby adafruit_support_bill » Thu May 17, 2012 9:54 am
Environment is WIN7
Are you on a 32 or 64 bit system?
In C:/Windows/inf, there should be a file called "setupapi.dev.log". The last section should show a record of your driver install attempts and may contain some useful information for diagnosing the problem.
Post the last few hundred lines (use the "code" button above the edit window and paste the text between the tabs.)
Postby Mack6225 » Thu May 17, 2012 6:58 pm
64
called "setupapi.dev.log" is uploaded as attachment
Thanks in advance
message contains banned characters. The maximum number of allowed characters is 60000
Trying to upload attachment
Mack6225
Postby adafruit_support_bill » Thu May 17, 2012 7:29 pm
Postby Mack6225 » Thu May 17, 2012 8:58 pm
Well I only had to be told twice.
>>>  [Device Install (DiInstallDevice) - ROOT\PORTS\0000]
>>>  Section start 2012/05/16 23:14:12.970
      cmd: "C:\Windows\system32\hdwwiz.exe"
     dvi: Selected driver installs from section [ComPort] in 'c:\windows\system32\driverstore\filerepository\msports.inf_amd64_neutral_fdcfb86ce78678d1\msports.inf'.
     dvi: Set selected driver complete.
     inf: {SetupCopyOEMInf: C:\Windows\INF\msports.inf} 23:14:12.980
     inf:      Opened PNF: 'C:\Windows\INF\msports.inf' ([strings.0409])
!    inf:      Unable to set OEM source media location - error ignored
!    inf:      Error 87: The parameter is incorrect.
     inf: {SetupCopyOEMInf exit (0x00000000)} 23:14:13.055
     inf: Opened INF: 'C:\Windows\System32\DriverStore\FileRepository\msports.inf_amd64_neutral_fdcfb86ce78678d1\msports.inf' ([strings.0409])
     dvi: {Plug and Play Service: Device Install for ROOT\PORTS\0000}
     ump:      Creating Install Process: DrvInst.exe 23:14:13.085
     ndv:      Infpath=C:\Windows\INF\msports.inf
     ndv:      DriverNodeName=msports.inf:Std.NTamd64:ComPort:6.1.7600.16385:*pnp0500:*pnp0501
     ndv:      DriverStorepath=C:\Windows\System32\DriverStore\FileRepository\msports.inf_amd64_neutral_fdcfb86ce78678d1\msports.inf
     ndv:      Building driver list from driver node strong name...
     inf:      Saved PNF: 'C:\Windows\System32\DriverStore\FileRepository\msports.inf_amd64_neutral_fdcfb86ce78678d1\msports.PNF' (Language = 0409)
     ndv:      {Core Device Install} 23:14:13.215
!    pol:           Selected driver node does not match this device (force-install)
     dvi:           {DIF_ALLOW_INSTALL} 23:14:13.270
     dvi:                Using exported function 'PortsClassInstaller' in module 'C:\Windows\system32\MsPorts.Dll'.
     dvi:                Class installer == MsPorts.Dll,PortsClassInstaller
     dvi:                No CoInstallers found
     dvi:                Class installer: Enter 23:14:13.275
     dvi:                Class installer: Exit
     dvi:                Default installer: Enter 23:14:13.275
     dvi:                Default installer: Exit
     dvi:           {DIF_ALLOW_INSTALL - exit(0xe000020e)} 23:14:13.275
     ndv:           Installing files...
     dvi:           {DIF_INSTALLDEVICEFILES} 23:14:13.280
     dvi:                Class installer: Enter 23:14:13.280
     dvi:                Default installer: Enter 23:14:13.280
     dvi:                     {Install FILES}
     inf:                          Opened PNF: 'c:\windows\system32\driverstore\filerepository\msports.inf_amd64_neutral_fdcfb86ce78678d1\msports.inf' ([strings.0409])
     inf:                          {Install Inf Section [ComPort.NT]}
     inf:                               CopyFiles=ComPort.NT.Copy  (msports.inf line 254)
     flq:                               CopyFiles from an inbox inf.
