Triggering From Serial Input
by ckeyes on Fri Dec 07, 2012 7:07 pm
I seem to be able to get where I want to be with controlling my 160 LED LPD8806 strip
in individual sketches but I was hoping I could get a number of different effects in one
sketch that I could trigger each one using serial inputs.
I've seen some examples where button presses etc. will trigger various sections of a sketch
but I don't seem to be able to get anything working other than the simplest of effects.
I have this script working but I'd love to get a smooth flowing rainbow effect added to it:
#include "LPD8806.h"
#include "SPI.h"
int dataPin  = 2;
int clockPin = 3;
const int numPixels = 160;
LPD8806 strip = LPD8806(160, dataPin, clockPin);
  strip.begin();
  strip.show();
  Serial.begin(9600);
// function prototypes, do not remove these!
void colorChase(uint32_t c, uint8_t wait);
void colorWipe(uint32_t c, uint8_t wait);
void dither(uint32_t c, uint8_t wait);
void scanner(uint8_t r, uint8_t g, uint8_t b, uint8_t wait);
void wave(uint32_t c, int cycles, uint8_t wait);
void rainbowCycle(uint8_t wait);
uint32_t Wheel(uint16_t WheelPos);
  // read the sensor:
  if (Serial.available() > 0) {
    char inByte = Serial.read();
    Serial.print("Command Received ");
    Serial.print(inByte);
    Serial.print("\n\r");
    int i;
          uint32_t c;
    switch (inByte) {
    case 'a':
      while (!Serial.available()) {
// Set all pixels to red
          c = strip.Color(255,0,0);
          for (i=0; i < strip.numPixels(); i++) {
              strip.setPixelColor(i, c);
          strip.show();
          delay(100);
      break;
    case 'b':
         // Wipe from middle:
          c = strip.Color(255,255,255); // white
          for (i=strip.numPixels() / 2 - 1; i >= 0; i--) { // half of strip, count down to 0
            strip.setPixelColor(i, c); // left pixel
            strip.setPixelColor(strip.numPixels() - 1 - i, c); // right pixel
            strip.show();
            delay(100);
      break;
    case 'c':
         digitalWrite(13, HIGH);   // set the LED on
         delay(150);              // wait for a second
         digitalWrite(13, LOW);    // set the LED off
      break;
      case 'd':
         delay(1000);              // wait for a second
      break;
      case 'e':
         delay(20);              // wait for a second
      break;
    default:
      // turn all the LEDs off:
      for (int thisPin = 13; thisPin < 13; thisPin++) {
        digitalWrite(thisPin, LOW);
When I copy code from another script and paste it into the section with the break I can never
get it to compile. Any pointers on inserting effects into the break areas would be greatly appreciated!
Carl
ckeyes
Re: Triggering From Serial Input
by adafruit_support_bill on Sat Dec 08, 2012 7:41 am
You should be able to insert another 'case' into the 'switch' statement as long as you stick to the proper syntax. http://arduino.cc/en/Reference/SwitchCase
If you post the code that you are having problems with, we can help you figure out what is wrong with it.
by ckeyes on Sat Dec 08, 2012 12:42 pm
Thanks. This project requires a lot of due diligence for a newbie :-) I got it working pretty well and am finally getting the flow of it all I think. (pun)
One thing that does escape me though is how to get the strip to do things like the comet effect while the strip is a solid color etc., what would appear
to be two things at once. The effects I see in the samples don't seem to go over any of those types of effects.
Can those be done with an UNO and LPD8806? Love to see some sample code if they can!
Here's a link to some effects I'd love to be able to do: http://www.youtube.com/watch?v=degZYv11rNc
Many thanks,
Carl
ckeyes
by adafruit_support_bill on Sat Dec 08, 2012 2:14 pm
This is just like the "colorChase()" function in the StrandTest example - except you use a color other than black (0) for the 'background color'.
