After the RPi2 boots up and the kernal loads, the screen goes black But when I enter the following commands
sudo mv /usr/share/X11/xorg.conf.d/99-fbturbo.conf ~
export FRAMEBUFFER=/dev/fb1
startx
startx
pi@raspberrypi ~ $ sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.14-v7+ (root@vagrant-ubuntu-trusty-32) (gcc ve rsion 4.8.3 20140106 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.01 - Lina ro GCC 2013.11) ) #2 SMP PREEMPT Thu May 28 18:17:59 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 80836a80, node_mem_map ba09300 0
[ 0.000000] Normal zone: 1888 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (8620->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 10 pages/cpu @ba060000 s12224 r8192 d20544 u4096 0
[ 0.000000] pcpu-alloc: s12224 r8192 d20544 u40960 alloc=10*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 239776
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1776 bcm2708_fb.fbheight=952 bcm2709.boardrev=0xa21041 bcm2709.serial=0xf71cafbb smsc 95xx.macaddr=B8:27:EB:1C:AF:BB bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2 709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_bas e=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,11 5200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 940664K/966656K available (5832K kernel code, 403K rwdata , 1776K rodata, 396K init, 772K bss, 25992K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
[ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x8077657c (7610 kB)
[ 0.000000] .init : 0x80777000 - 0x807da000 ( 396 kB)
[ 0.000000] .data : 0x807da000 - 0x8083edec ( 404 kB)
[ 0.000000] .bss : 0x8083edec - 0x808fff54 ( 773 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000014] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 35791 39424256ns
[ 0.000036] Switching to timer-based delay loop, resolution 52ns
[ 0.000323] Console: colour dummy device 80x30
[ 0.001842] console [tty1] enabled
[ 0.001893] Calibrating delay loop (skipped), value calculated using timer fr equency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001976] pid_max: default: 32768 minimum: 301
[ 0.002400] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002460] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.003746] Initializing cgroup subsys memory
[ 0.003842] Initializing cgroup subsys devices
[ 0.003895] Initializing cgroup subsys freezer
[ 0.003961] Initializing cgroup subsys net_cls
[ 0.004014] Initializing cgroup subsys blkio
[ 0.004124] CPU: Testing write buffer coherency: ok
[ 0.004239] ftrace: allocating 20147 entries in 60 pages
[ 0.054095] CPU0: update cpu_capacity 1024
[ 0.054172] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.054211] [bcm2709_smp_prepare_cpus] enter
[ 0.054368] Setting up static identity map for 0x541ef8 - 0x541f50
[ 0.114029] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.114335] CPU1: Booted secondary processor
[ 0.114342] [bcm2709_secondary_init] enter cpu:1
[ 0.114397] CPU1: update cpu_capacity 1024
[ 0.114405] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.133991] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.134239] CPU2: Booted secondary processor
[ 0.134245] [bcm2709_secondary_init] enter cpu:2
[ 0.134276] CPU2: update cpu_capacity 1024
[ 0.134284] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.154063] [bcm2709_boot_secondary] cpu:3 started (0) 16
[ 0.154300] CPU3: Booted secondary processor
[ 0.154306] [bcm2709_secondary_init] enter cpu:3
[ 0.154337] CPU3: update cpu_capacity 1024
[ 0.154345] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.154442] Brought up 4 CPUs
[ 0.154563] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.154597] CPU: All CPU(s) started in SVC mode.
[ 0.155627] devtmpfs: initialized
[ 0.180307] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.182450] pinctrl core: initialized pinctrl subsystem
[ 0.185967] NET: Registered protocol family 16
[ 0.191602] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.213842] cpuidle: using governor ladder
[ 0.243872] cpuidle: using governor menu
[ 0.244270] bcm2709.uart_clock = 3000000
[ 0.247816] No ATAGs?