     cpy:                               Open PnpLockdownPolicy: Err=2. This is OK. Use LockDownPolicyDefault
     flq:                               QueueSingleCopy...
     flq:                               Inf     : 'c:\windows\system32\driverstore\filerepository\msports.inf_amd64_neutral_fdcfb86ce78678d1\msports.inf'
     flq:                               SourceInf: 'c:\windows\system32\driverstore\filerepository\msports.inf_amd64_neutral_fdcfb86ce78678d1\msports.inf'
     flq:                               SourceSection: [sourcedisksfiles]
     flq:                               Source root path based on SourceInf
     flq:                               SourceRootPath: 'C:\Windows\System32\DriverStore\FileRepository\msports.inf_amd64_neutral_fdcfb86ce78678d1'
     flq:                               {FILE_QUEUE_COPY}
     flq:                                    CopyStyle      - 0x09000000
     flq:                                         SourceRootPath - 'C:\Windows\System32\DriverStore\FileRepository\msports.inf_amd64_neutral_fdcfb86ce78678d1'
     flq:                                         SourceFilename - 'serial.sys'
     flq:                                         TargetDirectory- 'C:\Windows\system32\DRIVERS'
     flq:                                         TargetFilename - 'serial.sys'
     flq:                                         SourceDesc     - 'windows cd'
     flq:                                    {FILE_QUEUE_COPY exit(0x00000000)}
     flq:                                         SourceFilename - 'serenum.sys'
     flq:                                         TargetFilename - 'serenum.sys'
     inf:                          {Install Inf Section [ComPort.NT] exit (0x00000000)}
     dvi:                          Processing co-installer registration section [ComPort.NT.CoInstallers].
     inf:                          {Install Inf Section [ComPort.NT.CoInstallers]}
     inf:                          {Install Inf Section [ComPort.NT.CoInstallers] exit (0x00000000)}
     dvi:                          Co-installers registered.
     dvi:                          {Install INTERFACES}
     dvi:                               Installing section [ComPort.NT.Interfaces]
     dvi:                          {Install INTERFACES exit 00000000}
     dvi:                     {Install FILES exit (0x00000000)}
     dvi:           {DIF_INSTALLDEVICEFILES - exit(0x00000000)} 23:14:13.300
     ndv:           Pruning file queue...
     dvi:           {_SCAN_FILE_QUEUE}
     flq:                ScanQ flags=620
     flq:                     SPQ_SCAN_PRUNE_COPY_QUEUE
     flq:                     SPQ_SCAN_FILE_COMPARISON
     flq:                     SPQ_SCAN_ACTIVATE_DRP
     flq:                ScanQ number of copy nodes=2
     flq:                File 'C:\Windows\system32\DRIVERS\serial.sys' pruned from copy.
     sig:                Using catalog 'C:\Windows\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~~6.1.7600.16385.cat'.
     cpy:                DrpSetRegFileProt 'C:\Windows\system32\DRIVERS\serial.sys' Status=0 Class=Inbox Windows protected
     flq:                File 'C:\Windows\system32\DRIVERS\serenum.sys' pruned from copy.
     cpy:                DrpSetRegFileProt 'C:\Windows\system32\DRIVERS\serenum.sys' Status=0 Class=Inbox Windows protected
     flq:                ScanQ action=200 DoPruning=32
     flq:                ScanQ end Validity flags=620 CopyNodes=0
     dvi:           {_SCAN_FILE_QUEUE exit(0, 0x00000000)}
     ndv:           Committing file queue...
     flq:           {_commit_file_queue}
     flq:                CommitQ DelNodes=0 RenNodes=0 CopyNodes=0
     flq:                CommitQ early exit: No nodes are queued
     flq:           {_commit_file_queue exit OK}
     ndv:           Registering CoInstallers...
     dvi:           {DIF_REGISTER_COINSTALLERS} 23:14:13.580
     dvi:                Class installer: Enter 23:14:13.580
     dvi:                Default installer: Enter 23:14:13.580
     dvi:           {DIF_REGISTER_COINSTALLERS - exit(0x00000000)} 23:14:13.590
     ndv:           Installing interfaces...