(I haven't tested this, but it should be close)
void colorOverColorChase(uint32_t color, uint32_t backgroundColor, uint8_t wait) {
  int i;
    strip.setPixelColor(i, 0);  // turn all pixels off
      strip.setPixelColor(i, color);
      if (i == 0) {
        strip.setPixelColor(strip.numPixels()-1, backgroundColor);
      } else {
        strip.setPixelColor(i-1, backgroundColor);
      strip.show();
      delay(wait);
by ckeyes on Sat Dec 08, 2012 5:57 pm
Not sure what I'm doing wrong here but here's the code I have so far. Can't get it to compile.
Really appreciate your help with this!
#include "SPI.h"
int dataPin  = 2;
int clockPin = 3;
  strip.begin();
  strip.show();
  Serial.begin(9600);
  // read the sensor:
    int i;
          uint32_t c;
    switch (inByte) {
    case 'a':
          strip.show();
          //delay(100);
      break;
    case 'b':
         //green to red wave
  wave(strip.Color(0,127,0),60,0,100); //color, cycles, delay, repetitions
  wave(strip.Color(20,107,0),50,0,50); //color, cycles, delay, repetitions
  wave(strip.Color(40,87,0),40,0,50); //color, cycles, delay, repetitions
  wave(strip.Color(80,47,0),30,0,50); //color, cycles, delay, repetitions
  wave(strip.Color(107,27,0),20,0,100); //color, cycles, delay, repetitions
  wave(strip.Color(127,0,0),5,0,200); //color, cycles, delay, repetitions
      break;
    case 'c':
   twoColorSparkle(strip.Color(127,0,0), strip.Color(0,127,0), 50, 10); //color 1, color 2, density, delay - random sparkles in two colors
      break;
      case 'd':
          rainbowCycle(0);  // make it go through the cycle fairly fast
      break;
      case 'e':
              turnAllOff();
      break;
      case 'f':
  chaseMultipleLinesLToH(10,10,0,152); //number of leds in line, delay, low,
      break;
      case 'g':
  turnAllOn(strip.Color(0,0,80),200);
  dither(strip.Color(127,0,0), 10); //color, delay - random fills up the strip
  dither(strip.Color(0,0,80), 10); //color, delay - random fills up the strip
  //fadeUp(0,0,127,30); //red, green, blue, delay - fade up all pixels one color
      break;
      case 'h':
  randomSparkleUpSegment(strip.Color(0,127,0),15,10,0,100); //color, density, delay, low point, high point
  turnSegmentOn(strip.Color(0,127,0),200,0,100); //color, delay, start of segment, end of segment
  delay(500);
      break;
      case 'i':
  fillUpTheStar(strip.Color(127,0,0),30); //color, delay
  fillUpCenterStar(strip.Color(0,127,0), 30); //color, delay
  fadeDown(127,0,0,30);
      break;
      case 'j':
  colorOverColorChase(strip.Color(127,  0,  0), 100); // Red
  colorOverColorChase(strip.Color(  0,127,  0), 100); // Green
  colorOverColorChase(strip.Color(  0,  0,127), 100); // Blue
  colorOverColorChase(strip.Color(127,127,127), 100); // White
      break;
// An "ordered dither" fills every pixel in a sequence that looks
// sparkly and almost random, but actually follows a specific order.
void dither(uint32_t c, uint8_t wait) {
  // Determine highest bit needed to represent pixel index
  int hiBit = 0;
  int n = strip.numPixels() - 1;
  for(int bit=1; bit < 0x8000; bit <<= 1) {
    if(n & bit) hiBit = bit;
  int bit, reverse;
  for(int i=0; i<(hiBit << 1); i++) {
    // Reverse the bits in i to create ordered dither:
    reverse = 0;
    for(bit=1; bit <= hiBit; bit <<= 1) {
      reverse <<= 1;
      if(i & bit) reverse |= 1;
    strip.setPixelColor(reverse, c);
    strip.show();
    delay(wait);
  delay(250); // Hold image for 1/4 sec
// "Larson scanner" = Cylon/KITT bouncing light effect
void scanner(uint8_t r, uint8_t g, uint8_t b, uint8_t wait) {
  int i, j, pos, dir;
  pos = 0;
  dir = 1;
  for(i=0; i<((strip.numPixels()-1) * 8); i++) {
    // Draw 5 pixels centered on pos. setPixelColor() will clip
    // any pixels off the ends of the strip, no worries there.