[ 0.247881] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.247937] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.247997] mailbox: Broadcom VideoCore Mailbox driver
[ 0.248139] bcm2708_vcio: mailbox at f300b880
[ 0.248505] bcm_power: Broadcom power driver
[ 0.248543] bcm_power_open() -> 0
[ 0.248568] bcm_power_request(0, 8)
[ 0.749247] bcm_mailbox_read -> 00000080, 0
[ 0.749279] bcm_power_request -> 0
[ 0.749439] Serial: AMBA PL011 UART driver
[ 0.749589] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 1.269936] console [ttyAMA0] enabled
[ 1.347532] SCSI subsystem initialized
[ 1.351551] usbcore: registered new interface driver usbfs
[ 1.357220] usbcore: registered new interface driver hub
[ 1.362680] usbcore: registered new device driver usb
[ 1.369647] Switched to clocksource arch_sys_counter
[ 1.404498] FS-Cache: Loaded
[ 1.407767] CacheFiles: Loaded
[ 1.423380] NET: Registered protocol family 2
[ 1.429146] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.436403] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.443083] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.449553] TCP: reno registered
[ 1.452830] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.458814] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.465548] NET: Registered protocol family 1
[ 1.470418] RPC: Registered named UNIX socket transport module.
[ 1.476361] RPC: Registered udp transport module.
[ 1.481147] RPC: Registered tcp transport module.
[ 1.485866] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.493322] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counter s available
[ 1.501780] bcm2708_dma: DMA manager at f3007000
[ 1.506592] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000 000(1008 MiB)
[ 1.516579] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 1.523085] audit: initializing netlink subsys (disabled)
[ 1.528556] audit: type=2000 audit(1.299:1): initialized
[ 1.550191] VFS: Disk quotas dquot_6.5.2
[ 1.554518] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.564215] FS-Cache: Netfs 'nfs' registered for caching
[ 1.570498] NFS: Registering the id_resolver key type
[ 1.575628] Key type id_resolver registered
[ 1.579921] Key type id_legacy registered
[ 1.585051] msgmni has been set to 1853
[ 1.590592] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 52)
[ 1.598272] io scheduler noop registered
[ 1.602254] io scheduler deadline registered (default)
[ 1.607743] io scheduler cfq registered
[ 1.614235] BCM2708FB: allocated DMA memory fac00000
[ 1.619251] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 1.652540] Console: switching to colour frame buffer device 222x59
[ 1.676593] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driv er
[ 1.684418] uart-pl011 dev:f1: no DMA platform data
[ 1.689979] vc-cma: Videocore CMA driver
[ 1.693987] vc-cma: vc_cma_base = 0x00000000
[ 1.698780] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.704303] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.721555] brd: module loaded
[ 1.730927] loop: module loaded
[ 1.735047] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ 1.742881] Loading iSCSI transport class v2.0-870.
[ 1.748856] usbcore: registered new interface driver smsc95xx
[ 1.754836] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.961046] Core Release: 2.80a
[ 1.964266] Setting default values for core params
[ 1.969186] Finished setting default values for core params
[ 2.175314] Using Buffer DMA mode
[ 2.178703] Periodic Transfer Interrupt Enhancement - disabled
[ 2.184661] Multiprocessor Interrupt Enhancement - disabled
[ 2.190357] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.194802] Dedicated Tx FIFOs mode
[ 2.198668] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac 14000 dma = 0xfac14000 len=9024
[ 2.208731] FIQ FSM acceleration enabled for :
[ 2.208731] Non-periodic Split Transactions
[ 2.208731] Periodic Split Transactions
[ 2.208731] High-Speed Isochronous Endpoints
[ 2.234727] dwc_otg: Microframe scheduler enabled
[ 2.234805] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x803ea6a0
[ 2.245294] WARN::hcd_init_fiq:413: FIQ ASM at 0x803ea9fc length 36
[ 2.256119] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb80a000
[ 2.266712] dwc_otg bcm2708_usb: DWC OTG Controller
[ 2.276280] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 2.288234] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 2.298390] Init: Port Power? op_state=1
[ 2.306870] Init: Power Port (0)
[ 2.314890] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.326261] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 2.338019] usb usb1: Product: DWC OTG Controller
[ 2.347205] usb usb1: Manufacturer: Linux 3.18.14-v7+ dwc_otg_hcd
[ 2.357785] usb usb1: SerialNumber: bcm2708_usb
[ 2.367743] hub 1-0:1.0: USB hub found
[ 2.376030] hub 1-0:1.0: 1 port detected
[ 2.384828] dwc_otg: FIQ enabled
[ 2.384845] dwc_otg: NAK holdoff enabled
[ 2.384856] dwc_otg: FIQ split-transaction FSM enabled
[ 2.384912] Module dwc_common_port init
[ 2.385286] usbcore: registered new interface driver usb-storage
[ 2.396054] mousedev: PS/2 mouse device common for all mice
[ 2.406723] bcm2835-cpufreq: min=600000 max=900000
[ 2.416269] sdhci: Secure Digital Host Controller Interface driver
[ 2.426961] sdhci: Copyright(c) Pierre Ossman
[ 2.436153] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[ 2.479922] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.496107] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.506857] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.517075] usbcore: registered new interface driver usbhid
[ 2.528246] usbhid: USB HID core driver
[ 2.539041] TCP: cubic registered
[ 2.546930] Initializing XFRM netlink socket
[ 2.556882] NET: Registered protocol family 17
[ 2.568109] Key type dns_resolver registered
[ 2.577314] Registering SWP/SWPB emulation handler
[ 2.579809] Indeed it is in host mode hprt0 = 00021501
[ 2.597103] registered taskstats version 1
[ 2.605950] vc-sm: Videocore shared memory driver
[ 2.615226] [vc_sm_connected_init]: start
[ 2.624551] [vc_sm_connected_init]: end - returning 0
[ 2.635426] Waiting for root device /dev/mmcblk0p6...