     dvi:           {DIF_INSTALLINTERFACES} 23:14:13.590
     dvi:                Class installer: Enter 23:14:13.590
     dvi:                Default installer: Enter 23:14:13.590
     dvi:           {DIF_INSTALLINTERFACES - exit(0x00000000)} 23:14:13.595
     ndv:           Installing device...
     dvi:           {DIF_INSTALLDEVICE} 23:14:13.595
     dvi:                Class installer: Enter 23:14:13.595
     inf:                     AddReg=ComPort.AddReg,ComPort.NT.AddReg  (msports.inf line 255)
     dvi:                     {Install DEVICE}
     dvi:                          Writing BASIC Logical Configurations...
     dvi:                          Processing Registry/Property directives...
     inf:                          {Install Inf Section [ComPort.NT.Hw]}
     inf:                               AddReg=ComPort.NT.HW.AddReg  (msports.inf line 260)
     inf:                          {Install Inf Section [ComPort.NT.Hw] exit (0x00000000)}
     dvi:                          {Writing Device Properties}
     dvi:                               Provider name=Microsoft
     dvi:                               DriverDate 06/21/2006
     dvi:                               DriverVersion=6.1.7600.16385
     dvi:                               Class name=Ports
     dvi:                               Manufacturer=(Standard port types)
     dvi:                               HardwareID=*pnp0500
     dvi:                               CompatibleID=*pnp0501
     dvi:                               Matching DeviceID=*pnp0500
     dvi:                               Strong Name=msports.inf:Std.NTamd64:ComPort:6.1.7600.16385:*pnp0500:*pnp0501
     dvi:                          {Writing Device Properties - Complete}
     inf:                          {Install Inf Section [ComPort.NT.Services]}
     inf:                               AddService=Serial,0x00000002,Serial_Service_Inst,Serial_EventLog_Inst  (msports.inf line 304)
     inf:                               ServiceType=1  (msports.inf line 317)
     inf:                               StartType=1  (msports.inf line 318)
     inf:                               ErrorControl=0  (msports.inf line 319)
     inf:                               ServiceBinary=C:\Windows\system32\DRIVERS\serial.sys  (msports.inf line 320)
     inf:                               DisplayName="Serial port driver"  (msports.inf line 316)
     inf:                               LoadOrderGroup="Extended base"  (msports.inf line 321)
     dvi:                               Add Service: Modified existing service 'Serial'.
     inf:                               AddReg=Serial_EventLog_AddReg  (msports.inf line 333)
     inf:                               AddService=Serenum,,Serenum_Service_Inst  (msports.inf line 305)
     inf:                               ServiceType=1  (msports.inf line 326)
     inf:                               StartType=3  (msports.inf line 327)
     inf:                               ErrorControl=1  (msports.inf line 328)
     inf:                               ServiceBinary=C:\Windows\system32\DRIVERS\serenum.sys  (msports.inf line 329)
     inf:                               DisplayName="Serenum Filter Driver"  (msports.inf line 325)
     inf:                               LoadOrderGroup="PNP Filter"  (msports.inf line 330)
     dvi:                               Add Service: Modified existing service 'Serenum'.
     inf:                          {Install Inf Section [ComPort.NT.Services] exit(0x00000000)}
     dvi:                          Updated reflected section names for: msports.inf
     dvi:                     {Install DEVICE exit (0x00000000)}
     dvi:                     Writing common driver property settings.
     dvi:                          DriverDescription=Communications Port
     dvi:                          DeviceDisplayName=Communications Port
     dvi:                     Install Device: Restarting device. 23:14:13.765
     dvi:                     Install Device: Restarting device completed. 23:14:13.780
!!!  dvi:                     Device not started: Device has problem: 0x22: CM_PROB_NO_SOFTCONFIG.
     dvi:           {DIF_INSTALLDEVICE - exit(0x00000000)} 23:14:13.785
     dvi:           {DIF_NEWDEVICEWIZARD_FINISHINSTALL} 23:14:13.785
     dvi:                Class installer: Enter 23:14:13.785
     dvi:                Default installer: Enter 23:14:13.785
     dvi:           {DIF_NEWDEVICEWIZARD_FINISHINSTALL - exit(0xe000020e)} 23:14:13.785
     ndv:           Device install status=0x00000000
     ndv:           Performing device install final cleanup...
