Print Degree Sign with Temp on Touchscreen?
by bunger on Fri Mar 02, 2012 6:27 pm
I am successfully printing temperature on my tft touchscreen, but would like to add the degree sign after it. Here is my working code:
float temperatureF = (temperatureC * 9.0 / 5.0) + 32.0;
 char temperature[10];
 dtostrf(temperatureF,4,1,temperature);
 tft.fillRect(140, 100, 100, 40, BLACK);
 tft.drawString(140, 100, temperature, GREEN, 4);  // DISPLAY THE TEXT
Unfortunately, after much searching I can't figure out how to do that.
Any help would be very much appreciated!!!
bunger
Re: Print Degree Sign with Temp on Touchscreen?
by adafruit on Fri Mar 02, 2012 6:29 pm
There is no degree symbol in the font table, you could draw an 'o' instead
by bunger on Fri Mar 02, 2012 6:35 pm
adafruit wrote:There is no degree symbol in the font table, you could draw an 'o' instead
Is that what most people do?
bunger
by adafruit on Fri Mar 02, 2012 6:38 pm
sure
by bunger on Fri Mar 02, 2012 6:56 pm
adafruit wrote:sure
220... 221... whatever it takes... ;-)
bunger
by stimps on Sat Oct 06, 2012 1:33 am
I found a way to do it, but i cant remember how lol
heres my code feel free to sift:)
*edit*
I just used a very tactfully placed "o"
//#include <Servo.h>
#include <EEPROM.h>
//Servo startdrive;
//gas turbine ecu code start
//   John Warnes   combined and tested code combining adafruits LCD sheild code and Nathan Nissen's RPM code.
//   November 2011 Mega 2560 240x320 adafruit touchsheild display
#include "TFTLCD.h"
#include "TouchScreen.h"
#if not defined USE_ADAFRUIT_SHIELD_PINOUT
#error "For use with the shield, make sure to #define USE_ADAFRUIT_SHIELD_PINOUT in the TFTLCD.h library file"
#endif
// These are the pins for the shield!
#define YP A1  // must be an analog pin, use "An" notation!
#define XM A2  // must be an analog pin, use "An" notation!
#define YM 7   // can be a digital pin
#define XP 6   // can be a digital pin
#define TEMP_SENSOR_PIN 4
#define TEMP_SENSOR_PIN 5
#define ANALOG_VOTLAGE_REFERENCE 5
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// Color definitions
#define BLUE            0x001F
#define   BLACK           0x0000
#define   RED             0xF800
#define   GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
#define LTGREEN         0x3F11
#define JJCOLOR         0x4444
#define ARROW           0x8888
TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, 0);
int TIT = 0;
int TOT = 0;
int waittime = 0;
int throttle =12;
int idlespeed = 0;
int warmuptime = 0;
int rampup = 0;
int rampdn = 0;
int running = false;
int ignitionon = false;
int gas = false;
int dies = false;
int debouncetime = 0;
int fuelpump = 22;  // pin output for fuelpump
int gassol = 23;    // pin output for gas line solenoid
int ignition = 24;  // pin output for ignition relay
int starter = 12;   // pin output for starter unit PWM 12
int startduty = 0;
volatile unsigned long rpmcount;
unsigned long rpm;
unsigned long currenttime;
unsigned long runtime;
unsigned long starttime;
unsigned long gasruntime;
void rpm_fun(){
  rpmcount++;
}//Each rotation, this interrupt function is run once, so take that into consideration for calculating RPM
void setup(void) {
  //startdrive.attach(12);
  pinMode(fuelpump, OUTPUT);
  pinMode(gassol, OUTPUT);
  pinMode(ignition, OUTPUT);
  pinMode(starter, OUTPUT);
  Serial.begin(9600);
