Program AmbiBox for Adalight (for Windows users only). Updat
Re: Program AmbiBox for Adalight (for Windows users only). U
sorry, can't find your mail address
http://www.ambibox.ru/en/index.php/Scre ... of_AmbiBoxhorstepipe wrote:sorry, can't find your mail address
- scorpie
HI,
since my update to kodi, the leds stay of.
What I have tried so far
Updated to the latest ambibox
Tried the lastest script - gives me in Kodi a script error
deinstalled and installed Ambibox within Kodi, but noting works.
When Kodi starts I get the notifications that it is connected to Ambibox and that the profile is set to default.
I have exactly the same settings in Gotham 13.2 and there it is working as it should be.
Some advice?
Some advice?
Necessary convert the script to Kodi
- scorpie
@demmax2004
can you do that, because I can't
noscorpie wrote:@demmax2004
hey,
I had another feature request:
In Ambibox you can autochange profiles based on launched applications, that works nice. But what I'd need is to quit Ambibox when a special application starts.
I need this because I have a Steam plug-in for XBMC (which is btw. very nice to integrate Steam in XBMC).
So I start XBMC, XBMC starts Ambibox, everything's fine here.
From XBMC I start Steam, here Ambibox has to terminate, because:
quitting Steam triggers XBMC to start, which can't start because Ambibox is still running and using the XBMC log file. So I get an error from XBMC:
"Error. Unable to create application. Exiting"
Then I have to manually quit Ambibox, then delete the XBMC.log (isn't deletable before because it's used by Ambibox, why??), and then I can start XBMC...
I don't know what's the easiest way to solve this problem, sure there is more than one possible solution.
@kenv99: In normal case closing XBMC also closes Ambibox. Why doesn't it work when it's been closed by the Steam plugin?
@demmax2004: If it's less efford to implement maybe you could just add a trigger to quit Ambibox when a particular program starts.
I'll also try to ask the author of the Steam plugin, but I think it isn't maintained as good as yours by far.
solved,
just created a batch with
"taskkill /IM AmbiBox.exe"
now everything works fine
edit: If somebody else needs a shortcut to start/quit Ambibox, just create this .bat file:
@echo off
tasklist /fi "imagename eq AmbiBox.exe" | find /i "AmbiBox.exe" > nul
if not errorlevel 1 (taskkill /f /im "AmbiBox.exe") else (
start "ambibox" /b "C:\Program Files (x86)\AmbiBox\AmbiBox.exe"
exit
not good, need use command line
C:\Program Files (x86)\AmbiBox\AmbiBox.exe -exit
This only quits Ambibox. I needed to map One button to start/quit it.demmax2004 wrote:not good, need use command line
I corrected.scorpie wrote:@demmax2004
Download here http://www.ambibox.ru/en/index.php/Download_AmbiBox
Hi folks
I can't make playclaw (last version) working with ambibox (2.1.6), and I don't know why.
My setup : Windows 8.1 64b, GTX770, i5 3570k, 16go RAM / Adalight type led system.
Ambibox works great with many profiles setups (static background, music adaptive, windows 8 capture on desktop, everything is ok with this.
But when I use Playclaw, the leds stays off, no matter the app I launch.
Playclaw recognize well the application (there is a little blue window on bottom of screen appears when I launch the fullscreen app (games), but the leds stays off.
I uninstalled/reinstalled the two apps, tried many compatibility modes on executables, launched them in admin mode : leds stays off.
I tried with desactivating other "overlay" apps like Afterburner, same problem.