    // we'll make the colors dimmer at the edges for a nice pulse
    // look
    strip.setPixelColor(pos - 2, strip.Color(r/4, g/4, b/4));
    strip.setPixelColor(pos - 1, strip.Color(r/2, g/2, b/2));
    strip.setPixelColor(pos, strip.Color(r, g, b));
    strip.setPixelColor(pos + 1, strip.Color(r/2, g/2, b/2));
    strip.setPixelColor(pos + 2, strip.Color(r/4, g/4, b/4));
    strip.show();
    delay(wait);
    // If we wanted to be sneaky we could erase just the tail end
    // pixel, but it's much easier just to erase the whole thing
    // and draw a new one next time.
    for(j=-2; j<= 2; j++)
        strip.setPixelColor(pos+j, strip.Color(0,0,0));
    // Bounce off ends of strip
    pos += dir;
    if(pos < 0) {
      pos = 1;
      dir = -dir;
    } else if(pos >= strip.numPixels()) {
      pos = strip.numPixels() - 2;
      dir = -dir;
// Sine wave effect
#define PI 3.14159265
void wave(uint32_t c, int cycles, uint8_t wait, int repetitions) {
  float y;
  byte r, g, b, r2, g2, b2;
  // Need to decompose color into its r, g, b elements
  g = (c >> 16) & 0x7f;
  r = (c >> 8) & 0x7f;
  b = c & 0x7f;
  for(int x=0; x<repetitions; x++)
    for(int i=0; i<strip.numPixels(); i++) {
      y = sin(PI * (float)cycles * (float)(x + i) / (float)strip.numPixels());
        y = 1.0 - y; // Translate Y to 0.0 (top) to 1.0 (center)
        r2 = (byte)((float)r * y);
        g2 = (byte)((float)g * y);
        b2 = (byte)((float)b * y);
      strip.setPixelColor(i, r2, g2, b2);
    strip.show();
    delay(wait);
void chaseUpTheStar(uint32_t c, uint8_t wait) {
  int i,j;
      strip.setPixelColor(80, c);
      delay(wait);
      strip.setPixelColor(80, strip.Color(0,0,0));
         for (i = 1; i <= 20; i++) {
           strip.setPixelColor(80+i, c);
           strip.setPixelColor(80-i, c);
           strip.show();   // write all the pixels out
           delay(wait);
           strip.setPixelColor(80+i, strip.Color(0,0,0));
           strip.setPixelColor(80-i, strip.Color(0,0,0));
         for (j=0; j<=29; j++) {
           strip.setPixelColor(j, c);
           strip.setPixelColor(59-j, c);
           delay(wait);
           strip.setPixelColor(j, strip.Color(0,0,0));
           strip.setPixelColor(59-j, strip.Color(0,0,0));
void chaseUpCenterStar(uint32_t c, uint8_t wait) {
  int i,j;
         for (i = 1; i <= 6; i++) {
           strip.setPixelColor(146+i, c);
           strip.setPixelColor(147-i, c);
           delay(wait);
           strip.setPixelColor(146+i, strip.Color(0,0,0));
           strip.setPixelColor(147-i, strip.Color(0,0,0));
         for (j=0; j<=18; j++) {
           strip.setPixelColor(103+j, c);
           strip.setPixelColor(140-j, c);
           delay(wait);
           strip.setPixelColor(103+j, strip.Color(0,0,0));
           strip.setPixelColor(140-j, strip.Color(0,0,0));
void fillUpTheStar(uint32_t c, uint8_t wait) {
  int i,j;
      delay(wait);
           delay(wait);
           delay(wait);
void fillUpCenterStar(uint32_t c, uint8_t wait) {
  int i,j;
           delay(wait);
           delay(wait);
void chaseBetweenLToH(uint32_t c, uint8_t wait, uint8_t pointL, uint8_t pointH) {
  int i;
         for (i = pointL; i <= pointH; i++) {
           delay(wait);
           strip.setPixelColor(i, strip.Color(0,0,0));
void chaseBetweenHToL(uint32_t c, uint8_t wait, uint8_t pointL, uint8_t pointH) {
  int i;
         for (i = pointH; i >= pointL; i--) {