[ 2.759765] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.771030] Indeed it is in host mode hprt0 = 00001101
[ 2.980095] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.991364] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.003953] hub 1-1:1.0: USB hub found
[ 3.012382] hub 1-1:1.0: 5 ports detected
[ 3.047548] mmc0: host does not support reading read-only switch, assuming wr ite-enable
[ 3.062545] mmc0: new high speed SDHC card at address b738
[ 3.073235] mmcblk0: mmc0:b738 SD16G 14.9 GiB
[ 3.085825] mmcblk0: p1 p2 < p5 p6 > p3
[ 3.207864] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. O pts: (null)
[ 3.220881] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[ 3.243595] devtmpfs: mounted
[ 3.251748] Freeing unused kernel memory: 396K (80777000 - 807da000)
[ 3.299868] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.410176] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.421859] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
[ 3.436949] smsc95xx v1.0.4
[ 3.503593] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1 .1, smsc95xx USB 2.0 Ethernet, b8:27:eb:1c:af:bb
[ 3.959892] usb 1-1.5: new low-speed USB device number 4 using dwc_otg
[ 4.109876] usb 1-1.5: New USB device found, idVendor=0c40, idProduct=8000
[ 4.122320] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber =0
[ 4.135308] usb 1-1.5: Product: 2.4GHz receiver
[ 4.146319] usb 1-1.5: Manufacturer: ELMCU
[ 4.171464] input: ELMCU 2.4GHz receiver as /devices/platform/bcm2708_usb/usb 1/1-1/1-1.5/1-1.5:1.0/0003:0C40:8000.0001/input/input0
[ 4.189355] hid-generic 0003:0C40:8000.0001: input,hidraw0: USB HID v1.11 Key board [ELMCU 2.4GHz receiver] on usb-bcm2708_usb-1.5/input0
[ 4.226321] input: ELMCU 2.4GHz receiver as /devices/platform/bcm2708_usb/usb 1/1-1/1-1.5/1-1.5:1.1/0003:0C40:8000.0002/input/input1
[ 4.245040] hid-generic 0003:0C40:8000.0002: input,hidraw1: USB HID v1.11 Mou se [ELMCU 2.4GHz receiver] on usb-bcm2708_usb-1.5/input1
[ 4.432392] udevd[176]: starting version 175
[ 4.908533] GPIO $bb8c0000 = 0x24800000
[ 4.963120] GPIO $bb8c0004 = 0x24024
[ 5.011541] * 0xbb8c0000 &= ~ 0xE00000
[ 5.058180] * 0xbb8c0000 | 4 << 0x0015
[ 5.086532] * 0xbb8c0000 &= ~ 0x7000000
[ 5.124990] * 0xbb8c0000 | 4 << 0x0018
[ 5.138688] * 0xbb8c0000 &= ~ 0x38000000
[ 5.150105] * 0xbb8c0000 | 4 << 0x001B
[ 5.169803] * 0xbb8c0004 &= ~ 0x0007
[ 5.186481] * 0xbb8c0004 | 4 << 0x0000
[ 5.196989] * 0xbb8c0004 &= ~ 0x0038
[ 5.207554] * 0xbb8c0004 | 4 << 0x0003
[ 5.220162] GPIO $bb8c0000 = 0x24800000
[ 5.231947] GPIO $bb8c0004 = 0x24024
[ 5.253876] bcm2708_spi 3f204000.spi: DMA channel 2 at address 0xf3007200 wit h irq 77
[ 5.272481] bcm2708_spi 3f204000.spi: DMA channel 4 at address 0xf3007400 wit h irq 20
[ 5.303744] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.323447] fbtft_of_value: buswidth = 8
[ 5.335879] fbtft_of_value: debug = 0
[ 5.347139] fbtft_of_value: rotate = 90
[ 5.357171] fbtft_of_value: fps = 20
[ 5.543965] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video mem ory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
[ 5.561353] bcm2708_spi 3f204000.spi: SPI Controller at 0x3f204000 (irq 80)
[ 5.573732] bcm2708_spi 3f204000.spi: SPI Controller running in dma mode
[ 5.595980] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
[ 6.687635] random: nonblocking pool is initialized
[ 7.003685] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 7.277606] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 7.821972] input: ft6x06_ts as /devices/virtual/input/input2
