Character only library for OLED display
Postby fat16lib » Wed Feb 29, 2012 3:15 pm
I wrote a character only library for the Monochrome 128x32 OLED graphic display. It should also work on the 128x64 display but I have not tested it since I don't have this display.
This library is not buffered so it uses about 500 bytes less RAM than the Adafruit graphic library.
This neat tiny display can used in place of a standard LCD in projects that are short of RAM by using this library.
The file is SSD1306ASCII20120229.zip at http://code.google.com/p/beta-lib/downloads/list.
Here is the readme file:
SSD1306ASCII is an unbuffered character only library for an Adafruit 1306
OLED display. The SSD1306ASCII library only requires a few bytes of RAM.
SSD1306ASCII implements a small part of the LiquidCrystal API. Implemented
functions include clear(), home(), print(), setCursor(), and write().
It has only been tested with the "Monochrome 128x32 OLED graphic display".
http://www.adafruit.com/products/661
To use this library, copy the SSD1306ASCII folder to your libraries folder.
Edit SSD1306ASCII.h and select your display type. The default is:
// #define SSD1306_128_64
#define SSD1306_128_32
Select the font that will be used by defining FONT_TYPE. The default is:
#define FONT_TYPE 1
This is an 96 character version of the Adafruit glcdfont.
See SSD1306fonts.pdf for a rough representation of other choices.
Try the ssd1306HelloWorld example first.
The ssd1306ShowFont example displays all characters in the font.
The ssd1306FontMap example was used to generate SSD1306fonts.pdf.
fat16lib
Re: Character only library for OLED display
Postby Desert_Rat » Fri Apr 13, 2012 4:34 pm
Thank you! Since my little project doesn't require graphics, only text I easily replaced the Adafruit library with this one and not only did it give me a little more RAM, it reduced the program code itself about 2k as well.
This is great for those that don't require fancy graphic capabilities and only use text.
I went from living in a van down by the river to a shack in the desert.
Meh, at least it's an upgrade.
Desert_Rat
Postby zulucat » Tue Apr 17, 2012 1:40 am
fat16lib wrote: ... It should also work on the 128x64 display but I have not tested it since I don't have this display ...
I did some quick testing with my 128x64 display. Both HelloWorld and ShowFont examples work with the bigger display.
zulucat
Postby davegior » Sat May 05, 2012 7:05 pm
Fantastic. Much easier to use than the sample librarary. Thank you for sharing it with us.
Question: is there a character for Omega? Ω
davegior
Postby buton » Wed Feb 27, 2013 9:19 am
just what i was looking for...
thanks
buton
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
Users browsing this forum: demmax2004, mibignistinly and 6 guests
New Products [103]
LEDs[109]
Cables[61]