!    ndv:           Queueing up error report since device has a PnP problem...
     ndv:      {Core Device Install - exit(0x00000000)} 23:14:13.790
     dvi:      {DIF_DESTROYPRIVATEDATA} 23:14:13.790
     dvi:           Class installer: Enter 23:14:13.790
     dvi:           Default installer: Enter 23:14:13.790
     dvi:      {DIF_DESTROYPRIVATEDATA - exit(0xe000020e)} 23:14:13.790
     ump:      Server install process exited with code 0x00000000 23:14:13.805
     ump: {Plug and Play Service: Device Install exit(00000000)}
     dvi: {DIF_DESTROYPRIVATEDATA} 23:14:13.815
     dvi:      Class installer: Enter 23:14:13.815
     dvi:      Default installer: Enter 23:14:13.815
     dvi: {DIF_DESTROYPRIVATEDATA - exit(0xe000020e)} 23:14:13.815
<<<  Section end 2012/05/16 23:14:13.815
<<<  [Exit status: SUCCESS]
>>>  [Device Install (DiShowUpdateDevice) - USB\VID_239A&PID_0001\6&12CDDB4D&2&2]
>>>  Section start 2012/05/16 23:16:24.768
      cmd: "C:\Windows\System32\DeviceProperties.exe" "USB\VID_239A&PID_0001\6&12CDDB4D&2&2"
     dvi: {DIF_UPDATEDRIVER_UI} 23:16:24.772
     dvi:      No class installer for 'AVR CDC Bootloader'
     dvi:      Default installer: Enter 23:16:24.779
     dvi: {DIF_UPDATEDRIVER_UI - exit(0xe000020e)} 23:16:24.784
     ndv: {Update Driver Software Wizard for USB\VID_239A&PID_0001\6&12CDDB4D&2&2}
     ndv: {Update Driver Software Wizard exit(00000000)}
<<<  Section end 2012/05/16 23:51:53.355
>>>  Section start 2012/05/16 23:52:06.379
     dvi: {DIF_UPDATEDRIVER_UI} 23:52:06.382
     dvi:      Default installer: Enter 23:52:06.389
     dvi: {DIF_UPDATEDRIVER_UI - exit(0xe000020e)} 23:52:06.394
<<<  Section end 2012/05/16 23:52:21.072
>>>  Section start 2012/05/16 23:53:17.414
     dvi: {DIF_UPDATEDRIVER_UI} 23:53:17.419
     dvi:      Default installer: Enter 23:53:17.419
     dvi: {DIF_UPDATEDRIVER_UI - exit(0xe000020e)} 23:53:17.419
<<<  Section end 2012/05/16 23:53:30.408
>>>  [Device Uninstall (Device Manager) - USB\VID_239A&PID_0001\6&12CDDB4D&2&2]
>>>  Section start 2012/05/16 23:53:36.995
     dvi: {DIF_REMOVE} 23:53:36.998
     dvi:      Default installer: Enter 23:53:37.004
     dvi:           {Remove DEVICE}
     dvi:                InstanceID = 'USB\VID_239A&PID_0001\6&12CDDB4D&2&2'
     dvi:                Devnode Status = 0x01806400
     dvi:                CM_Query_And_Remove_Subtree_Ex returns 0x00000000
     dvi:                Devnode Status after CM_Query_And_Remove_Subtree_Ex = 0x01806400
     dvi:                Query-and-Remove succeeded
     dvi:                {Delete DEVICE}
     dvi:                     Device Instance uninstalled.
