RGB LED w/ PWM waterproof flexi strip Problem
by apophisnico on Tue Oct 30, 2012 5:52 am
I bought one meter of RGB LED. Sometimes a part of LEDS will not turn on or are not controllable. An investigation has allowed me to see that there is a chip on it that malfunctioning. If I am to hand the chip, LEDs revert all controllable. have you got a solution for me?
Regards,
Nicolas
apophisnico
Re: RGB LED w/ PWM waterproof flexi strip Problem
by adafruit_support_bill on Tue Oct 30, 2012 5:54 am
Hi Nicolas,
Was this strip purchased from Adafruit?
by apophisnico on Tue Oct 30, 2012 5:59 am
Digital Addressable RGB LED w/ PWM waterproof flexi strip - (1m)
orders id : 181021
thank you
apophisnico
by adafruit_support_bill on Tue Oct 30, 2012 6:15 am
On the digital strips, sometimes a solder connection to the chip cracks from repeated flexing. These can usually be repaired with a soldering iron.
by apophisnico on Tue Oct 30, 2012 6:48 am
Yes ok but the problem is not between the connection of 2 LEDs it's the black chip which have a problem and it's not possible (for me) to repair its connexion.. If the problem was a connection between two LEDs it will be to easy to repair it :-D
I just got the LEDs and the product arrived damaged, it is not as if I used it for a while. I just make a prototype...
apophisnico
by adafruit_support_bill on Tue Oct 30, 2012 7:27 am
If you received it in that condition, contact support@adafruit.com with a link to this thread and we will replace it.
by apophisnico on Tue Oct 30, 2012 7:29 am
Ok i'll do that.
Thank you for your help!
Nicolas
apophisnico
