Adalight support in Boblight via Atmolight
Re: Adalight support in Boblight via Atmolight
by F0x123 on Tue Jul 03, 2012 7:04 pm
GsJosh wrote:What a pity this doesn't work on Windows yet! I have indeed seen the 1.3b1 deamon and it works very well on Windows. Unfortunately, the XBMC add-on (which is exactly what I will need) does not work with the newest version of the deamon!
Does anybody have another good solution to get this working smoothly under FullHD? I have already tried lightpack, but it doesn't run supersmooth either. For more information on this, see the lightpack topic.
Arduino Uno
50x ws8201
Asus E35M1-I DELUXE
Windows 7
XBMC
exact the same setup and problem. lightpack causes tearing in movies and low performance in UI.
boblight causes stuttering in HD movies.
atmolight does not work correctly because I dont know how to configure the pde file and atmowin software.....
if you have any solution for this setup, please let me know. thnx.
F0x123
by redocili on Thu Jul 05, 2012 12:04 pm
Arduino Uno
50x ws8201
Asus E35M1-I DELUXE
Windows 7
XBMC
you can try this:
viewtopic.php?f=25&t=27746
pls report if all works fine!
redocili
by F0x123 on Sat Jul 07, 2012 9:00 pm
hi, thank you. I tried this and managed to get it to work with me setup but I still have to use fullscreen window instead of true fullscreen in xbmc and thus I got tearing during playback and a lower performance during xbmc gui. Is there any fix for that?
any atmowin xbmc plugin or setting to fix this tearing. It seems that aero turned off causes this tearing.
F0x123
by zwickl on Sun Jul 29, 2012 7:43 am
Hello there,
first of all: Thank you for your script, it brought me way nearer to a possible Ambilight solution, as most other scripts are based on the WS2801 IC, but I'm fighting around here with a 50 LED String LPD6803 IC.
My setup:
- Arduino Duemilanove
- Mac OS X (boblightd built from the source (without portaudio, opengl, x11, prefix=/usr)
- 50 RGB LED Strip with LPD6803 IC
- PIN 11 is Data, PIN 13 clk (as also defined in the fastSPI lib), 5V 3A current connected, GND as well
(*.INO, boblightd debug dump & my boblight.config can be found at the end of the topic)
So INO compiles, boblightd connects to Arduino, but I have 3-5 LED's flickering wildly (LED21,22,24,25). When I start XBMC with boblight addon the "rainbow" when finding the daemon is in false colors. The LED's are updated when playing a movie, but again flikering (half of them) and false colors.
Do you have any suggestions ? I came so close and my gf is slowly starting rage mode as I'm spending so much time with the Ambilight Solution ;)
Thank you in advance,
Christian
arduino_atmo_boblight.zip
(39.3 KiB) Downloaded 226 times
zwickl
by GsJosh on Tue Oct 16, 2012 3:10 pm
I've got Adalight working with boblight under Windows 7!
I just thought I would mention it here since there were several people trying to get this working.
When you try to use the latest windows version of boblight from the official site, you come to the conclusion that it doesn't work with the XBMC boblight plugin. Rather annoying. So I had to use an older version of boblight.
Since this week I have a new setup (switched to intel) and I have the following working:
Adalight (WS2801 + Arduino UNO)
boblight 1.3
XBMC
XBMC boblight plugin (1.0.3 I believe, the latest at the moment)
It's running very smooth, no impact on video whatsoever, absolutely loving it. Here's what I used:
1. I uploaded this slightly modified LEDstream.pde, earlier posted here to my UNO.
2. Then downloaded this boblight version for windows, no idea who compiled this, but whatever.
3. Here is my boblight.conf file, I created it with this calculator (GREAT TOOL!), you might need to change your com port number:
[global]
interface   127.0.0.1
port      19333
[device]
name      ambilight
output      /dev/com3
channels        150
type            atmo
interval        10000
prefix          FF
rate            115200
[color]
name      red
rgb      FF0000
gamma      1
adjust      1
blacklevel      0
[color]
name      green
rgb      00FF00
gamma      1
adjust      1
blacklevel      0
[color]
name      blue
rgb      0000FF
gamma      1
adjust      0.6
blacklevel      0
[light]
name            50
color           red     ambilight 148
color           green   ambilight 149
color           blue    ambilight 150
hscan           38.91 44.46
vscan           90.91 100
4. Since this older version of boblight doesn't seem to be able to reach the com-port by itself, it needs a little help. (in my case) So you either need to start Arduino and do a "Serial Status" check, or you need to run the newer version of boblight first to 'activate' the com port. I really don't know why but here is how I solved it:
5. I wrote a batch file that looks like this:
start "boblightd" /MIN C:\boblightd\launchfirst_boblight-1.3-beta1\boblightd.exe -c C:\boblightd\launchfirst_boblight-1.3-beta1\boblight.conf -f
TIMEOUT /T 1
taskkill /im boblightd.exe
start "boblightd" /MIN C:\boblightd\boblightd.exe -c c:\boblightd\boblight.conf -f
ps1. This German website (via Google translate) has some interesting information.
ps. the files from this site don't really work for me... Seems to be a different version of boblight.
GsJosh
by gannicus on Tue Nov 20, 2012 10:54 am
GsJosh wrote:I've got Adalight working with boblight under Windows 7!
boblight 1.3
XBMC
[global]
interface   127.0.0.1
port      19333
[device]
name      ambilight
output      /dev/com3
channels        150
type            atmo
interval        10000
prefix          FF
rate            115200
[color]
name      red
rgb      FF0000
gamma      1
adjust      1
blacklevel      0
[color]
name      green
rgb      00FF00
gamma      1
adjust      1
blacklevel      0
[color]
name      blue
rgb      0000FF
gamma      1
adjust      0.6
blacklevel      0
[light]
name            50
hscan           38.91 44.46
vscan           90.91 100
TIMEOUT /T 1
Did all this GsJosh, and for once, XBMC connects to boblight. That's the good news. The bad news is, nothing is happening inside xbmc. The lights do their test pattern after I run the batch file, but that's it. All the connections are made in the batch file window, everything says hello etc.
I've got the com# correctly changed for my setup. What could be the problem here? I've tried everything.
gannicus
by gannicus on Tue Nov 20, 2012 11:08 am
Here is the copy of my boblight.conf file as well. This is a 100 LED array, and I used that website you linked to generate it.
Then made the changes you suggested.
#[global]
interface   127.0.0.1
port      19333
[device]
name      ambilight
output   /dev/com3
channels   768
type      atmo
interval   10000
prefix   FF
rate      115200
[color]
name      red
rgb         FF0000
gamma      1.0
adjust      1.0
blacklevel   0.0
[color]
name      green
rgb         00FF00
gamma      1.0
adjust      1.0
blacklevel   0.0
[color]
name      blue
rgb         0000FF
gamma      1.0
adjust      1.0
blacklevel   0.0
[light]
name      Left1
color      green    ambilight 2
color      blue    ambilight 3
hscan      0 10
vscan      90 95
[light]
name      Left2
color      red    ambilight 4
color      green    ambilight 5
color      blue    ambilight 6
hscan      0 10
vscan      86 90
[light]
name      Left3
color      red    ambilight 7
color      green    ambilight 8
color      blue    ambilight 9
hscan      0 10
vscan      81 86
[light]
name      Left4
color      red    ambilight 10
color      green    ambilight 11
color      blue    ambilight 12
hscan      0 10
vscan      77 81
[light]
name      Left5
color      red    ambilight 13
hscan      0 10