  attachInterrupt(0, rpm_fun, FALLING);
  rpmcount = 0;
  rpm = 0;
  //for (int i = 0; i < 512; i++) //wipes eeprom if required
  //EEPROM.write(i, 0);
  tft.reset();
  tft.initDisplay();
  tft.setRotation(1);
  pinMode(13, OUTPUT);
  welcomescreen();
  delay(500);
  mainscreen();
  rampup = EEPROM.read(0);  //retreives values from eeprom and writes to the screen
  tft.setTextColor(YELLOW);
  tft.setTextSize(1);
  tft.fillRect(63, 178, 25, 10, BLACK);
  tft.setCursor(66, 180);
  tft.println(rampup,DEC);
  rampdn = EEPROM.read(1);
  tft.fillRect(71, 192, 20, 10, BLACK);
  tft.setCursor(74, 195);
  tft.println(rampdn,DEC);
  idlespeed = EEPROM.read(2);
  tft.fillRect(73, 208, 15, 10, BLACK);
  tft.setCursor(75, 210);
  tft.println(idlespeed,DEC);
  warmuptime = EEPROM.read(3);
  tft.fillRect(86, 223, 35, 10, BLACK);
  tft.setCursor(93, 225);
  tft.println(warmuptime,DEC);
#define MINPRESSURE 4
#define MAXPRESSURE 600
void loop()
  digitalWrite(13, HIGH);
  Point p = ts.getPoint();
  digitalWrite(13, LOW);
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
  //startdrive.write(pos);
  if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
    p.x = map(p.x, TS_MINX, TS_MAXX, tft.height(), 0);
    p.y = map(p.y, TS_MINY, TS_MAXY, tft.width(), 0);
    //Serial.print("(");     Serial.print(p.x);    Serial.print(", ");     Serial.print(p.y);    Serial.println(")");
    if (p.x < 190 && p.y < 160) {    // if "E" is pressed run the update eeprom section, and load the current settings into memory for storage.
      if (p.x > 165 && p.y > 130){
        updateeeprom();
    if (p.x < 45 && p.y > 150) {   //if the correct area on the screen is pushed for that button, it increments that variable and updates the screen.
      tft.setTextSize(1);
      if (p.y < 195) {
        rampup--;
      else if(p.y < 240) {
        rampdn--;
      else if(p.y < 285) {
        idlespeed--;
      else {
        warmuptime--;
    if (p.x > 45 && p.x < 90) {
      tft.setTextSize(1);
      if (p.y >150) {
        if (p.y < 195) {
          rampup++;
          rampdn++;
          tft.fillRect(71, 193, 20, 10, BLACK);
          idlespeed++;
        else {
          warmuptime++;
    }     //   END of arrow button settings input section.
    currenttime = millis();     // keeps time of how long ecu has been running, time events are recorded off this for processing
    if (debouncetime > 100) {
      debouncetime = 0;
    if (p.x > 160 && p.y < 90 && debouncetime > 2)     // a press on the start button, commences only if the button hasnt been already pressed recently (debounce)
      running = !running;
      debouncetime = 0;   //debounces the start button
      starttime = currenttime;  //records the time the engine started
      if (running == true) {              // if START button is pressed, print the red stop button.
        tft.fillCircle(50,50, 42, RED);
        tft.setTextColor(WHITE);
        tft.setTextSize(2);
        tft.setCursor(28, 42);
        tft.println("STOP");
      else if (running == false) {          // if STOP button is pressed, print the green start button.
        tft.fillCircle(50,50, 42, GREEN);
        tft.setTextSize(2);
        tft.setCursor(20, 42);
        tft.println("START");
  waittime = waittime++;
  //int throttleread = analogRead(A15);  //throttle pot connected to pin 15    0 -- 5 volt input  5k pot.
