128X32 I2C OLED Display Library [SOLVED]
by Knight on Wed Oct 03, 2012 10:19 pm
So I purchased a 128x32 OLED display, and I tried to get the example code working. Here is what I have done so far:
* Downloaded and installed both libraries: https://github.com/adafruit/Adafruit_SSD1306 and https://github.com/adafruit/Adafruit-GFX-Library
* Renamed the folders in the libraries folder to Adafruit_SSD1306 and Adafruit_GFX as per the readme.
* Opened up the Adafruit_SSD1306.h file in notepad and commented out "#define SSD1306_128_64" and uncommented out "#define SSD1306_128_32".
This is all I have done.
I then attempt to compile and run the default example code sketch by clicking on File > Examples > Adafruit_SSD1306 > ssd1306_128x32_i2c. After I attempt to compile I get the following error: ssd1306_128x32_i2c.cpp:53:2: error: #error ("Height incorrect, please fix Adafruit_SSD1306.h!");
I have tried removing everything that says anything to do with 64, and nothing I do seems to help. In desperation I commented out the checks in the sketch, and was able to get the display to run, though it's only using the top half of the screen, which makes all but the largest text unreadable. Obviously I'm missing something in regards to the library configuration.
Below is the modified Adafruit_SSD1306.h file:
This is a library for our Monochrome OLEDs based on SSD1306 drivers
Pick one up today in the adafruit shop!
------> http://www.adafruit.com/category/63_98
These displays use SPI to communicate, 4 or 5 pins are required to
products from Adafruit!
BSD license, check license.txt for more information
All text above, and the splash screen must be included in any redistribution
#if ARDUINO >= 100
 #include "Arduino.h"
 #include "WProgram.h"
#include <Adafruit_GFX.h>
#define BLACK 0
#define WHITE 1
#define SSD1306_I2C_ADDRESS 0x3C // 011110+SA0+RW - 0x3C or 0x3D
// Address for 128x32 is 0x3C
// Address for 128x32 is 0x3D (default) or 0x3C (if SA0 is grounded)
SSD1306 Displays
The driver is used in multiple displays (128x64, 128x32, etc.).
Select the appropriate display below to create an appropriately
sized framebuffer, etc.
SSD1306_128_64 128x64 pixel display
SSD1306_128_32 128x32 pixel display
You also need to set the LCDWIDTH and LCDHEIGHT defines to an
appropriate size
// #define SSD1306_128_64
#if defined SSD1306_128_64 && defined SSD1306_128_32
  #error "Only one SSD1306 display can be specified at once in SSD1306.h"
#if !defined SSD1306_128_64 && !defined SSD1306_128_32
  #error "At least one SSD1306 display must be specified in SSD1306.h"
  #define SSD1306_LCDWIDTH 128
  #define SSD1306_LCDHEIGHT 64
#if defined SSD1306_128_32
  #define SSD1306_LCDHEIGHT 32
#define SSD1306_SETCONTRAST 0x81
#define SSD1306_DISPLAYALLON 0xA5
#define SSD1306_NORMALDISPLAY 0xA6
#define SSD1306_INVERTDISPLAY 0xA7
#define SSD1306_DISPLAYOFF 0xAE
#define SSD1306_DISPLAYON 0xAF
#define SSD1306_SETCOMPINS 0xDA
#define SSD1306_SETPRECHARGE 0xD9
#define SSD1306_SETMULTIPLEX 0xA8
#define SSD1306_SETLOWCOLUMN 0x00
#define SSD1306_SETHIGHCOLUMN 0x10
#define SSD1306_SETSTARTLINE 0x40
#define SSD1306_MEMORYMODE 0x20
#define SSD1306_COMSCANINC 0xC0
#define SSD1306_COMSCANDEC 0xC8
#define SSD1306_SEGREMAP 0xA0
#define SSD1306_CHARGEPUMP 0x8D
#define SSD1306_EXTERNALVCC 0x1
#define SSD1306_SWITCHCAPVCC 0x2
// Scrolling #defines
#define SSD1306_ACTIVATE_SCROLL 0x2F
class Adafruit_SSD1306 : public Adafruit_GFX {
  Adafruit_SSD1306(int8_t SID, int8_t SCLK, int8_t DC, int8_t RST, int8_t CS);
  Adafruit_SSD1306(int8_t RST);
  void begin(uint8_t switchvcc = SSD1306_SWITCHCAPVCC, uint8_t i2caddr = SSD1306_I2C_ADDRESS);
  void ssd1306_command(uint8_t c);
  void ssd1306_data(uint8_t c);
  void clearDisplay(void);
  void invertDisplay(uint8_t i);
  void display();
  void startscrollright(uint8_t start, uint8_t stop);
  void startscrollleft(uint8_t start, uint8_t stop);
  void startscrolldiagright(uint8_t start, uint8_t stop);
  void startscrolldiagleft(uint8_t start, uint8_t stop);
  void stopscroll(void);
  void drawPixel(int16_t x, int16_t y, uint16_t color);
  int8_t _i2caddr, sid, sclk, dc, rst, cs;
  void fastSPIwrite(uint8_t c);
  void slowSPIwrite(uint8_t c);
  volatile uint8_t *mosiport, *clkport, *csport, *dcport;
  uint8_t mosipinmask, clkpinmask, cspinmask, dcpinmask;
Much thanks in advance for what I'm sure is a silly mistake on my part!
Re: 128X32 I2C OLED Display Library
by adafruit on Wed Oct 03, 2012 11:14 pm
try with a fresh copy of the library, make sure you only have one copy
change which line is commented in the .h file, and be sure to save it!
then try to re-compile and upload the sketch
by Knight on Thu Oct 04, 2012 12:47 am
adafruit wrote:.... make sure you only have one copy ....
You know... it's like you've done this before! And I ALMOST ignored that part of your response, figuring, "yeah, sure, typical response."
Much thanks! That was it, multiple copies of the library.
Re: 128X32 I2C OLED Display Library [SOLVED]
by farn7259 on Mon Nov 12, 2012 8:14 pm
So I've tried to run this code for a simple school project, but due to my apparent lack of knowledge for the fundamentals of the Arduino platform I need help.
- Ive downloaded both zip folders
- I dont know how to correct the error: " 'Adafruit_SS1306' does not name a type"
- I know that the .h file must be changed but I dont know it that is everything I need to do.
Some assistance on this would be greatly appreciated!!
by adafruit_support_rick on Mon Nov 12, 2012 9:06 pm
Have a look at this page for instructions on how to install libraries. And no, you don't want to rename the .h file. You want to make sure the library folder has the right name.