Now, I don't know what to do. :-(
There is my Playclaw log :
Anybody can help me here, please ? :'(
Here is my last ambibox log entries17:49:38.372 | PlayClaw5.exe | Detected Windows 8.1 x64 (6.3 build 9600)
17:49:38.372 | PlayClaw5.exe | Exe path: C:\Program Files (x86)\PlayClaw 5\
17:49:38.373 | PlayClaw5.exe | Config path: C:\ProgramData\PlayClaw5\
17:49:38.497 | PlayClaw5.exe | Set interface language: Français
17:49:38.506 | PlayClaw5.exe |
17:49:38.506 | PlayClaw5.exe | ##### Software version: Build 3105 (10 sept. 2014) #####
17:49:38.547 |x64 playclawhook64.exe | PlayClaw launcher build (Sep 10 2014), Windows version: 8.1 (6.3 build 9600)
17:49:38.549 | playclawhook32.exe | PlayClaw launcher build (Sep 10 2014), Windows version: 8.1 (6.3 build 9600)
17:49:38.562 |x64 playclawhook64.exe | PlayClaw hook build (Sep 10 2014)
17:49:38.576 | playclawhook32.exe | PlayClaw hook build (Sep 10 2014)
17:49:38.619 |x64 playclawhook64.exe | <dx11> Feature level DX11.0
17:49:38.665 |x64 core temp.exe | + Attached (winver: 6.2 build 9200) 00007FFB90F30000
17:49:38.782 |x64 edlaunch.exe | + Attached (winver: 6.2 build 9200) 00007FFB90F30000
17:49:38.822 | playclawhook32.exe | <dx11> Feature level DX11.0
17:49:38.842 | playclawhook32.exe | <virt> Set hook
17:49:38.861 | skype.exe | + Attached (winver: 6.3 build 9600) 18030000
17:49:38.865 | chrome.exe | ! Blocked process chrome.exe
17:49:38.874 | ambibox.exe | + Attached (winver: 6.1 build 7600) 0F150000
17:49:38.889 | playclaw5.exe | + Attached (winver: 6.1 build 7600) 0F150000
17:49:38.922 | BANNED.exe | + Attached (winver: 6.2 build 9200) 0F150000
17:49:39.190 | firefox.exe | + Attached (winver: 6.3 build 9600) 3FE00000
17:49:39.392 | firefox.exe | <dx11> Set hook
17:49:39.433 | firefox.exe | <dx10> Set hook
17:49:39.528 | firefox.exe | <dx9> Set hook
17:49:39.680 | nvbackend.exe | + Attached (winver: 6.3 build 9600) 07300000
17:49:40.240 | konepureopticalmonitor.exe | + Attached (winver: 6.2 build 9200) 0F150000
17:49:40.619 | PlayClaw5.exe | License type: ESSAI
17:49:40.619 | PlayClaw5.exe | <CPU> ***************** init *****************
17:49:40.626 | PlayClaw5.exe | <CPU> GenuineIntel detected
17:49:40.626 | PlayClaw5.exe | <CPU> CPU Name Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
17:49:40.626 | PlayClaw5.exe | <CPU> Num logical CPUs: 4
17:49:40.626 | PlayClaw5.exe | <CPU> CPU ID 306A9
17:49:40.626 | PlayClaw5.exe | <CPU> CPU with Thermal control MSR
17:49:40.627 | PlayClaw5.exe |
17:49:40.627 | PlayClaw5.exe | <GPU> ***************** init *****************
17:49:40.629 | PlayClaw5.exe | <GPU> Getting NVidia GPU information
17:49:40.629 | PlayClaw5.exe | <GPU> Num logical GPUs : 1
17:49:40.630 | PlayClaw5.exe | <GPU> Num physical GPUs: 1
17:49:40.631 | PlayClaw5.exe | <GPU> Driver version: 344.60, branch r344_32
17:49:40.631 | PlayClaw5.exe | <GPU> GPU 0: GeForce GTX 770
17:49:40.632 | PlayClaw5.exe | <GPU> Thermal Sensor 0 type 1 target 0x01 temp 46
17:49:40.634 | PlayClaw5.exe |
17:49:40.666 |x64 edlaunch.exe | <dx9> Set hook
17:49:40.679 | playclawcapture32.exe | PlayClaw capture server (Sep 10 2014) is starting
17:49:40.692 | playclawcapture32.exe | *** NVENC *** has detected 1 CUDA capable GPU device(s)
17:49:40.692 | playclawcapture32.exe | *** NVENC *** GPU 0 - GeForce GTX 770 has Compute SM 3.0, NVENC Available
17:49:40.702 | playclawcapture32.exe | [Error] *** AMD_VCE *** Couldn't find AMD platform, cannot proceed.
17:49:40.702 | playclawcapture32.exe | *** CAP *** Starting dispatcher...
