EL without an inverter
Postby LondonGent » Sat May 05, 2012 4:42 am
Having looked at the specs for the EL Tape:
•Size: 100 cm x 1.5 cm about 1mm thick, the glowing part is 1cm wide
•Panel lifetime: >25000 hours
•Operating voltage: 60-250VAC
•Operating Frequency: 50-5000HZ
•Current Draw: 0.14mA/cm2 (max) @ 110V / 400Hz
•Initial Brightness: 75 cd/m2
•Operating Temperature: -50 C / 65 C
•~10 nF per meter
With suitable protection, can EL be run directly from the mains? In the UK we are ~240VAC/50Hz.
LondonGent
Re: EL without an inverter
Postby adafruit » Sat May 05, 2012 12:01 pm
technically, yes...but its very dangerous and we dont recommend it as there is no current limit from the wall and you can do yourself a good one :(
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
Users browsing this forum: No registered users and 5 guests
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
