Program AmbiBox for Adalight (for Windows users only). Updat
calibra3
Re: Program AmbiBox for Adalight (for Windows users only). Updated 02.03.2013
Post by calibra3 »
Hello demmax2004.
I have received my arduino uno and 100 leds ws2801, and I would like to use your program ambibox for the xbmc.
I am a noob with the arduino.
Please can you tell me if I only need to upload the ledstream.pde to the arduino , and then, configure the ambibox with the number of leds and the position????
I am not sure, if I have to use the ledstream.pde or adalight.pde.....
And If I only want the ambibox for view movies in xbmc, Do I need the playclaw installed o not? I don't need the ambilight for games..
thanks for all.
demmax2004
Post by demmax2004 »
I am a noob with the arduino. :)
Better capture a PlayClaw, but it is possible and means AmbiBox, you need only to XBMC -> System-> Video output-> Use a fullscreen window rather than tru fullscreen = enabled.
calibra3
Post by calibra3 »
thanks for your fast reply demmax.
But please, then I will use the playclaw, because I want full screeen( not windowed)
But first, can you tell me if I need to upload de ledstream.pde , or what .pde I need to upload into the arduino Uno.
thanks again.
demmax2004
calibra3 wrote: But first, can you tell me if I need to upload de ledstream.pde , or what .pde I need to upload into the arduino Uno.
I do not know what is the Arduino
Kev1000000
Post by Kev1000000 »
calibra3 wrote:thanks for your fast reply demmax.
thanks again.
You need to upload ledstream.pde only to use AmbiBox.
scorpie
Post by scorpie »
I do have some questions and maybe someone can help me.
Right now my HTPC is running mediaportal, atmowin and the ardurino uno and it is working really good. But I would like to switch to xbmc.
Is ambibox working with xbmc using true fullscreen and aero on?
I uploaded LEDstream_LPD8806.pde to my arduino and after powering it on the colours are changing but ambibox is doing nothing. It says the arduino is connected, but nomatter what mode I use I don't get any lights.
Is there a step by step guide?
My os is windows 7 32bit
thanks
demmax2004
Use PlayClaw capture mode (Download and installa latest version of PlayClaw)
scorpie
Post by scorpie »
I did that, but as I wrote It is not working. Can I use the default settings of playclaw or do I have to change something. I can the the fps, cpu and so on - so I think playclaw is working
demmax2004
AmbiBox with PlayClaw to work with XBMC is fine, unless you are have taken older versions of software/
scorpie
Post by scorpie »
I am using the latest 2.1.2 and the playclaw that comes with it
demmax2004
scorpie wrote:I am using the latest 2.1.2 and the playclaw that comes with it
PlayClaw what version + build ???
scorpie
Post by scorpie »
Playclaw 4 Build 2352.
But even without playclaw my leds are not working. I think after clicking on "show area of capture" the leds should switch on. I tried every single method of screen capture, but non is working on the desktop?
Which pde for the arduino is the right on, maybe I have a wrong one, but after resetting the arduino (without ambibox started) the leds are working like they should. They are switching the colours three or four times.
demmax2004
scorpie wrote:Playclaw 4 Build 2352.
This version is very old and does not work correctly.
scorpie wrote:But even without playclaw my leds are not working. I think after clicking on "show area of capture" the leds should switch on. I tried every single method of screen capture, but non is working on the desktop?
If standard methods of capture does not work, then the problem is in the device. I do not know what firmware to upload to the device.
scorpie
Post by scorpie »
@demmax2004
thanks for your try to help me.
I really would like to use it, but if no one of the others here tries to help me, I think I have to give up.
Last call for help now!
can someone give me a working *.pde or*.ino. Some post above it is written that the ledstream.pde should be used. In the adalight tut. it is the Adalight.pde. So which one is the right one.
I tried the Colorswirl.pde with processing and it is working, but I don't have luck with ambibox.
I have 90 leds and it would be really nice if someone can help me
thanks
scorpie
scorpie
Post by scorpie »
So, started right from the scratch. Ambibox is working now (on the desktop), but how do I get playclaw (build 2600 - the latest one) to work with xbmc frodo. Are there some settings in playclaw itself that I have to make?