17:49:40.842 | PlayClaw5.exe | Desktop recording mode is OFF
17:49:43.201 | iastoricon.exe | + Attached (winver: 6.2 build 9200) 0F150000
17:49:44.318 | deluge.exe | + Attached (winver: 6.2 build 9200) 0F150000
17:49:50.899 | PaintPackInterface | Shutdown
17:49:51.930 | ambibox.exe | + Attached (winver: 6.1 build 7600) 0F150000
17:49:52.715 | dropbox.exe | + Attached (winver: 6.3 build 9600) 0B540000
17:49:55.208 | ambibox.exe | + Attached (winver: 6.1 build 7600) 0F150000
17:50:02.916 | PaintPackInterface | PlayClaw is initializing
17:50:04.585 |x64 s1_sp64_ship.exe | + Attached (winver: 6.2 build 9200) 00007FFB90F30000
17:50:04.596 |x64 s1_sp64_ship.exe | <dx11> Set hook
17:50:05.465 |x64 wkspbroker.exe | + Attached (winver: 6.3 build 9600) 00007FFB90F30000
17:50:05.465 |x64 classicstartmenu.exe | + Attached (winver: 6.3 build 9600) 00007FFB90F30000
17:50:05.470 | plugin-nm-server.exe | + Attached (winver: 6.2 build 9200) 0F150000
17:50:05.474 |x64 hsmgr64.exe | + Attached (winver: 6.2 build 9200) 00007FFB90F30000
17:50:05.479 | hsmgr.exe | + Attached (winver: 6.2 build 9200) 0F150000
17:50:05.481 | usb3monitor.exe | + Attached (winver: 6.2 build 9200) 0F150000
17:50:05.490 |x64 conhost.exe | + Attached (winver: 6.3 build 9600) 00007FFB90F30000
17:50:05.531 | plugin-container.exe | + Attached (winver: 6.3 build 9600) 06BE0000
17:50:05.674 |x64 s1_sp64_ship.exe | Frame buffer 1920x1080 pixel format 28(32 bpp)
17:50:05.685 |x64 s1_sp64_ship.exe | <dx11> [Error] Cannot find shader compiler module, load d3dcompiler_47.dll
17:50:05.685 |x64 s1_sp64_ship.exe | New UI
17:50:05.886 | PaintPackInterface | Getting frames from PlayClaw5PaintPack_Frame_1_1
17:50:05.887 | PaintPackInterface | Get frame
17:50:05.977 | PaintPackInterface | Get frame
17:50:05.982 |x64 s1_sp64_ship.exe | Prepare ppframe PlayClaw5PaintPack_Frame_1920_1080
17:50:06.027 | PaintPackInterface | Getting frames from PlayClaw5PaintPack_Frame_1920_1080
17:50:06.027 | PaintPackInterface | Get frame
17:50:06.080 | PaintPackInterface | Get frame
17:50:06.131 | PaintPackInterface | Get frame
17:50:06.182 | PaintPackInterface | Get frame
17:50:06.233 | PaintPackInterface | Get frame
17:50:06.284 | PaintPackInterface | Get frame
17:50:06.335 | PaintPackInterface | Get frame
17:50:06.386 | PaintPackInterface | Get frame
17:50:06.438 | PaintPackInterface | Get frame
17:50:06.489 | PaintPackInterface | Get frame
17:50:06.540 | PaintPackInterface | Get frame
17:50:06.591 | PaintPackInterface | Get frame
17:50:06.642 | PaintPackInterface | Get frame
17:50:06.693 | PaintPackInterface | Get frame
17:50:06.744 | PaintPackInterface | Get frame
17:50:06.795 | PaintPackInterface | Get frame
17:50:06.846 | PaintPackInterface | Get frame
17:50:06.897 | PaintPackInterface | Get frame
17:50:06.945 | PaintPackInterface | Get frame
17:50:06.993 | PaintPackInterface | Get frame
17:50:07.042 | PaintPackInterface | Get frame
17:50:07.090 | PaintPackInterface | Get frame
17:50:07.138 | PaintPackInterface | Get frame
17:50:07.186 | PaintPackInterface | Get frame
17:50:07.235 | PaintPackInterface | Get frame
17:50:07.283 | PaintPackInterface | Get frame
17:50:07.331 | PaintPackInterface | Get frame
17:50:07.379 | PaintPackInterface | Get frame
17:50:07.427 | PaintPackInterface | Get frame
17:50:07.475 | PaintPackInterface | Get frame
17:50:07.523 | PaintPackInterface | Get frame
17:50:07.571 | PaintPackInterface | Get frame
17:50:07.619 | PaintPackInterface | Get frame
17:50:07.667 | PaintPackInterface | Get frame
17:50:07.715 | PaintPackInterface | Get frame
17:50:07.763 | PaintPackInterface | Get frame
17:50:07.812 | PaintPackInterface | Get frame
17:50:07.860 | PaintPackInterface | Get frame
17:50:07.908 | PaintPackInterface | Get frame
17:50:07.953 | PaintPackInterface | Get frame
17:50:07.998 | PaintPackInterface | Get frame
17:50:08.044 | PaintPackInterface | Get frame
17:50:08.089 | PaintPackInterface | Get frame
