PROBLEM WITH: LCD Shield Kit with 16x2 Character White on Blue Display
by N_Man on Fri Nov 16, 2012 9:30 pm
I have purchased a LCD Shield Kit with 16x2 Character White on Blue Display for my ARDUINO UNO. After connecting it and loading the following code I get lit up squares on the first line and nothing on the second line . Does that mean that the shield I got is defective?
Any helps would be highly appreciated.
Code:
Example code for the Adafruit RGB Character LCD Shield and Library
This code displays text on the shield, and also reads the buttons on the keypad.
When a button is pressed, the backlight changes color.
// include the library code:
#include <Wire.h>
#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
// The shield uses the I2C SCL and SDA pins. On classic Arduinos
// this is Analog 4 and 5 so you can't use those for analogRead() anymore
// However, you can connect other I2C sensors to the I2C bus and share
// the I2C bus.
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
// These #defines make it easy to set the backlight color
#define RED 0x1
#define YELLOW 0x3
#define GREEN 0x2
#define TEAL 0x6
#define BLUE 0x4
#define VIOLET 0x5
#define WHITE 0x7
  // Debugging output
  Serial.begin(9600);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  lcd.setCursor(0, 1);
  // Print a message to the LCD. We track how long it takes since
  // this library has been optimized a bit and we're proud of it :)
  int time = millis();
  lcd.print("Hello, world!");
  //lcd.println("it is me");
//  time = millis() - time;
//  Serial.print("Took "); Serial.print(time); Serial.println(" ms");
  lcd.setBacklight(WHITE);
uint8_t i=0;
//    lcd.println("Hello, world!");
//  lcd.println("it is me");
Photo on 12-11-16 at 8.20 PM.jpg (101.22 KiB) Viewed 1795 times
Photo on 12-11-16 at 8.20 PM #2.jpg (115.13 KiB) Viewed 1795 times
N_Man
Re: PROBLEM WITH: LCD Shield Kit with 16x2 Character White on Blue Display
by adafruit on Fri Nov 16, 2012 9:40 pm
what happens when you plug the shield ONTO the arduino?
by N_Man on Fri Nov 16, 2012 9:44 pm
Well it is the same story.
Photo on 12-11-16 at 8.43 PM.jpg (105.46 KiB) Viewed 1789 times
adafruit wrote:what happens when you plug the shield ONTO the arduino?
N_Man
by adafruit on Fri Nov 16, 2012 9:50 pm
does pressing buttons change the LED on/off state?
by N_Man on Fri Nov 16, 2012 10:07 pm
Well initially I loaded the Hello World example, which had the button checking and functionality in the loop portion of the code. However, the LED would not display anything and would keep flickering. Pressing the buttons did change the LED to off or on depending on which button was pressed. Then I decided to remove all the code inside the loop section. In this case the screen does not flicker, however it only displays the squares. Now pressing the buttons does not do anything since there is no code for it. If there any particular code you want me to try?
adafruit wrote:does pressing buttons change the LED on/off state?
N_Man
by adafruit on Fri Nov 16, 2012 10:09 pm
go back to the original code, twist the contrast knob once in a while to check if letters show up. if the buttons 'do something' to the backlight then the chip is working - there might be something wrong with the LCD. check your connections. is the LCD from adafruit?
by shuma on Sun Feb 10, 2013 2:39 pm
Hi.
I have exactly the same problem here.
The LCD is only displaying a row of square.
Buttons works, with the code below i can switch the backlight on and off, I was able to control a steeper motor hooked to the arduino with the shield buttons. So I assume the chip and the connection is ok.
I have doublecheck my soldering it's seam clean too.
Do you think it' a wiring problem or the LCD is defective?
#include <Wire.h>
// the I2C bus.
#define YELLOW 0x3
  // Debugging output
  Serial.begin(9600);
  lcd.begin(16, 2);
  lcd.setBacklight(0x1);
  lcd.clear();
void loop()
uint8_t buttons = lcd.readButtons();
  if (buttons) {
    lcd.clear();
    lcd.setCursor(0,0);
    if (buttons & BUTTON_UP) {
      lcd.print("UP ");
    if (buttons & BUTTON_DOWN) {
      lcd.print("DOWN ");
      lcd.setBacklight(0x0);
shuma
by adafruit_support_rick on Sun Feb 10, 2013 3:33 pm
Well, from the pictures I think I can see several issues. First of all, you should not be powering the shield from Vin. You should be connecting t o the 5V pin on the arduino.
VIn is the unregulated input. Since you're using USB to power the board, this is going to be 5V, which is fine, but if you were to decide power the board with a 9V supply through the barrel jack, then VIn would be 9V, which would likely damage the shield.
several solders on the 16-pin LCD appear to be cold joints - the solder is blobbed up and hasn't flowed onto the pad. Solder joints should look like this:
See our Guide To Excellent Soldering for more information.
Finally, your jumper wires for power, ground, SDA and SCL don't appear to be soldered at all. You cannot expect a reliable connection if the wires are simply inserted into the holes.
by shuma on Sun Feb 10, 2013 6:09 pm
Thank you DriverBlock.
May be I was to confidant in my soldering abilities :)
You were right, solders on the 16-pin LCD wasn't so good and a for a few of them it hasn't flowed onto the pad.
I have redone the soldering in the LCD and now working great. Beginner Mistake :)
And I don't power the shied with the Vin pin but with the regulated 5v. The Vin is connected to a stepper motor driver card on a breadboard not shown on the photo. and to power the arduino when i am on battery (10 volt)
shuma
by sloft on Wed Sep 25, 2013 9:55 am
I had the same problem but whit the Raspberry Pi, I confirm it was just a soldering problem, after double-check my solders I succeed get the LCD working.
sloft