vscan      72 77
[light]
name      Left6
color      red    ambilight 16
color      green    ambilight 17
color      blue    ambilight 18
hscan      0 10
vscan      68 72
[light]
name      Left7
color      red    ambilight 19
color      green    ambilight 20
color      blue    ambilight 21
hscan      0 10
vscan      63 68
[light]
name      Left8
color      red    ambilight 22
color      green    ambilight 23
color      blue    ambilight 24
hscan      0 10
vscan      59 63
[light]
name      Left9
color      red    ambilight 25
color      green    ambilight 26
color      blue    ambilight 27
hscan      0 10
vscan      54 59
[light]
name      Left10
color      red    ambilight 28
color      green    ambilight 29
color      blue    ambilight 30
hscan      0 10
vscan      50 54
[light]
name      Left11
color      red    ambilight 31
color      green    ambilight 32
color      blue    ambilight 33
hscan      0 10
vscan      45 50
[light]
name      Left12
color      red    ambilight 34
color      green    ambilight 35
color      blue    ambilight 36
hscan      0 10
vscan      40 45
[light]
name      Left13
color      red    ambilight 37
color      green    ambilight 38
color      blue    ambilight 39
hscan      0 10
vscan      36 40
[light]
name      Left14
color      red    ambilight 40
color      green    ambilight 41
color      blue    ambilight 42
hscan      0 10
vscan      31 36
[light]
name      Left15
color      red    ambilight 43
color      green    ambilight 44
color      blue    ambilight 45
hscan      0 10
vscan      27 31
[light]
name      Left16
color      red    ambilight 46
color      green    ambilight 47
color      blue    ambilight 48
hscan      0 10
vscan      22 27
[light]
name      Left17
color      red    ambilight 49
color      green    ambilight 50
color      blue    ambilight 51
hscan      0 10
vscan      18 22
[light]
name      Left18
color      red    ambilight 52
color      green    ambilight 53
color      blue    ambilight 54
hscan      0 10
vscan      13 18
[light]
name      Left19
color      red    ambilight 55
color      green    ambilight 56
color      blue    ambilight 57
hscan      0 10
vscan      9 13
[light]
name      Left20
color      red    ambilight 58
color      green    ambilight 59
color      blue    ambilight 60
hscan      0 10
vscan      4 9
[light]
name      Left21
color      red    ambilight 61
color      green    ambilight 62
color      blue    ambilight 63
hscan      0 10
vscan      0 4
[light]
name      Top1
color      red    ambilight 64
color      green    ambilight 65
color      blue    ambilight 66
hscan      3 6
vscan      0 20
[light]
name      Top2
color      red    ambilight 67
color      green    ambilight 68
color      blue    ambilight 69
hscan      6 10
vscan      0 20
[light]
name      Top3
color      red    ambilight 70
color      green    ambilight 71
color      blue    ambilight 72
hscan      10 13
vscan      0 20
[light]
name      Top4
color      red    ambilight 73
color      green    ambilight 74
color      blue    ambilight 75
hscan      13 16
vscan      0 20
[light]
name      Top5
color      red    ambilight 76
color      green    ambilight 77
color      blue    ambilight 78
hscan      16 20
vscan      0 20
[light]
name      Top6
color      red    ambilight 79
color      green    ambilight 80
color      blue    ambilight 81
hscan      20 23
vscan      0 20
[light]
name      Top7
color      red    ambilight 82
color      green    ambilight 83
color      blue    ambilight 84
hscan      23 26
vscan      0 20
[light]
name      Top8
color      red    ambilight 85
color      green    ambilight 86
color      blue    ambilight 87
hscan      26 30
vscan      0 20
[light]
name      Top9
color      red    ambilight 88
color      green    ambilight 89
color      blue    ambilight 90
hscan      30 33
vscan      0 20
[light]
name      Top10
color      red    ambilight 91
color      green    ambilight 92
color      blue    ambilight 93
hscan      33 36
vscan      0 20
[light]
name      Top11
color      red    ambilight 94
color      green    ambilight 95
color      blue    ambilight 96
hscan      36 40
vscan      0 20
[light]
name      Top12
color      red    ambilight 97
