Pin Assignments on RGB LED?
Re: Pin Assignments on RGB LED?
Postby deejayspinz » Thu Feb 23, 2012 4:47 pm
I've just been playing with the same type of LED. As is been said already - they are common-annode, so think in reverse. 1 pin goes to +5v the other 3 go to digital pins on the arduino. Use the example I have below to see it in action. Note the Pin assignments are to PWM pins.
// Select which PWM-capable pins are to be used.
int redPin = 9;
int greenPin = 3;
int bluePin = 10;
// Set up our outputs, and give full high values so the
// LEDs start off.  Then fade in the blue LED.
void setup()
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  analogWrite(redPin, 255);
  analogWrite(greenPin, 255);
  analogWrite(bluePin, 255);
// The cycle of ramps will go through all of the primary
// and secondary hues in the RGB rainbow, and repeat.
void loop()
   analogWrite(redPin, 225);
   //digitalWrite(redPin, LOW);
  //green
  analogWrite(greenPin, 0);
  delay(2000);
  //yellow
  analogWrite(redPin, 0);
  analogWrite(greenPin, 190);
// delay(2000);
  //orange
//  analogWrite(redPin, 115);
//  analogWrite(greenPin, 245);
//  analogWrite(bluePin, 255);
delay(2000);
delay(2000);
deejayspinz
Previous
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
Users browsing this forum: No registered users and 4 guests
New Products [102]
LEDs[108]
Cables[60]
Prototyping[69]
