LPD8806 Digital Light Wand + SD Card + LCD
Postby is0-mick » Mon Nov 12, 2012 5:55 am
Hi Guys,
Someone kindly sent me some LPD8806 strip to create a version of my Digital Light Wand with LCD + SD reader light painting tool.
You can select a bitmap image on the SD card using the LCD display, and then send it to the strip.
If anyone wants the code, its available here:
http://pastebin.com/ueJhzQbK
Some pictures of it in action
http://www.flickr.com/photos/68646769@N ... otostream/
Mick
is0-mick
Re: LPD8806 Digital Light Wand + SD Card + LCD
Postby is0-mick » Tue Nov 13, 2012 6:32 am
I’ve now added the Gamma Lookup Table that I came across in one of the LPD8806 examples, which seems to do a better job of converting 8bit RGB values to 7bit RGB due to the way our eyes work!
Previously I was just bit shifting, but the Gamma lookup helps produce an image that looks more comparable to the input image.
The image produced by bitshifting seemed to lack a little contrast and seemed too bright.
I’ve uploaded a picture to flickr produced with the new code so you can compare.
New code is now here:
http://pastebin.com/NbgLWdNF
Mick
is0-mick
Postby larryp61 » Fri Nov 16, 2012 11:09 pm
Hello is0-mick,
Do you have a schematic for the project? Like how to attach the sd, lcd and buttons? Thanks
larryp61
Postby larryp61 » Sat Nov 17, 2012 12:23 am
Sorry didn't know there was prebuilt shield for this.
larryp61
Postby tbitson » Sat Nov 17, 2012 8:17 am
What shield are you using?
tbitson
Postby is0-mick » Sat Nov 17, 2012 1:57 pm
Just a one I picked up from ebay.
If you search for arduino lcd keypad, it should bring it up.
Here is a video of it on youtube.
http://www.youtube.com/watch?v=Mh-LZx1As4E
Mick
is0-mick
Postby owenlab » Thu Nov 22, 2012 7:50 am
Hi Mick, it's possible to adapte this sketch with the HL1606 strip?
I saw your other code for 1606 strip, but run with LSB file and i need a sketch that runs with BMP or JPG file...
Could you write a sketch for this scope please?
really thanks a lot
Owen
owenlab
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
Users browsing this forum: mibignistinly and 6 guests
New Products [107]
More Dev Boards[31]
Components & Parts[70]
LEDs[111]
Cables[62]
