G is for GROUND! The latest Circuit Playground is here!
LED Belt uploading code failure
by tallgoofy on Fri Nov 30, 2012 1:10 pm
I bought the LED belt about a month and a half ago to add to a halloween costume I made for my wife. I had no issues the first time around. Now I am revisiting the strand for a different project but am having issues with it uploading to the board. Not sure if this is user error on my part or if the board sustained some sort of damage during its last outing. When I plug into the USB the strand runs through the previous sequence. I've tried multiple USB cables. I've hit reset before/after/during upload to no avail. I read through other posts on this board and issues seemed to be sorted by choosing the correct serial source. This does not seem to be an issue with me.
Here is the verbose logging from a previous attempt:
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy -I/Users/Enchanter/Documents/Arduino/libraries/LPD8806 -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/libraries/SPI /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/siriloop.cpp -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/siriloop.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy -I/Users/Enchanter/Documents/Arduino/libraries/LPD8806 -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/libraries/SPI -I/Users/Enchanter/Documents/Arduino/libraries/LPD8806/utility /Users/Enchanter/Documents/Arduino/libraries/LPD8806/LPD8806.cpp -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/LPD8806/LPD8806.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy -I/Users/Enchanter/Documents/Arduino/libraries/LPD8806 -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/libraries/SPI -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/libraries/SPI/utility /Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/libraries/SPI/SPI.cpp -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/SPI/SPI.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=972457814 -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/malloc.c -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/malloc.c.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=1379220386 -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/pins_teensy.c -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/pins_teensy.c.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=-569942242 -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/usb.c -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/usb.c.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=2002663918 -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/WInterrupts.c -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/WInterrupts.c.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=-1153429352 -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/wiring.c -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/wiring.c.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/HardwareSerial.cpp -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/HardwareSerial.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/main.cpp -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/main.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/Print.cpp -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/Print.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/Tone.cpp -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/Tone.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/usb_api.cpp -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/usb_api.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/WMath.cpp -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/WMath.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/WString.cpp -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/WString.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/core.a /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/malloc.c.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/core.a /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/pins_teensy.c.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/core.a /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/usb.c.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/core.a /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/WInterrupts.c.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/core.a /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/wiring.c.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/core.a /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/HardwareSerial.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/core.a /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/main.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/core.a /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/Print.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/core.a /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/Tone.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/core.a /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/usb_api.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/core.a /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/WMath.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/core.a /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/WString.cpp.o
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -Os -Wl,--gc-sections,--relax -mmcu=atmega32u4 -o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/siriloop.cpp.elf /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/siriloop.cpp.o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/LPD8806/LPD8806.cpp.o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/SPI/SPI.cpp.o /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/core.a -L/var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp -lm
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/siriloop.cpp.elf /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/siriloop.cpp.eep
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/siriloop.cpp.elf /var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/siriloop.cpp.hex
Binary sketch size: 3830 bytes (of a 28672 byte maximum)
/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega32u4 -cavr109 -P/dev/tty.usbmodem411 -b57600 -D -Uflash:w:/var/folders/g3/2_pv1vhs4wx6ch8v94yzv7c80000gp/T/build6962983905695047821.tmp/siriloop.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 9 2007 at 11:20:31
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
System wide configuration file is "/Applications/TeensyDuino/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/Enchanter/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodem411
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 1024 8 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : avr910
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: Send: . [1b]
avrdude: Send: S [53]
avrdude: ser_recv(): programmer is not responding
avrdude: butterfly_recv(): programmer is not responding
Any help would be awesome. Thanks.
tallgoofy
Re: LED Belt uploading code failure
by adafruit on Sat Dec 01, 2012 10:08 pm
does the LED pulse?
by tallgoofy on Sun Dec 02, 2012 1:48 pm
When I hit the reset button the LED pulses, but that's the only time.
tallgoofy
by adafruit on Mon Dec 03, 2012 9:01 pm
when you hit the reset button, and the LED pulses, whats the COM port that shows up?
by tallgoofy on Mon Dec 03, 2012 9:17 pm
tallgoofy
by adafruit on Mon Dec 03, 2012 10:10 pm
ok make sure thats selected, then turn off the debugging output as it will affect timing. press UPLOAD then click the reset button immediately
by tallgoofy on Mon Dec 03, 2012 11:56 pm
Many thanks. I thought I had tried that but I suppose I hadn't hit it at just the right moment to make it work. That fixed it.
tallgoofy
