HAPPY LABOR DAY - ADAFRUIT IS OPEN - ALL ORDERS PLACED AFTER 11AM ET 9/4/2015 WILL NOT SHIP UNTIL TUESDAY 9/8/2015 - READ MORE!
Using power breakout leads on 12mm pixels
by allears on Sat Dec 01, 2012 5:54 pm
I've got 2 25-pixel strands, and 2 5v 1500ma power supplies.
Is there some way I can use the power breakout leads to power one strand with each supply, while using the connectors to daisy chain data, clock, and ground? That would effectively connect the +5 of each supply together... Or should I either cut the connectors and wire each strand individually, or buy one larger power supply?
allears
Re: Using power breakout leads on 12mm pixels
by adafruit on Sat Dec 01, 2012 10:11 pm
not a good idea - you can't connect power supply outputs together or they could be damaged permanently :(