  //throttle = map(throttleread, 0, 1023, 1, 100);
  if(running == true)
    ignitionon = running;
       //starts gas at engine start
    digitalWrite(ignition, HIGH);  //starts ignition at engine start
    analogWrite(starter, startduty);
    if (rpm > 2000) {                  //ensures gas is only injected if engine turning faster than 2000 rpm.
      digitalWrite(gassol, HIGH);
      gas = running;
  if(running == false)
    runtime = 0;
    starttime = 0;
    startduty = 0;
    digitalWrite(fuelpump, LOW); //if not running, keeps all fuel, gas and spark off
    digitalWrite(gassol, LOW);
    digitalWrite(ignition, LOW);
    analogWrite(starter, 0);
    dies = running;
    gas = running;
  if(running == true && runtime > 20000 && rpm > 2000) //20 seconds after start switchover fuel    check this later
    dies = running;
    gas = !running;
    digitalWrite(fuelpump, HIGH);
  if (waittime == 200 ) {
    showpos();
  if (waittime == 400 ) {
    readT2();
  if (waittime == 500 ) {
    updateb();
  if (waittime == 600 ) {
    readT1();
  if (waittime > 800  )
  {  //take snapshot of rpm data periodically
    waittime = 0;
    runtime = currenttime - starttime; //total of running time is the total ecu time minus the time START was pressed. keeps the runtime updated.
      (runtime = 0);
    Serial.print("Runtime is  ");    Serial.println(runtime,DEC);     Serial.print("gasruntime is");   Serial.println(gasruntime,DEC);   Serial.print("currenttime is");  Serial.println(currenttime,DEC);    Serial.print("Starttime is");    Serial.println(starttime,DEC);
    debouncetime = debouncetime++;
    {if (startduty < 254 ) // if engine starting, ramp up starter effort untill full power.
      startduty = startduty+3; // 3 is rate of starter power increase
    analogWrite(starter, startduty);}
    detachInterrupt(0);//Don't process interrupts during calculations
    rpm = 100*rpmcount;  //1000 if using the 4017 divide by 10 counter
    rpmcount = 0;
    attachInterrupt(0, rpm_fun, FALLING);  //Restart the interrupt processing
    tft.fillRect(123, 12, 123, 34, BLACK);//erase box and print main RPM display
    tft.setCursor(125, 15);
    tft.setTextSize(4);
    tft.println(rpm,DEC);
    tft.fillRect(101, 164, 25, 10, BLACK);
    tft.setTextSize(1);
    tft.setCursor(102, 165);
    tft.println(startduty,DEC);
void mainscreen()
  tft.fillScreen(BLACK);//fills screen with black
  tft.fillCircle(50,50, 42, GREEN);//draws start button
  tft.drawCircle(50, 50, 44, WHITE);
  tft.drawCircle(50, 50, 45, YELLOW);
  tft.drawRect(120, 10, 200, 38, WHITE); //RPM main display
  tft.drawRect(155, 50, 165, 28, WHITE);//TIT BOX (OI! keep it clean)
  tft.drawRect(155, 80, 165, 28, WHITE);//Tot box
  tft.drawRect(155, 110, 165, 28, WHITE);//tht box
  tft.drawRect(1, 100, 18, 18, WHITE); //IGN box
  tft.drawRect(1, 120, 18, 18, WHITE); //GAS box
  tft.drawRect(1, 140, 18, 18, WHITE); //DIES box
  tft.drawRect(123, 50, 30, 30, WHITE); //eeprom store button box
  tft.drawRect(155, 157, 40, 40, WHITE);//1st box
  tft.drawRect(197, 157, 40, 40, WHITE);//2nd box
  tft.drawRect(239, 157, 40, 40, WHITE);//3rd box
  tft.drawRect(280, 157, 40, 40, WHITE);//4th box
  tft.drawRect(155, 200, 40, 40, WHITE);//5th box
  tft.drawRect(197, 200, 40, 40, WHITE);//6th box
  tft.drawRect(239, 200, 40, 40, WHITE);//7th box
