128x32 i2c OLED -- compile problem
by joss on Tue Nov 20, 2012 10:19 pm
I just purchased a 128x32 i2c OLED from adafruit and am following the instructions at
http://learn.adafruit.com/monochrome-ol ... 2c-display
but I am getting a compile error about conflicting declarations:
.../Arduino/libraries/Adafruit_SSD1306/Adafruit_SSD1306.cpp:31: error: conflicting declaration 'uint8_t font []'
.../Arduino/libraries/Adafruit_GFX/glcdfont.c:9: error: 'font' has a previous declaration as 'const unsigned char font [1275]'
I am new to arduino and am hoping somebody has a good idea.
Thanks in advance
joss
Re: 128x32 i2c OLED -- compile problem
by nikk on Wed Nov 21, 2012 8:59 am
i just got mine today. I had the same error.
Just comment out line 31 in Adafruit_SSD1306.cpp. The demo is working for me after that.
I don´t understand why there is this line 31 in Adafruit_SSD1306.cpp.
Regards,
nikk
nikk
by adafruit on Wed Nov 21, 2012 11:43 am
which version of the IDE are you using?
by Constantin on Wed Nov 21, 2012 6:09 pm
I am using 1.01 and I have the same issue. Both sets of files just downloaded from github.
Constantin
by joss on Wed Nov 21, 2012 6:23 pm
I was running version 1.0.1 of the IDE. I upgraded to 1.0.2 and got the same result.
I tried nikk's fix above and that worked.
to be clear I commented out line 31 in Adafruit_SSD1306.cpp
giving the following:
// a 5x7 font table
//extern uint8_t PROGMEM font[];
then it compiles and runs fine.
I am unclear if this change will have unfortunate consequences later.
joss
by adafruit on Wed Nov 21, 2012 7:40 pm
thats odd - what OS are you using?
by joss on Wed Nov 21, 2012 8:31 pm
I am on Mac OS X 10.7.2, but I think the problem will prove to be platform agnostic.
Line 31 from Adafruit_SSD1306.cpp:
Line 9 from Adafruit_GFX.cpp:
const static unsigned char font[] PROGMEM = {
since we are clearly defining font[] twice and with different types.
I just downloaded both libraries from github on the 20th.
joss
by Constantin on Sat Nov 24, 2012 4:05 pm
I have the same issue in OSX 10.7.5 and Windows 7. Both running 1.01 of the Arduino IDE.
Constantin
by jarruda on Sun Nov 25, 2012 12:42 am
I believe the correct solution to the problem is this:
Line 31 of Adafruit_SSD1306:
To:
  extern const uint8_t PROGMEM font[];
and
Line 9 of glcdfont.c:
To:
  const static uint8_t  font[] PROGMEM = {
Note that changing glcdfont.c isn't strictly necessary since a uint8_t is just an unsigned char, but Dennis Ritchie would haunt me.
After making the change, I ran the 128x32 SPI example sketch from the library and it's working just fine.
jarruda
by adafruit on Sun Nov 25, 2012 1:34 pm
sorry, someone sent us a pull request that just broke everything and we blindly assumed it was fixing a bug. GFX has been reverted, you can redownload it!