     dvi:                {Delete DEVICE exit (0x00000000)}
     dvi:           {Remove DEVICE exit (0x00000000)}
     dvi: {DIF_REMOVE - exit(0x00000000)} 23:53:37.037
<<<  Section end 2012/05/16 23:53:37.037
>>>  [Device Uninstall (Device Manager) - ROOT\PORTS\0000]
>>>  Section start 2012/05/16 23:54:54.627
      cmd: "C:\Windows\system32\mmc.exe" C:\Windows\system32\devmgmt.msc
     dvi: {DIF_REMOVE} 23:54:54.627
     dvi:      Class installer: Enter 23:54:54.647
     dvi:                InstanceID = 'ROOT\PORTS\0000'
     dvi:                Devnode Status = 0x01802403
     dvi:                Devnode Status after CM_Query_And_Remove_Subtree_Ex = 0x01802401
     dvi: {DIF_REMOVE - exit(0x00000000)} 23:54:54.697
<<<  Section end 2012/05/16 23:54:54.697
[Boot Session: 2012/05/16 23:58:06.109]
>>>  [Device Install (Hardware initiated) - usb\vid_239a&pid_0001\6&12cddb4d&2&2]
>>>  Section start 2012/05/16 23:58:52.570
     ump: Creating Install Process: DrvInst.exe 23:58:52.630
     ndv: Retrieving device info...
     ndv: Setting device parameters...
     ndv: Searching just Driver Store...
     dvi: {Build Driver List} 23:58:52.820
     cpy:      Policy is set to make all digital signatures equal.
     dvi:      Enumerating INFs from path list 'C:\Windows\INF'
     dvi: {Build Driver List - exit(0x00000000)} 23:58:53.741
     ndv: Selecting best match from just Driver Store...
     dvi: {DIF_SELECTBESTCOMPATDRV} 23:58:53.741
     dvi:      Default installer: Enter 23:58:53.751
     dvi:           {Select Best Driver}
!    dvi:                Selecting driver failed(0xe0000228)
     dvi:           {Select Best Driver - exit(0xe0000228)}
!    dvi:      Default installer: failed!
!    dvi:      Error 0xe0000228: There are no compatible drivers for this device.
     dvi: {DIF_SELECTBESTCOMPATDRV - exit(0xe0000228)} 23:58:53.821
     ndv: Skipping Windows Update because no internet connection!
     ndv: Searching Driver Store and Device Path...
     dvi: {Build Driver List} 23:58:58.952
     dvi:      Enumerating INFs from path list 'C:\Windows\inf'
     dvi: {Build Driver List - exit(0x00000000)} 23:59:07.502
     ndv: Selecting best match from Driver Store (including Device Path)...
     dvi: {DIF_SELECTBESTCOMPATDRV} 23:59:07.502
     dvi:      Default installer: Enter 23:59:07.502
     dvi: {DIF_SELECTBESTCOMPATDRV - exit(0xe0000228)} 23:59:07.502
     ndv: {Core Device Install} 23:59:07.502
!    ndv:      Installing NULL driver!
     dvi:      {DIF_ALLOW_INSTALL} 23:59:07.502
     dvi:      {DIF_ALLOW_INSTALL - exit(0xe000020e)} 23:59:07.502
     dvi:      {DIF_INSTALLDEVICE} 23:59:07.502
!    dvi:                Installing NULL driver!
     dvi:                {Restarting Devices} 23:59:07.542
     dvi:                     Restart: USB\VID_239A&PID_0001\6&12CDDB4D&2&2
     dvi:                {Restarting Devices exit} 23:59:07.612
     dvi:      {DIF_INSTALLDEVICE - exit(0x00000000)} 23:59:07.612
     ndv:      Device install status=0xe0000203
!    ndv:      Queueing up error report since device installation failed...