[ 7.989892] i2c-core: driver [ft6x06_ts] using legacy suspend method
[ 8.001444] i2c-core: driver [ft6x06_ts] using legacy resume method
[ 12.442946] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 13.910860] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE 1
[ 16.718483] cfg80211: Calling CRDA to update world regulatory domain
[ 17.463227] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:1 02396k SSFS
[ 124.620702] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. O pts: (null)
pi@raspberrypi ~ $ FRAMEBUFFER=/dev/fb1 startx &
[1] 2351
pi@raspberrypi ~ $
X.Org X Server 1.12.4
Release Date: 2012-08-27
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.2.0-2-mx5 armv7l Debian
Current Operating System: Linux raspberrypi 3.18.14-v7+ #2 SMP PREEMPT Thu May 2 8 18:17:59 UTC 2015 armv7l
Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1776 bcm2708_fb.fbhe ight=952 bcm2709.boardrev=0xa21041 bcm2709.serial=0xf71cafbb smsc95xx.macaddr=B8 :27:EB:1C:AF:BB bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_ac tive_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc _mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tt y1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
Build Date: 11 February 2015 09:31:17PM
xorg-server 2:1.12.4-6+deb7u6 (Julien Cristau <[email protected]>)
Current version of pixman: 0.33.1
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Aug 30 15:15:19 2015
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
[1] 2349
pi@raspberrypi ~ $ xauth: file /home/pi/.Xauthority does not exist
Current Operating System: Linux raspberrypi 3.18.8-v7+ #2 SMP PREEMPT Mon Mar 9 14:11:05 UTC 2015 armv7l
Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbhe ight=984 bcm2709.boardrev=0xa21041 bcm2709.serial=0xf71cafbb smsc95xx.macaddr=B8 :27:EB:1C:AF:BB bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_ac tive_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc _mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tt y1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait fbcon=map:10 f bcon=font:VGA8x8
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Aug 31 11:05:58 2015
[ 0.000000] Linux version 3.18.8-v7+ (root@vagrant-ubuntu-precise-32) (gcc version 4.8.3 20140106 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.01 - Linaro GCC 2013.11) ) #2 SMP PREEMPT Mon Mar 9 14:11:05 UTC 2015
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] free_area_init_node: node 0, pgdat 80834a00, node_mem_map ba093000
[ 0.000000] PERCPU: Embedded 10 pages/cpu @ba060000 s12224 r8192 d20544 u40960
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239776
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2709.boardrev=0xa21041 bcm2709.serial=0xf71cafbb smsc95xx.macaddr=B8:27:EB:1C:AF:BB bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait fbcon=map:10 fbcon=font:VGA8x8
[ 0.000000] Memory: 940672K/966656K available (5828K kernel code, 403K rwdata, 1776K rodata, 392K init, 772K bss, 25984K reserved)
[ 0.000000] .text : 0x80008000 - 0x807754b4 (7606 kB)
[ 0.000000] .init : 0x80776000 - 0x807d8000 ( 392 kB)
[ 0.000000] .data : 0x807d8000 - 0x8083cd6c ( 404 kB)
[ 0.000000] .bss : 0x8083cd6c - 0x808fde94 ( 773 kB)
[ 0.000013] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000037] Switching to timer-based delay loop, resolution 52ns
[ 0.000336] Console: colour dummy device 80x30
[ 0.001828] console [tty1] enabled
[ 0.001879] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001961] pid_max: default: 32768 minimum: 301