color      green    ambilight 98
color      blue    ambilight 99
hscan      40 43
vscan      0 20
[light]
name      Top13
color      red    ambilight 100
color      green    ambilight 101
color      blue    ambilight 102
hscan      43 46
vscan      0 20
[light]
name      Top14
color      red    ambilight 103
color      green    ambilight 104
color      blue    ambilight 105
hscan      46 50
vscan      0 20
[light]
name      Top15
color      red    ambilight 106
color      green    ambilight 107
color      blue    ambilight 108
hscan      50 53
vscan      0 20
[light]
name      Top16
color      red    ambilight 109
color      green    ambilight 110
color      blue    ambilight 111
hscan      53 56
vscan      0 20
[light]
name      Top17
color      red    ambilight 112
color      green    ambilight 113
color      blue    ambilight 114
hscan      56 60
vscan      0 20
[light]
name      Top18
color      red    ambilight 115
color      green    ambilight 116
color      blue    ambilight 117
hscan      60 63
vscan      0 20
[light]
name      Top19
color      red    ambilight 118
color      green    ambilight 119
color      blue    ambilight 120
hscan      63 66
vscan      0 20
[light]
name      Top20
color      red    ambilight 121
color      green    ambilight 122
color      blue    ambilight 123
hscan      66 70
vscan      0 20
[light]
name      Top21
color      red    ambilight 124
color      green    ambilight 125
color      blue    ambilight 126
hscan      70 73
vscan      0 20
[light]
name      Top22
color      red    ambilight 127
color      green    ambilight 128
color      blue    ambilight 129
hscan      73 76
vscan      0 20
[light]
name      Top23
color      red    ambilight 130
color      green    ambilight 131
color      blue    ambilight 132
hscan      76 80
vscan      0 20
[light]
name      Top24
color      red    ambilight 133
color      green    ambilight 134
color      blue    ambilight 135
hscan      80 83
vscan      0 20
[light]
name      Top25
color      red    ambilight 136
color      green    ambilight 137
color      blue    ambilight 138
hscan      83 86
vscan      0 20
[light]
name      Top26
color      red    ambilight 139
color      green    ambilight 140
color      blue    ambilight 141
hscan      86 90
vscan      0 20
[light]
name      Top27
color      red    ambilight 142
color      green    ambilight 143
color      blue    ambilight 144
hscan      90 93
vscan      0 20
[light]
name      Top28
color      red    ambilight 145
color      green    ambilight 146
color      blue    ambilight 147
hscan      93 96
vscan      0 20
[light]
name      Top29
hscan      96 100
vscan      0 20
[light]
name      Right1
color      red    ambilight 151
color      green    ambilight 152
color      blue    ambilight 153
hscan      90 100
vscan      4 9
[light]
name      Right2
color      red    ambilight 154
color      green    ambilight 155
color      blue    ambilight 156
hscan      90 100
vscan      9 13
[light]
name      Right3
color      red    ambilight 157
color      green    ambilight 158
color      blue    ambilight 159
hscan      90 100
vscan      13 18
[light]
name      Right4
color      red    ambilight 160
color      green    ambilight 161
color      blue    ambilight 162
hscan      90 100
vscan      18 22
[light]
name      Right5
color      red    ambilight 163
color      green    ambilight 164
color      blue    ambilight 165
hscan      90 100
vscan      22 27
[light]
name      Right6
color      red    ambilight 166
color      green    ambilight 167
color      blue    ambilight 168
hscan      90 100
vscan      27 31
[light]
name      Right7
color      red    ambilight 169
color      green    ambilight 170
color      blue    ambilight 171
hscan      90 100
vscan      31 36
[light]
name      Right8
color      red    ambilight 172
color      green    ambilight 173
color      blue    ambilight 174
hscan      90 100
vscan      36 40
[light]
name      Right9
color      red    ambilight 175
color      green    ambilight 176
color      blue    ambilight 177
hscan      90 100
vscan      40 45
[light]
name      Right10
color      red    ambilight 178
color      green    ambilight 179
