Digital LED Belt uploading code to Atmega32u4
Postby mlandergan » Mon Jun 25, 2012 1:24 pm
I purchased the Digital LED Belt Kit and I was following the tutorial on making it and I got stuck at number 5, uploading the test code to the Atmega32u4. I downloaded the specific arduino ide from the tutorial and clicked on the board Atmega32u4 breakout. I am using the correct cable. I downloaded the library and installed in my library folder in my arduino folder. The problem is when I upload the code I get this error "Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding" :( I then hit the reset button and none of the LED's on the belt light up.Any help is appreciated.
mlandergan
Re: Digital LED Belt uploading code to Atmega32u4
Postby adafruit_support_rick » Mon Jun 25, 2012 2:42 pm
Did you select the correct serial port in the Tools:Serial Port menu?
Postby mlandergan » Mon Jun 25, 2012 2:54 pm
Yes the serial port that I selected is "/dev/tty.usbmodemfd121"
mlandergan
Postby adafruit » Wed Jun 27, 2012 12:30 pm
Sorry for the delay - we were at an event! OK Can you do us a favor and in the pref tab click the squares for "Verbose" output for compiling and uploading?
Postby mlandergan » Thu Jun 28, 2012 1:22 pm
Im sorry where is the "pref tab"
mlandergan
Postby pburgess » Thu Jun 28, 2012 2:52 pm
From the menu bar, select Arduino->Preferences. There are two check boxes for "Show verbose output..." Select both and click OK.
pburgess
Postby mlandergan » Thu Jun 28, 2012 4:52 pm
I could not find the box for verbos this is what I saw when I opened up the preferences in the arduino ide, which I downloaded from the tutorial.
mlandergan
Postby pburgess » Thu Jun 28, 2012 5:27 pm
Oh! Crud, that's right, I'd forgotten those options were only added in newer versions of the Arduino IDE.
Instead, hold down the SHIFT key when clicking the "upload" button. That will enable verbose output for just that one transfer, not permanently. Copy the output here and we can take a look through it.
pburgess
Postby mlandergan » Thu Jun 28, 2012 6:10 pm
This is the output when uploading with holding shift:
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy -I/Users/jtlandergan/Documents/Arduino/libraries/LPD8806 -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/libraries/SPI /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/LEDbeltKit.cpp -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/LEDbeltKit.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy -I/Users/jtlandergan/Documents/Arduino/libraries/LPD8806 -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/libraries/SPI -I/Users/jtlandergan/Documents/Arduino/libraries/LPD8806/utility /Users/jtlandergan/Documents/Arduino/libraries/LPD8806/LPD8806.cpp -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/LPD8806/LPD8806.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy -I/Users/jtlandergan/Documents/Arduino/libraries/LPD8806 -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/libraries/SPI -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/libraries/SPI/utility /Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/libraries/SPI/SPI.cpp -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/SPI/SPI.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=551161773 -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/malloc.c -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/malloc.c.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=228372705 -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/pins_teensy.c -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/pins_teensy.c.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=-1402580686 -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/usb.c -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/usb.c.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=-1221615858 -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/WInterrupts.c -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/WInterrupts.c.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=650932977 -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/wiring.c -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/wiring.c.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/HardwareSerial.cpp -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/HardwareSerial.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/main.cpp -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/main.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/Print.cpp -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/Print.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/Tone.cpp -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/Tone.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/usb_api.cpp -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/usb_api.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/WMath.cpp -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/WMath.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/WString.cpp -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/WString.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/core.a /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/malloc.c.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/core.a /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/pins_teensy.c.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/core.a /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/usb.c.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/core.a /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/WInterrupts.c.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/core.a /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/wiring.c.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/core.a /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/HardwareSerial.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/core.a /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/main.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/core.a /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/Print.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/core.a /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/Tone.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/core.a /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/usb_api.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/core.a /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/WMath.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/core.a /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/WString.cpp.o
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -Os -Wl,--gc-sections,--relax -mmcu=atmega32u4 -o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/LEDbeltKit.cpp.elf /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/LEDbeltKit.cpp.o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/LPD8806/LPD8806.cpp.o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/SPI/SPI.cpp.o /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/core.a -L/var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp -lm
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/LEDbeltKit.cpp.elf /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/LEDbeltKit.cpp.eep
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/LEDbeltKit.cpp.elf /var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/LEDbeltKit.cpp.hex
Binary sketch size: 7536 bytes (of a 28672 byte maximum)
/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega32u4 -cavr109 -P/dev/tty.usbmodemfd121 -b57600 -D -Uflash:w:/var/folders/np/npbd54DJHsKVA6VzMr1Je++++TI/-Tmp-/build2111330383780406856.tmp/LEDbeltKit.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 9 2007 at 11:20:31
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
System wide configuration file is "/Users/jtlandergan/Documents/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/jtlandergan/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodemfd121
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 1024 8 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : avr910
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: Send: . [1b]
avrdude: Send: S [53]
avrdude: ser_recv(): programmer is not responding
mlandergan
Postby mlandergan » Sun Jul 01, 2012 1:23 pm
any help?
mlandergan
Postby adafruit_support_bill » Sun Jul 01, 2012 1:43 pm
Do you see any led activity on the 32U4 board itself after hitting reset or during the upload attempt?
Postby adafruit » Sun Jul 01, 2012 2:16 pm
yes, are you pressing reset and seeing the LED pulse?
Postby mlandergan » Sun Jul 01, 2012 2:37 pm
When I attempt to upload a skectch, there is no led activity besides the red power led. When I hit the reset button, the green led pulses 5 times.
mlandergan
Postby adafruit » Sun Jul 01, 2012 2:40 pm
great, are you pressing that button right before uploading?
Postby mlandergan » Sun Jul 01, 2012 2:49 pm
I just tried that and now Im getting this
"Binary sketch size: 7536 bytes (of a 28672 byte maximum)
avrdude: ser_open(): can't open device "/dev/tty.usbmodemfd121": No such file or directory"
mlandergan
Next
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
Users browsing this forum: hiduino and 5 guests
New Products [103]
LEDs[109]
Cables[61]