[ 0.002387] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002448] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.003740] Initializing cgroup subsys memory
[ 0.003828] Initializing cgroup subsys devices
[ 0.003881] Initializing cgroup subsys freezer
[ 0.003934] Initializing cgroup subsys net_cls
[ 0.003999] Initializing cgroup subsys blkio
[ 0.004114] CPU: Testing write buffer coherency: ok
[ 0.004226] ftrace: allocating 20136 entries in 60 pages
[ 0.054109] CPU0: update cpu_capacity 1024
[ 0.054188] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.054226] [bcm2709_smp_prepare_cpus] enter
[ 0.054392] Setting up static identity map for 0x540a38 - 0x540a90
[ 0.114047] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.114365] CPU1: Booted secondary processor
[ 0.114372] [bcm2709_secondary_init] enter cpu:1
[ 0.114425] CPU1: update cpu_capacity 1024
[ 0.114434] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.134018] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.134266] CPU2: Booted secondary processor
[ 0.134273] [bcm2709_secondary_init] enter cpu:2
[ 0.134304] CPU2: update cpu_capacity 1024
[ 0.134312] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.154084] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.154319] CPU3: Booted secondary processor
[ 0.154326] [bcm2709_secondary_init] enter cpu:3
[ 0.154360] CPU3: update cpu_capacity 1024
[ 0.154368] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.154467] Brought up 4 CPUs
[ 0.154588] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.154622] CPU: All CPU(s) started in SVC mode.
[ 0.155659] devtmpfs: initialized
[ 0.181050] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.183209] pinctrl core: initialized pinctrl subsystem
[ 0.186909] NET: Registered protocol family 16
[ 0.192595] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.213874] cpuidle: using governor ladder
[ 0.243904] cpuidle: using governor menu
[ 0.244355] bcm2709.uart_clock = 3000000
[ 0.247843] No ATAGs?
[ 0.247909] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.247965] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.248023] mailbox: Broadcom VideoCore Mailbox driver
[ 0.248160] bcm2708_vcio: mailbox at f300b880
[ 0.248545] bcm_power: Broadcom power driver
[ 0.248582] bcm_power_open() -> 0
[ 0.248609] bcm_power_request(0, 8)
[ 0.749289] bcm_mailbox_read -> 00000080, 0
[ 0.749320] bcm_power_request -> 0
[ 0.749465] Serial: AMBA PL011 UART driver
[ 0.749616] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 1.271860] console [ttyAMA0] enabled
[ 1.347544] SCSI subsystem initialized
[ 1.351556] usbcore: registered new interface driver usbfs
[ 1.357225] usbcore: registered new interface driver hub
[ 1.362682] usbcore: registered new device driver usb
[ 1.369709] Switched to clocksource arch_sys_counter
[ 1.405245] FS-Cache: Loaded
[ 1.408507] CacheFiles: Loaded
[ 1.424169] NET: Registered protocol family 2
[ 1.429988] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.437203] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.443892] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.450389] TCP: reno registered
[ 1.453639] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.459622] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.466368] NET: Registered protocol family 1
[ 1.471224] RPC: Registered named UNIX socket transport module.
[ 1.477165] RPC: Registered udp transport module.
[ 1.481951] RPC: Registered tcp transport module.