     ndv: {Core Device Install - exit(0xe0000203)} 23:59:07.612
     ump: Server install process exited with code 0xe0000203 23:59:07.612
<<<  Section end 2012/05/16 23:59:07.622
<<<  [Exit status: FAILURE(0xe0000203)]
>>>  Section start 2012/05/17 00:01:06.239
     dvi: {DIF_UPDATEDRIVER_UI} 00:01:07.149
     dvi:      Default installer: Enter 00:01:07.219
     dvi: {DIF_UPDATEDRIVER_UI - exit(0xe000020e)} 00:01:07.259
<<<  Section end 2012/05/17 00:01:28.295
>>>  Section start 2012/05/17 00:02:18.361
     dvi: {DIF_REMOVE} 00:02:18.371
     dvi:      Default installer: Enter 00:02:18.371
     dvi: {DIF_REMOVE - exit(0x00000000)} 00:02:18.401
<<<  Section end 2012/05/17 00:02:18.401
>>>  [Device Install (Hardware initiated) - USB\VID_239A&PID_0001\6&12cddb4d&2&2]
>>>  Section start 2012/05/17 00:02:24.561
     ump: Creating Install Process: DrvInst.exe 00:02:24.561
     dvi: {Build Driver List} 00:02:25.701
     dvi: {Build Driver List - exit(0x00000000)} 00:02:26.282
     dvi: {DIF_SELECTBESTCOMPATDRV} 00:02:26.282
     dvi:      Default installer: Enter 00:02:26.292
     dvi: {DIF_SELECTBESTCOMPATDRV - exit(0xe0000228)} 00:02:26.292
     ndv: Searching Windows Update for drivers... 00:02:26.322
     ndv: Acquired WU search serialization mutex. 00:02:26.322
     ndv: About to release WU search serialization mutex. 00:02:42.533
     ndv: No driver found on Windows Update. 00:02:42.533
     dvi: {Build Driver List} 00:02:42.533
     dvi: {Build Driver List - exit(0x00000000)} 00:02:46.823
     dvi: {DIF_SELECTBESTCOMPATDRV} 00:02:46.823
     dvi:      Default installer: Enter 00:02:46.823
     dvi: {DIF_SELECTBESTCOMPATDRV - exit(0xe0000228)} 00:02:46.833
     ndv: {Core Device Install} 00:02:46.833
     dvi:      {DIF_ALLOW_INSTALL} 00:02:46.833
     dvi:           Default installer: Enter 00:02:46.833
     dvi:      {DIF_ALLOW_INSTALL - exit(0xe000020e)} 00:02:46.833
     dvi:      {DIF_INSTALLDEVICE} 00:02:46.833
     dvi:                {Restarting Devices} 00:02:46.853
     dvi:                {Restarting Devices exit} 00:02:46.853
     dvi:      {DIF_INSTALLDEVICE - exit(0x00000000)} 00:02:46.853
     ndv: {Core Device Install - exit(0xe0000203)} 00:02:46.853
     ump: Server install process exited with code 0xe0000203 00:02:46.963
<<<  Section end 2012/05/17 00:02:46.973
Mack6225
Postby adafruit_support_bill » Fri May 18, 2012 4:48 am
It is doing the default search for drivers. This won't work. You need to select "Browse my computer for driver software". Then select the folder where you have downloaded the INF file.
Postby Mack6225 » Tue May 22, 2012 10:43 pm
I did that – several times checked and double checked After your last post I took a break and then learned what the setupapi.dev.log does and found I could delete it. Then I looked at atmega32u4cdc.inf well well what do you know? The file atmega32u4cdc.inf had garbage at the bottom of the file. It’s corrupt! I haven’t seen that since MSDOS ver 5 I’m happy to say. I downloaded another atmega32u4cdc.inf and followed adafruit procedure and worked as advertised. Finished building the LED Belt Kit works great first time. I hope this information is helpful to someone. Thank you for your help.
Mack6225
Postby RandomOutput » Sun Jul 01, 2012 5:25 pm
I'm having the same issue here. Windows won't recognize atmega32u4cdc.inf as a valid driver when I point it at the driver location (tried both my desktop and a subfolder on the desktop containing only the driver). I just says no valid drivers found. Looking at the .inf in notepad I'm not seeing any obvious garbage text. Using a version of the .inf downloaded from http://www.adafruit.com/datasheets/atmega32u4cdc.inf .
I took a look at setupapi.dev.log but it makes no mention of any events preceding 2 days previous to my attempts to install these drivers.
Any help would be appreciated.
RandomOutput
Postby adafruit » Sun Jul 01, 2012 9:03 pm
can you post what VID/PID & subversion its reporting?
Previous
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
Users browsing this forum: No registered users and 4 guests
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