color      blue    ambilight 180
hscan      90 100
vscan      45 50
[light]
name      Right11
color      red    ambilight 181
color      green    ambilight 182
color      blue    ambilight 183
hscan      90 100
vscan      50 54
[light]
name      Right12
color      red    ambilight 184
color      green    ambilight 185
color      blue    ambilight one eight six
hscan      90 100
vscan      54 59
[light]
name      Right13
color      red    ambilight 187
color      green    ambilight 188
color      blue    ambilight 189
hscan      90 100
vscan      59 63
[light]
name      Right14
color      red    ambilight 190
color      green    ambilight 191
color      blue    ambilight 192
hscan      90 100
vscan      63 68
[light]
name      Right15
color      red    ambilight 193
color      green    ambilight 194
color      blue    ambilight 195
hscan      90 100
vscan      68 72
[light]
name      Right16
color      red    ambilight 196
color      green    ambilight 197
color      blue    ambilight 198
hscan      90 100
vscan      72 77
[light]
name      Right17
color      red    ambilight 199
color      green    ambilight 200
color      blue    ambilight 201
hscan      90 100
vscan      77 81
[light]
name      Right18
color      red    ambilight 202
color      green    ambilight 203
color      blue    ambilight 204
hscan      90 100
vscan      81 86
[light]
name      Right19
color      red    ambilight 205
color      green    ambilight 206
color      blue    ambilight 207
hscan      90 100
vscan      86 90
[light]
name      Right20
color      red    ambilight 208
color      green    ambilight 209
color      blue    ambilight 210
hscan      90 100
vscan      90 95
[light]
name      Right21
color      red    ambilight 211
color      green    ambilight 212
color      blue    ambilight 213
hscan      90 100
vscan      95 100
[light]
name      SubRight1
color      red    ambilight 214
color      green    ambilight 215
color      blue    ambilight 216
hscan      93 96
vscan      80 100
[light]
name      SubRight2
color      red    ambilight 217
color      green    ambilight 218
color      blue    ambilight 219
hscan      90 93
vscan      80 100
[light]
name      SubRight3
color      red    ambilight 220
color      green    ambilight 221
color      blue    ambilight 222
hscan      86 90
vscan      80 100
[light]
name      SubRight4
color      red    ambilight 223
color      green    ambilight 224
color      blue    ambilight 225
hscan      83 86
vscan      80 100
[light]
name      SubRight5
color      red    ambilight 226
color      green    ambilight 227
color      blue    ambilight 228
hscan      80 83
vscan      80 100
[light]
name      SubRight6
color      red    ambilight 229
color      green    ambilight 230
color      blue    ambilight 231
hscan      76 80
vscan      80 100
[light]
name      SubRight7
color      red    ambilight 232
color      green    ambilight 233
color      blue    ambilight 234
hscan      73 76
vscan      80 100
[light]
name      SubRight8
color      red    ambilight 235
color      green    ambilight 236
color      blue    ambilight 237
hscan      70 73
vscan      80 100
[light]
name      SubRight9
color      red    ambilight 238
color      green    ambilight 239
color      blue    ambilight 240
hscan      66 70
vscan      80 100
[light]
name      SubRight10
color      red    ambilight 241
color      green    ambilight 242
color      blue    ambilight 243
hscan      63 66
vscan      80 100
[light]
name      SubRight11
color      red    ambilight 244
color      green    ambilight 245
color      blue    ambilight 246
hscan      60 63
vscan      80 100
[light]
name      SubRight12
color      red    ambilight 247
color      green    ambilight 248
color      blue    ambilight 249
hscan      56 60
vscan      80 100
[light]
name      SubRight13
color      red    ambilight 250
color      green    ambilight 251
color      blue    ambilight 252
hscan      53 56
vscan      80 100
[light]
name      SubRight14
color      red    ambilight 253
color      green    ambilight 254
color      blue    ambilight 255
hscan      50 53
vscan      80 100
[light]
name      SubLeft1
color      red    ambilight 256