[ 1.486670] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.494176] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 1.502619] bcm2708_dma: DMA manager at f3007000
[ 1.507415] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.517474] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 1.523976] audit: initializing netlink subsys (disabled)
[ 1.529445] audit: type=2000 audit(1.299:1): initialized
[ 1.551289] VFS: Disk quotas dquot_6.5.2
[ 1.555609] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.565348] FS-Cache: Netfs 'nfs' registered for caching
[ 1.571631] NFS: Registering the id_resolver key type
[ 1.576759] Key type id_resolver registered
[ 1.581054] Key type id_legacy registered
[ 1.586195] msgmni has been set to 1853
[ 1.591718] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.599338] io scheduler noop registered
[ 1.603319] io scheduler deadline registered (default)
[ 1.608806] io scheduler cfq registered
[ 1.615299] BCM2708FB: allocated DMA memory fac00000
[ 1.620344] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 1.656143] Console: switching to colour frame buffer device 228x123
[ 1.682034] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 1.689821] uart-pl011 dev:f1: no DMA platform data
[ 1.695321] vc-cma: Videocore CMA driver
[ 1.699296] vc-cma: vc_cma_base = 0x00000000
[ 1.704104] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.709562] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.727247] brd: module loaded
[ 1.736586] loop: module loaded
[ 1.740186] vchiq: vchiq_init_state: slot_zero = 0xba800000, is_master = 0
[ 1.747990] Loading iSCSI transport class v2.0-870.
[ 1.753988] usbcore: registered new interface driver smsc95xx
[ 1.759921] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.966061] Core Release: 2.80a
[ 1.969254] Setting default values for core params
[ 1.974175] Finished setting default values for core params
[ 2.180269] Using Buffer DMA mode
[ 2.183631] Periodic Transfer Interrupt Enhancement - disabled
[ 2.189523] Multiprocessor Interrupt Enhancement - disabled
[ 2.195175] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.199588] Dedicated Tx FIFOs mode
[ 2.203489] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 2.213479] FIQ FSM acceleration enabled for :
[ 2.213479] Non-periodic Split Transactions
[ 2.213479] Periodic Split Transactions
[ 2.213479] High-Speed Isochronous Endpoints
[ 2.230355] dwc_otg: Microframe scheduler enabled
[ 2.230422] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x803e9a8c
[ 2.236414] WARN::hcd_init_fiq:413: FIQ ASM at 0x803e9de8 length 36
[ 2.242753] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb80a000
[ 2.248859] dwc_otg bcm2708_usb: DWC OTG Controller
[ 2.253853] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 2.261212] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 2.266802] Init: Port Power? op_state=1
[ 2.270792] Init: Power Port (0)
[ 2.274342] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.281236] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.288536] usb usb1: Product: DWC OTG Controller
[ 2.293316] usb usb1: Manufacturer: Linux 3.18.8-v7+ dwc_otg_hcd
[ 2.299392] usb usb1: SerialNumber: bcm2708_usb
[ 2.304971] hub 1-0:1.0: USB hub found
[ 2.308830] hub 1-0:1.0: 1 port detected
[ 2.313352] dwc_otg: FIQ enabled
[ 2.313366] dwc_otg: NAK holdoff enabled
[ 2.313377] dwc_otg: FIQ split-transaction FSM enabled
[ 2.313419] Module dwc_common_port init
[ 2.313811] usbcore: registered new interface driver usb-storage
[ 2.320248] mousedev: PS/2 mouse device common for all mice
[ 2.326601] bcm2835-cpufreq: min=600000 max=900000
[ 2.331840] sdhci: Secure Digital Host Controller Interface driver
[ 2.338090] sdhci: Copyright(c) Pierre Ossman
[ 2.342744] DMA channels allocated for the MMC driver
[ 2.379758] Load BCM2835 MMC driver
[ 2.383782] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.397634] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.404020] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.409827] usbcore: registered new interface driver usbhid
[ 2.416540] usbhid: USB HID core driver
[ 2.420911] TCP: cubic registered
[ 2.424343] Initializing XFRM netlink socket
[ 2.429881] NET: Registered protocol family 17
[ 2.436721] Key type dns_resolver registered
[ 2.441672] Registering SWP/SWPB emulation handler
[ 2.447538] registered taskstats version 1
[ 2.452002] vc-sm: Videocore shared memory driver
[ 2.456771] [vc_sm_connected_init]: start
[ 2.461588] [vc_sm_connected_init]: end - returning 0
[ 2.467921] Waiting for root device /dev/mmcblk0p2...