           delay(wait);
void chaseLineLToH(uint32_t c, uint8_t lineNumber, uint8_t wait, uint8_t pointL, uint8_t pointH) {
  int i, j;
         for(i = pointL; i < pointH+lineNumber; i++) {
           for(j = 0; j < lineNumber; j++) {
             strip.setPixelColor(i-j, c);
         delay(wait);
         turnAllOff();
void chaseLineHToL(uint32_t c, uint8_t lineNumber, uint8_t wait, uint8_t pointL, uint8_t pointH) {
  int i, j;
         for(i = pointH; i > pointL; i--) {
           for(j = 0; j<lineNumber; j++){
             strip.setPixelColor(i+j, c);
          delay(wait);
          turnAllOff();
void chaseToCenter(uint32_t c, uint8_t lineNumber, uint8_t wait, uint8_t pointL, uint8_t pointH) {
  int i, j, k;
  i = pointL;
  k = pointH;
  while(i < k && k > i) {
             strip.setPixelColor(k+j, c);
  delay(wait);
  i++;
  k--;
  turnAllOff();
void chasePastCenter(uint32_t c, uint8_t lineNumber, uint8_t wait, uint8_t pointL, uint8_t pointH) {
  int i, j, k;
  i = pointL;
  k = pointH;
  while(i < pointH && k > pointL) {
  delay(wait);
  i++;
  k--;
  turnAllOff();
void turnAllOn(uint32_t c, uint32_t wait) {
  int i;
    strip.setPixelColor(i, c);  // turn all pixels on
  delay(wait);
void turnSegmentOn(uint32_t c, uint32_t wait, uint8_t startofseg, uint8_t endofseg) {
  int i;
  for (i=startofseg; i <= endofseg; i++) {
  delay(wait);
void fadeUpSeg(uint32_t r, uint32_t g, uint32_t b, uint32_t wait, uint8_t startofseg, uint8_t endofseg) {
  int i, j;
  for (j=0; j <= 100; j++) {
    for (i=startofseg; i<=endofseg; i++) {
      strip.setPixelColor(i, strip.Color((r*j)/100,(g*j)/100,(b*j)/100));
  strip.show();
  delay(wait);
void fadeDownSeg(uint32_t r, uint32_t g, uint32_t b, uint32_t wait, uint8_t startofseg, uint8_t endofseg) {
  int i, j;
  for (j=100; j >= 0; j--) {
      strip.setPixelColor(i, strip.Color((r*j)/100,(g*j)/100,(b*j)/100));  // turn all pixels on
  strip.show();
  delay(wait);
void fadeUp(uint32_t r, uint32_t g, uint32_t b, uint32_t wait) {
  int i, j;
  strip.show();
  delay(wait);
void fadeDown(uint32_t r, uint32_t g, uint32_t b, uint32_t wait) {
  int i, j;
  strip.show();
  delay(wait);
void chaseMultipleLinesLToH(uint8_t lineNumber, uint8_t wait, uint8_t pointL, uint8_t pointH) {
  int i, j;
         for(i = pointL; i <= pointH; i++) {
             strip.setPixelColor(i, strip.Color(0,0,127));
             strip.setPixelColor(i+j+(2*lineNumber), strip.Color(127,0,0));
             strip.setPixelColor(i+j+(3*lineNumber), strip.Color(0,127,0));
             strip.setPixelColor(i+j+(4*lineNumber), strip.Color(127,127,0));
             strip.setPixelColor(i+j+(5*lineNumber), strip.Color(0,127,127));
             strip.setPixelColor(i+j+(6*lineNumber), strip.Color(127,0,127));
             strip.setPixelColor(i+j+(7*lineNumber), strip.Color(0,0,127));
             strip.setPixelColor(i+j+(8*lineNumber), strip.Color(127,0,0));
             strip.setPixelColor(i+j+(9*lineNumber), strip.Color(0,0,0));
         delay(wait);
void turnAllOff() {
  int i;
void randomSparkleUpSegment(uint32_t c, uint32_t density, uint8_t wait, uint8_t pointL, uint8_t pointH) {
  int i,j,location;
    for (j=pointL; j<=pointH; j++) {
      for (i=0; i <= density; i++) {
      location = random(pointL,j);
      strip.setPixelColor(location, c);
    delay(wait);
    turnAllOff();
void randomSparkleUpStrip(uint32_t c, uint32_t density, uint8_t wait) {
  int i,j,location;