color      green    ambilight 257
color      blue    ambilight 258
hscan      46 50
vscan      80 100
[light]
name      SubLeft2
color      red    ambilight 259
color      green    ambilight 260
color      blue    ambilight 261
hscan      43 46
vscan      80 100
[light]
name      SubLeft3
color      red    ambilight 262
color      green    ambilight 263
color      blue    ambilight 264
hscan      40 43
vscan      80 100
[light]
name      SubLeft4
color      red    ambilight 265
color      green    ambilight 266
color      blue    ambilight 267
hscan      36 40
vscan      80 100
[light]
name      SubLeft5
color      red    ambilight 268
color      green    ambilight 269
color      blue    ambilight 270
hscan      33 36
vscan      80 100
[light]
name      SubLeft6
color      red    ambilight 271
color      green    ambilight 272
color      blue    ambilight 273
hscan      30 33
vscan      80 100
[light]
name      SubLeft7
color      red    ambilight 274
color      green    ambilight 275
color      blue    ambilight 276
hscan      26 30
vscan      80 100
[light]
name      SubLeft8
color      red    ambilight 277
color      green    ambilight 278
color      blue    ambilight 279
hscan      23 26
vscan      80 100
[light]
name      SubLeft9
color      red    ambilight 280
color      green    ambilight 281
color      blue    ambilight 282
hscan      20 23
vscan      80 100
[light]
name      SubLeft10
color      red    ambilight 283
color      green    ambilight 284
color      blue    ambilight 285
hscan      16 20
vscan      80 100
[light]
name      SubLeft11
color      red    ambilight 286
color      green    ambilight 287
color      blue    ambilight 288
hscan      13 16
vscan      80 100
[light]
name      SubLeft12
color      red    ambilight 289
color      green    ambilight 290
color      blue    ambilight 291
hscan      10 13
vscan      80 100
[light]
name      SubLeft13
color      red    ambilight 292
color      green    ambilight 293
color      blue    ambilight 294
hscan      6 10
vscan      80 100
[light]
name      SubLeft14
color      red    ambilight 295
color      green    ambilight 296
color      blue    ambilight 297
hscan      3 6
vscan      80 100
[light]
name      SubLeft15
color      red    ambilight 298
color      green    ambilight 299
color      blue    ambilight 300
hscan      0 3
vscan      80 100
gannicus
by demmax2004 on Fri Nov 30, 2012 2:50 am
Only Windows users.
The best for Windows.
Adalight supported in the Server IR 2.0.9 Ambilight Edition, all the details HERE
demmax2004
by demmax2004 on Mon Dec 10, 2012 9:25 am
added wizard zones
Video HERE
demmax2004
by GsJosh on Sun Apr 28, 2013 9:21 am
gannicus wrote:
GsJosh wrote:...
I'm sorry for the late reply but I recently got the exact same problem as you're having. I updated to a newer version of XBMC and suddenly the lights weren't coming on anymore. I've asked some people on the XBMC forum to help me but I have little hope... Did you solve the problem? Perhaps we should have another look at Lightpack since they have improved the software recently.
GsJosh
by K G B on Wed Sep 25, 2013 9:11 am
Hi guys,
I bought 60led/meter ws2811 strips (only one data wire), thinking that bigger is better (silly me).
To get it working on a 64" tv I need to use 272 LEDs *87 horizontal and 49 vertical.
I also purchased a Teensy 3 in hope its better specs will be able to carry my ambilight system.
http://www.pjrc.com/teensy/index.html
Now, Is there an actual way I can try and test this baby of mine? No code I can find works for so many led lights.
I'd be very grateful to get this working properly. Should I focus on FastSPI2 release code which has been optimised or stick with FastSPI?
How do you work out settings for boblight prefix for 272 LED setup. I don't know much but am willing to learn. Please help me get this working and I'll upload as many pics as you want :)
Regards,
Milo
K G B
by nicholass on Wed Mar 12, 2014 1:52 pm
I have a 3 wires LED RGB Strip 60 led 1 meter long with a SW2812 chip.
An Arduino Uno R3
I run Windows 7 Professional 32 bits.
Do you have a web site address that I can download a boblight or adafruit that will work with that?
nicholass