[ 2.509864] Indeed it is in host mode hprt0 = 00021501
[ 2.689791] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.696477] Indeed it is in host mode hprt0 = 00001101
[ 2.900090] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.906881] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.907639] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.910038] mmc0: new high speed SDHC card at address b738
[ 2.914363] mmcblk0: mmc0:b738 SD16G 14.9 GiB
[ 2.923775] mmcblk0: p1 p2
[ 2.936086] hub 1-1:1.0: USB hub found
[ 2.940062] hub 1-1:1.0: 5 ports detected
[ 3.032882] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.041414] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.049583] devtmpfs: mounted
[ 3.053424] Freeing unused kernel memory: 392K (80776000 - 807d8000)
[ 3.219941] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.340169] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.347165] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.357656] smsc95xx v1.0.4
[ 3.424211] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:1c:af:bb
[ 3.889976] usb 1-1.5: new low-speed USB device number 4 using dwc_otg
[ 4.040726] usb 1-1.5: New USB device found, idVendor=0c40, idProduct=8000
[ 4.054533] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.072972] usb 1-1.5: Product: 2.4GHz receiver
[ 4.084491] usb 1-1.5: Manufacturer: ELMCU
[ 4.112312] input: ELMCU 2.4GHz receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:0C40:8000.0001/input/input0
[ 4.131466] hid-generic 0003:0C40:8000.0001: input,hidraw0: USB HID v1.11 Keyboard [ELMCU 2.4GHz receiver] on usb-bcm2708_usb-1.5/input0
[ 4.175124] udevd[176]: starting version 175
[ 4.176154] input: ELMCU 2.4GHz receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:0C40:8000.0002/input/input1
[ 4.176985] hid-generic 0003:0C40:8000.0002: input,hidraw1: USB HID v1.11 Mouse [ELMCU 2.4GHz receiver] on usb-bcm2708_usb-1.5/input1
[ 4.707680] GPIO $bb8d0000 = 0x24800000
[ 4.732137] GPIO $bb8d0004 = 0x24024
[ 4.774659] * 0xbb8d0000 &= ~ 0xE00000
[ 4.791176] * 0xbb8d0000 | 4 << 0x0015
[ 4.806856] * 0xbb8d0000 &= ~ 0x7000000
[ 4.821456] * 0xbb8d0000 | 4 << 0x0018
[ 4.833608] * 0xbb8d0000 &= ~ 0x38000000
[ 4.845356] * 0xbb8d0000 | 4 << 0x001B
[ 4.858375] * 0xbb8d0004 &= ~ 0x0007
[ 4.870626] * 0xbb8d0004 | 4 << 0x0000
[ 4.887214] * 0xbb8d0004 &= ~ 0x0038
[ 4.902193] * 0xbb8d0004 | 4 << 0x0003
[ 4.918244] GPIO $bb8d0000 = 0x24800000
[ 4.933138] GPIO $bb8d0004 = 0x24024
[ 4.956523] bcm2708_spi 3f204000.spi: DMA channel 2 at address 0xf3007200 with irq 77
[ 5.021796] bcm2708_spi 3f204000.spi: DMA channel 4 at address 0xf3007400 with irq 20
[ 5.077976] stmpe-spi spi0.1: unknown chip id: 0x0
[ 5.104393] stmpe-spi: probe of spi0.1 failed with error -22
[ 5.135740] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.158335] fbtft_of_value: buswidth = 8
[ 5.170230] fbtft_of_value: debug = 0
[ 5.181294] fbtft_of_value: rotate = 90
[ 5.192109] fbtft_of_value: fps = 20
[ 5.437780] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
[ 5.452896] bcm2708_spi 3f204000.spi: SPI Controller at 0x3f204000 (irq 80)
[ 5.461557] bcm2708_spi 3f204000.spi: SPI Controller running in dma mode
[ 5.470425] bcm2708_i2c_init_pinmode(1,2)
[ 5.477259] bcm2708_i2c_init_pinmode(1,3)
[ 5.484937] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
[ 6.220119] random: nonblocking pool is initialized
[ 6.865154] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.110288] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 12.743120] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 14.203299] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[ 17.874612] Adding 102396k swap on /var/swap. Priority:-1 extents:8 across:545280k SSFS
What do you mean by reseating?adafruit2 wrote:try loosening the two black 'ears', then reseating the flex, and then pushing back both ears at once.
I tried that but the pins still seem to sit out a bit as in the previous pictueadafruit2 wrote:pull on the flex a little and then push it into the connector again
http://pcsupport.about.com/od/termsr/g/reseat.htm
