Diffused Digital RGB LED Pixels
Postby rustyjuggler » Fri Jun 24, 2011 11:37 am
I have bought the pixel strands:
http://www.adafruit.com/products/322
And I am looking at the tutorial for how to connect it to the Arduino.
My question is can I use the switching power supply that I also bought from you to power both the Arduino and the LED strip?
Would I then connect the 5V power directly to the 5V pin of the Arduino?
I would like to only have one power supply for my circuit.
rustyjuggler
Re: Diffused Digital RGB LED Pixels
Postby adafruit » Fri Jun 24, 2011 11:41 am
yup! that would work - but you have to be careful, make sure you connect it to 5V and not the Vin or 3V pin!
Postby rustyjuggler » Fri Jun 24, 2011 3:14 pm
Thanks, will it work even when I am connecting in to the computer through the USB cabel? Will it connect the correct power or will I have to disconnect the power then?
rustyjuggler
Postby rustyjuggler » Mon Aug 01, 2011 1:19 pm
Another question regarding this power supply. I should use some cap with the power supply? Or will the cap already on the Arduino work in this case as well?
rustyjuggler
Postby adafruit » Mon Aug 01, 2011 6:30 pm
adding a 470uF-2200uF cap might not hurt!
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
Users browsing this forum: No registered users and 4 guests
New Products [102]
LEDs[108]
Cables[60]
Prototyping[69]