  tft.drawRect(280, 200, 40, 40, WHITE);//8th box
  tft.fillRect(157, 159, 36, 36, LTGREEN);//fill 1st box
  tft.fillRect(199, 159, 36, 36, LTGREEN);//fill 2nd box
  tft.fillRect(241, 159, 36, 36, LTGREEN);//fill 3rd box
  tft.fillRect(282, 159, 36, 36, LTGREEN);//fill 4th box
  tft.fillRect(157, 202, 36, 36, LTGREEN);//fill 5th box
  tft.fillRect(199, 202, 36, 36, LTGREEN);//fill 6th box
  tft.fillRect(241, 202, 36, 36, LTGREEN);//fill 7th box
  tft.fillRect(282, 202, 36, 36, LTGREEN);//fill 8th box
  tft.fillTriangle(175, 161, 160, 191, 190, 191, ARROW);//Arrow 1st box
  tft.fillTriangle(217, 161, 202, 191, 232, 191, ARROW);//Arrow 2nd box
  tft.fillTriangle(260, 161, 245, 191, 274, 191, ARROW);//Arrow 3rd box
  tft.fillTriangle(285, 191, 300, 161, 315, 191, ARROW);//Arrow 4th box
  tft.fillTriangle(160, 205, 175, 236, 190, 206, ARROW);//Arrow 5th box
  tft.fillTriangle(202, 205, 217, 236, 232, 206, ARROW);//Arrow 6th box
  tft.fillTriangle(245, 205, 260, 236, 274, 206, ARROW);//Arrow 7th box
  tft.fillTriangle(285, 205, 300, 236, 315, 206, ARROW);//Arrow 8th box
  tft.setTextColor(WHITE);  //print START in green circle
  tft.setTextSize(2);
  tft.setCursor(21, 42);
  tft.setTextColor(YELLOW); //print info next to output indicator boxes
  tft.setCursor(22, 102);
  tft.println("Ign");
  tft.setCursor(22, 122);
  tft.println("Gas");
  tft.setCursor(22, 142);
  tft.println("Dies");
  tft.setTextSize(1);
  tft.setCursor(155, 145);
  tft.println("Ramp Up");
  tft.setCursor(200, 145);
  tft.println("Ramp Dn");
  tft.setCursor(247, 145);
  tft.println("Idle");
  tft.setCursor(279, 145);
  tft.println("Warm up");
  tft.setCursor(4, 165);
  tft.println("Starter effort =");
  tft.setCursor(4, 180);
  tft.println("Ramp up =");
  tft.setCursor(4, 195);
  tft.println("Ramp down =");
  tft.setCursor(4, 210);
  tft.println("Idlespeed =");
  tft.setCursor(88, 210);
  tft.println("00 rpm");
  tft.setCursor(4, 225);
  tft.println("Warm up time =");
  tft.setTextSize(4);
  tft.setCursor(222, 15);
  tft.println(" RPM");
  tft.setTextSize(3);
  tft.setCursor(129, 54);
  tft.println("E");
  tft.setTextColor(GREEN);
  tft.setCursor(230, 53);
  tft.println("C TIT");
  tft.setTextColor(RED);
  tft.setTextSize(2);
  tft.setCursor(218, 81);
  tft.println("o");
  tft.setCursor(230, 83);
  tft.setTextSize(3);
  tft.println("C TOT");
  tft.setTextColor(BLUE);
  tft.setCursor(247, 113);
  tft.println(" THT");
  tft.setTextSize(2);
  tft.setCursor(218, 51);
  tft.println("o");
  tft.setCursor(220, 114);
  tft.setTextSize(3);
  tft.println("%");
void readT1()
  int raw1 = analogRead(4); //read and calculate and display 1st thermocouple
  TIT = 3 * ( 5.0 * raw1 * 100.0) / 1024.0;  //3 is temp multiplier so we can read up to 15 volts (with 5 volt max input pin)
  tft.fillRect(157, 52, 58, 23, BLACK);//erase box
  tft.setCursor(160, 53);
  tft.setTextSize(3);
  tft.println(TIT,DEC);
void readT2()
  int raw2 = analogRead(5); //read and calculate and display 2nd thermocouple
  int TOT = 3 * ( 5.0 * raw2 * 100.0) / 1024.0;
  tft.fillRect(157, 81, 60, 24, BLACK);//erase box and print second temp display
  tft.setCursor(160, 83);
  tft.setTextSize(3);
  tft.println(TOT,DEC);
  if (currenttime < 8000)  {
    rpm = 0;
    TIT = 0;
    TOT = 0;
  }//avoids false rpm counting at startup
void showpos()
  tft.fillRect(157, 111, 62, 25, BLACK);//erase box and print tht pos display