    for (j=density; j<strip.numPixels(); j++) {
      location = random(0,j);
    delay(wait);
    turnAllOff();
void randomSparkle(uint32_t c, uint32_t density, uint8_t wait) {
  int i,j,location;
  for (j=0; j < 200; j++) {
         location = random(0,strip.numPixels()); //random location in first 5th of strip
    delay(wait);
    turnAllOff();
void randomColorSparkle(uint8_t wait) {
  int i;
  int location1, location2, location3, location4, location5;
  int color1, color2, color3;
       for (i=0; i < 200; i++) {
         location1 = random(0,32); //random location in first 5th of strip
         location2 = random(33,64); //random location in 2nd 5th of strip
         location3 = random(65,96); //random location in 3rd 5th of strip
         location4 = random(97,128); //random location in 4th 5th of strip
         location5 = random(129,159); //randon location in last 5th of strip
         color1 = random(127);
         color2 = random(127);
         color3 = random(127);
         strip.setPixelColor(location1, strip.Color(color1,color2,0));
         strip.setPixelColor(location2, strip.Color(color3,0,color1));
         strip.setPixelColor(location3, strip.Color(0,color2,color3));
         strip.setPixelColor(location4, strip.Color(color1,color2,0));
         strip.setPixelColor(location5, strip.Color(color3,0,color1));
         delay(wait);
         strip.setPixelColor(location1, strip.Color(0,0,0));
         strip.setPixelColor(location2, strip.Color(0,0,0));
         strip.setPixelColor(location3, strip.Color(0,0,0));
         strip.setPixelColor(location4, strip.Color(0,0,0));
         strip.setPixelColor(location5, strip.Color(0,0,0));
void twoColorSparkle(uint32_t c1, uint32_t c2, uint32_t density, uint8_t wait) {
  int i,j,location1,location2;
  for (j=0; j < 1; j++) {
         location1 = random(0,strip.numPixels()); //random location number 1
         location2 = random(0,strip.numPixels()); //random location number 2
         strip.setPixelColor(location1, c1);
         strip.setPixelColor(location2, c2);
    delay(wait);
    turnAllOff();
void rainbow(uint8_t wait) {
  int i, j;
  for (j=0; j < 384; j++) {     // 3 cycles of all 384 colors in the wheel
      strip.setPixelColor(i, Wheel( (i + j) % 384));
    delay(wait);
// Slightly different, this one makes the rainbow wheel equally distributed
// along the chain
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for (j=0; j < 384 * 1; j++) {     // 5 cycles of all 384 colors in the wheel
      // tricky math! we use each pixel as a fraction of the full 384-color wheel
      // (thats the i / strip.numPixels() part)
      // Then add in j which makes the colors go around per pixel
      // the % 384 is to make the wheel cycle around
      strip.setPixelColor(i, Wheel( ((i * 384 / strip.numPixels()) + j) % 384) );
    delay(wait);
// fill the dots one after the other with said color
// good for testing purposes
void colorWipe(uint32_t c, uint8_t wait) {
  int i;
      strip.show();
      delay(wait);
// Chase a dot down the strip
void colorChase(uint32_t c, uint8_t wait) {
  int i;
      if (i == 0) {
        strip.setPixelColor(strip.numPixels()-1, 0);
      } else {
        strip.setPixelColor(i-1, 0);
      strip.show();
      delay(wait);
  int i;
      if (i == 0) {
      } else {
      strip.show();
      delay(wait);
/* Helper functions */
//Input a value 0 to 384 to get a color value.
