Adalight with Lightpack
Re: Adalight with Lightpack
by Bavilo on Mon Jan 14, 2013 11:28 am
demmax2004 wrote:
Do you recommend increasing the height of the zones of leaving them default?
Are you asking me?
I can not advise you anything, I do not have the device Adalight.
Oh ok, which device do you use?
Bavilo
by demmax2004 on Mon Jan 14, 2013 11:44 am
Paintpack DMX
demmax2004
by Bavilo on Mon Jan 14, 2013 11:46 am
demmax2004 wrote:Paintpack DMX
I see, but you still had to set up the zones correct?
Did you make them cover only a slim part of the screen, or did you make the zones bigger to capture more of the screen?
Bavilo
by demmax2004 on Mon Jan 14, 2013 12:03 pm
Sorry. I can not understand you and what you want to tell me.
demmax2004
by Bavilo on Mon Jan 14, 2013 12:06 pm
demmax2004 wrote:Sorry. I can not understand you and what you want to tell me.
Oh, it's ok, I'll just wait until I receive my LEDs
Bavilo
by demmax2004 on Mon Jan 14, 2013 12:08 pm
If there are problems with the setup wizard, please contact me via email or skype
demmax2004
by flash608 on Tue Jan 15, 2013 7:12 am
mlte wrote:Any way to make it grab from the second or third screen? it works fine on the primary screen but refuses to grab anything from the second or third screen.
Edit: Nevermind I managed it , still one of the Led's stays off even though it lights just fine if I check "avg color on all leds"
Hi, i know it`s been a while, but how did you manage to do this? When i grab the area of some pixels to another screen (on my left) it doesn`t work at all. It works only on my primary screen. I`ve checked config file and if i grab the frames to the second screen the values goes with minus (-) for e.g. "Position=@Point(-302 640)"
50 LED + Arduino UNO v3 (Adalight) on 23" LG 2362D monitor
flash608
by Bavilo on Tue Jan 15, 2013 3:47 pm
Which LEDs are you guys using?
The adafruit LED Strand (or similar)?
How is the brightness of the halo effect? I just mounted all of my 100 LEDs and I'm not sure if the brightness will be enough...
All those youtube videos of DIY ambilight seem to have really bright effects. I hope mine will be the same...
Also, is anyone tilting the LEDs a certain degree towards to wall?
Bavilo
by flash608 on Tue Jan 15, 2013 4:46 pm
Hi Bavilo, mine looks like this ---> http://www.youtube.com/watch?v=OZoCCAyrQFY I`ve finished it a couple days ago. It works great.
In my case i put leds directly to the sides of the furnitures. It depends only on your project, you can do it in so many ways.
Oh, i`m using leds from ebay, they are a copy of those one from Adafruit and they are so bright that i`m using those in about 10-40% depending on films etc.
flash608
by Bavilo on Tue Jan 15, 2013 4:56 pm
flash608 wrote:Hi Bavilo, mine looks like this ---> http://www.youtube.com/watch?v=OZoCCAyrQFY I`ve finished it a couple days ago. It works great.
Wow that is really bright. Can you provide the link to the eBay listing? Mine are also a copy from the adafruit lights. But they don't look as bright as yours....not sure what I'm doing wrong...maybe its because the LEDs are perpendicular to the wall and not pointed at the wall?
Im going to be very sad if I spent all this money only to get a very dim ambilight...:(
Bavilo
by flash608 on Tue Jan 15, 2013 5:22 pm
I don`t know if i can post it here, but ok ---> http://www.ebay.com/itm/50pcs-12mm-IP65 ... 35c12558a7
It looks really bright cause my camera (SGS2) isn`t to fast to adjust to the current light conditions.
I suggest you to first (if you`re on Windows) install Arduino soft, then processing, and than run the adalight sketch or colorwhirl. That was the first software working with my leds nevertheless Lightpack is so much easier to use.
flash608
by Bavilo on Tue Jan 15, 2013 5:34 pm
flash608 wrote:I don`t know if i can post it here, but ok ---> http://www.ebay.com/itm/50pcs-12mm-IP65 ... 35c12558a7
Mine are 100% identical to yours. 1600mcd etc...
Also I ran multiple software. Processing, prismatik, and ambibox. I think I need to try prismatik again and see if I can adjust the brightness. But I think my problem is still that the LEDs are not pointing at the wall. I need to fix that tomorrow...
Bavilo
by Bavilo on Wed Jan 16, 2013 2:56 pm
I'm finally done with my ambilight!!!
This is the first shot of my 100 Channel 55" Setup.
http://imgur.com/aCKJs
I'm using Ambibox v 2.1.0
Bavilo
by mg3point on Sat Jan 26, 2013 6:57 pm
I am attempting a 100 channel setup. I am using an old laptop running windows 7 an arduino mega 2560 rev 3 and 4 stands of 25 WS2801's. I have everything wired up and am following the adalight tutorial and plan to use prismatik. Following the steps i pushed the LEDStream to arduino but when it runs its test sequence only the first LED is firing. Any suggestions? I've read somethings about needing to update the spi.h but don't want to go poking around and break something else.
mg3point
by pburgess on Sun Jan 27, 2013 2:43 am
mg3point: what pins are you connected to on the Arduino Mega?
Also, try connecting to the second strand of LEDs and see if you get the same symptoms, or if all the LEDs light up then.
pburgess