  tft.setCursor(160, 114);
  tft.setTextSize(3);
  tft.println(throttle,DEC);
void welcomescreen()
  tft.fillRect(71, 70, 190, 100, JJCOLOR);
  tft.drawString(85, 100, "J", WHITE, 5);
  delay(200);
  tft.drawString(147, 100, "G", WHITE, 5);
  delay(200);
  tft.drawString(210, 100, "T", WHITE, 5);
  delay(200);
  tft.drawRect(69, 68, 192, 102, WHITE);
  delay(200);
  tft.drawRect(67, 66, 196, 106, WHITE);
  tft.drawString(105, 195, "John Warnes  -  2011", WHITE);
  tft.drawString(85, 220, "John's Gas Turbine Project", WHITE);
void updateeeprom()   //stores these values into eeprom memory when "E" is pressed
EEPROM.write(0, rampup);
EEPROM.write(1, rampdn);
EEPROM.write(2, idlespeed);
EEPROM.write(3, warmuptime);
void updateb()
  if (ignitionon == true) {
    tft.fillRect(3, 101, 14, 15, YELLOW);
    tft.drawVerticalLine(3, 88, 12, BLACK);
  if (ignitionon == false) {
    tft.fillRect(3, 101, 14, 14, BLACK);
  if (gas == true) {
    tft.fillRect(3, 122, 14, 14, YELLOW);
  if (gas == false) {
    tft.fillRect(3, 122, 14, 14, BLACK);
  if (dies == true) {
    tft.fillRect(3, 142, 14, 14, YELLOW);
  if (dies == false) {
    tft.fillRect(3, 142, 14, 14, BLACK);
stimps
by ZTiK.nl on Thu Feb 14, 2013 8:30 pm
Sorry to revive an old topic, but I think there are still people coming here who want the same thing.
Below is an image I made of the 255 chars in the ascii table so you have a reference to whats possible and not.
I used code:
tft.print((char)1);
up to
tft.print((char)255);
Each line contains 20 characters except the first line.
The first line contains tabs and enters and such, so it is spread over 2 lines
2.8" TFT character map
TFT character map.jpg.jpg (550.89 KiB) Viewed 1244 times
As you can see either char9 or char247 would suit best for a degree symbol, but I suspect both are actually other symbols with different meanings...
Still printing a character is quicker than calculating where to draw a circle and how much space to leave open to print the next character...
P.S. sry about the fuzzyness in some areas of the picture, my webcam doesnt like bright screens very much (I have dimmed the backlight down to 10%ish)
ZTiK.nl
by Arctic_Eddie on Sat Feb 16, 2013 1:58 pm
Try ASCII code 176. That works in Windows by holding down the left Alt key while entering 0176 on the numeric keypad. °°°
Arctic_Eddie
by ZTiK.nl on Sat Feb 16, 2013 8:42 pm
Arctic_Eddie wrote:Try ASCII code 176. That works in Windows by holding down the left Alt key while entering 0176 on the numeric keypad. °°°
Unfortunately this does not work.
It will display a square on the display, not a degree sign.
ZTiK.nl
by Arctic_Eddie on Sun Feb 17, 2013 8:29 am
Displaying the character map as above is a good way to document any particular device. They don't use the same one as does Win7.
Arctic_Eddie
by adafruit_support_rick on Sun Feb 17, 2013 5:29 pm
The font data is in the glcdfont.c file included in the Adafruit_GFX library. We don't support this, but you can try creating your own fonts using a GLCD font creator tool, such as this one:
http://code.google.com/p/glcd-arduino/d ... p&can=2&q=
by nick_f on Sat Feb 07, 2015 3:14 am
display.print("Temperature: 24.6");
display.print((char)247);
display.println("C");
nick_f
by adafruit_support_rick on Sat Feb 07, 2015 11:54 am
Great! Thanks for posting!