//The colours are a transition r - g -b - back to r
  byte r, g, b;
  switch(WheelPos / 128)
    case 0:
      r = 127 - WheelPos % 128;   //Red down
      g = WheelPos % 128;      // Green up
      b = 0;                  //blue off
      break;
    case 1:
      g = 127 - WheelPos % 128;  //green down
      b = WheelPos % 128;      //blue up
      r = 0;                  //red off
      break;
    case 2:
      b = 127 - WheelPos % 128;  //blue down
      r = WheelPos % 128;      //red up
      g = 0;                  //green off
      break;
  return(strip.Color(r,g,b));
ckeyes
by ckeyes on Sat Dec 08, 2012 7:39 pm
I think the problem I'm having is in adding the effect in the "break j" area of the script.
I tried some variations of this: colorOverColorChase(strip.Color( 0,127, 0), 100);
but am really only guessing.
Might you know how I should add the code there as in the above script I posted?
Carl
ckeyes
by ckeyes on Sun Dec 09, 2012 12:36 am
I found that using this: colorOverColorChase(strip.Color(100,10,30),100,10);
in the break section works, but simply chases and fills the strip with one color.
Carl
ckeyes
by adafruit_support_bill on Sun Dec 09, 2012 8:03 am
ColorOverColorChase takes 2 colors (the chase color and the background color). You are passing it '100' for the background color.
by ckeyes on Sun Dec 09, 2012 12:26 pm
Gotcha, thanks. Can the scanner code here be changed to have the "comet" travel the strip over a background color?
The colorchase is very similar to what I did have working.
Reason I ask is that I have yet to see anywhere, and I've searched quite a bit, any videos or sample
code that would demonstrate anything near the effects in the video I posted above.
I have no idea what strip is used or what's driving it, but there are some very cool effects in it
that I've never seen an LPD8806 do....hope it can...not looking forward to starting over with something
else.
Getting a nice comet traveling over a background color might indicate that the other effects
are at least possible...then on to white sparkles over a smooth flowing rainbow :D
Carl
  int i, j, pos, dir;
  pos = 0;
  dir = 1;
  for(i=0; i<((strip.numPixels()-1) * 2); i++) {
    // look
    strip.setPixelColor(pos - 2, strip.Color(r/30, g/30, b/30));
    strip.setPixelColor(pos - 1, strip.Color(r/4, g/4, b/4));
    strip.setPixelColor(pos + 1, strip.Color(r/4, g/4, b/4));
    strip.setPixelColor(pos + 2, strip.Color(r/30, g/30, b/30));
    strip.show();
    delay(wait);
    pos += dir;
    if(pos < 0) {
      pos = 1;
      dir = -dir;
      dir = -dir;
ckeyes
by adafruit_support_bill on Mon Dec 10, 2012 6:50 am
It's possible, but you would need to do a bit of math. This code assumes black as a background color, and simply divides the R, G and B components so that they fade in and out. You could probably just add the R, G & B components of the background color to that, but you would have to constrain the results to valid values (255 or less). You will get different effects as you are mixing colors. You will probably have to do some experimentation to fine-tune the effect.
by ckeyes on Mon Dec 10, 2012 11:56 am
Appreciate all the help, but I'm not much of a coder and learn a lot more from
working with examples. It wouldn't appear they aren't any of the multi or layered
effects sketches around to learn from so I'm thinking of going the DMX route and design
effects using a GUI.
Many thanks,
Carl
ckeyes
