Breakout boards with micro SD card socket
Postby kscharf » Mon Aug 13, 2012 8:17 am
I've just noticed a small flaw with your two LCD displays with buit in micro SD card reader slots (and probably the stand alone SD card breakout board). The card will be nearly flush with the edge of the board when inserted. I wanted to put one of these boards into a small plastic case along with other boards to make a digital music player. I would cut a slot into the side of the case to allow changing the SD card, but it appears that I can't get the board close enough to the side of the case to be able to fully insert a card or remove it (maybe if I use a popstick to push the card in the rest of the way...). If the socket would overhang the edge of the board by about .1" it would be possible to have the socket right up against the wall of the case and maybe even project part ways into an opening in the wall. I think that these cards are usually accessed in most devices via a removable panel in the back or wall of the device and not a slot.
kscharf
Re: Breakout boards with micro SD card socket
Postby adafruit » Mon Aug 13, 2012 8:34 am
thanks for the feedback! this is the first time we've heard this request, we'll share it with our team.
thanks again,
adafruit support
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
Users browsing this forum: ArekKindAcere and 5 guests
New Products [113]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