17:50:08.134 | PaintPackInterface | Get frame
17:50:08.179 | PaintPackInterface | Get frame
17:50:08.224 | PaintPackInterface | Get frame
17:50:08.269 | PaintPackInterface | Get frame
17:50:08.314 | PaintPackInterface | Get frame
17:50:08.359 | PaintPackInterface | Get frame
17:50:08.404 | PaintPackInterface | Get frame
17:50:08.449 | PaintPackInterface | Get frame
17:50:08.494 | PaintPackInterface | Get frame
17:50:08.539 | PaintPackInterface | Get frame
17:50:08.584 | PaintPackInterface | Get frame
17:50:08.629 | PaintPackInterface | Get frame
17:50:08.674 | PaintPackInterface | Get frame
17:50:08.719 | PaintPackInterface | Get frame
17:50:08.764 | PaintPackInterface | Get frame
17:50:08.809 | PaintPackInterface | Get frame
17:50:08.855 | PaintPackInterface | Get frame
17:50:08.900 | PaintPackInterface | Get frame
17:50:08.942 | PaintPackInterface | Get frame
17:50:08.984 | PaintPackInterface | Get frame
17:50:09.026 | PaintPackInterface | Get frame
17:50:09.068 | PaintPackInterface | Get frame
17:50:09.110 | PaintPackInterface | Get frame
17:50:09.152 | PaintPackInterface | Get frame
17:50:09.194 | PaintPackInterface | Get frame
17:50:09.236 | PaintPackInterface | Get frame
17:50:09.278 | PaintPackInterface | Get frame
17:50:09.320 | PaintPackInterface | Get frame
17:50:09.362 | PaintPackInterface | Get frame
17:50:09.404 | PaintPackInterface | Get frame
17:50:09.446 | PaintPackInterface | Get frame
17:50:09.488 | PaintPackInterface | Get frame
17:50:09.530 | PaintPackInterface | Get frame
17:50:09.572 | PaintPackInterface | Get frame
17:50:09.614 | PaintPackInterface | Get frame
17:50:09.657 | PaintPackInterface | Get frame
17:50:09.699 | PaintPackInterface | Get frame
17:50:09.741 | PaintPackInterface | Get frame
17:50:09.783 | PaintPackInterface | Get frame
17:50:09.825 | PaintPackInterface | Get frame
17:50:09.867 | PaintPackInterface | Get frame
17:50:09.909 | PaintPackInterface | Get frame
17:50:09.948 | PaintPackInterface | Get frame
17:50:09.987 | PaintPackInterface | Get frame
17:50:10.026 | PaintPackInterface | Get frame
17:50:10.065 | PaintPackInterface | Get frame
17:50:10.104 | PaintPackInterface | Get frame
17:50:10.143 | PaintPackInterface | Get frame
17:50:10.182 | PaintPackInterface | Get frame
17:50:10.221 | PaintPackInterface | Get frame
17:50:10.260 | PaintPackInterface | Get frame
17:50:10.299 | PaintPackInterface | Get frame
17:50:10.338 | PaintPackInterface | Get frame
17:50:10.377 | PaintPackInterface | Get frame
17:50:10.417 | PaintPackInterface | Get frame
17:50:10.456 | PaintPackInterface | Get frame
17:50:10.495 | PaintPackInterface | Get frame
17:50:10.534 | PaintPackInterface | Get frame
17:50:10.573 | PaintPackInterface | Get frame
17:50:10.612 | PaintPackInterface | Get frame
17:50:10.651 | PaintPackInterface | Get frame
17:50:10.690 | PaintPackInterface | Get frame
17:50:10.729 | PaintPackInterface | Get frame
17:50:10.768 | PaintPackInterface | Get frame
17:50:10.808 | PaintPackInterface | Get frame
17:50:10.847 | PaintPackInterface | Get frame
17:50:10.886 | PaintPackInterface | Get frame
17:50:10.922 | PaintPackInterface | Get frame
17:50:10.958 | PaintPackInterface | Get frame
17:50:10.995 | PaintPackInterface | Get frame
17:50:11.031 | PaintPackInterface | Get frame
17:50:11.067 | PaintPackInterface | Get frame
17:50:11.103 | PaintPackInterface | Get frame
17:50:11.139 | PaintPackInterface | Get frame
17:50:11.175 | PaintPackInterface | Get frame
17:50:11.211 | PaintPackInterface | Get frame
17:50:11.248 | PaintPackInterface | Get frame
17:50:11.284 | PaintPackInterface | Get frame
17:50:11.320 | PaintPackInterface | Get frame
17:50:11.356 | PaintPackInterface | Get frame
17:50:11.392 | PaintPackInterface | Get frame
17:50:11.428 | PaintPackInterface | Get frame
17:50:11.464 | PaintPackInterface | Get frame
17:50:11.500 | PaintPackInterface | Get frame
17:50:11.536 | PaintPackInterface | Get frame
17:50:11.572 | PaintPackInterface | Get frame
17:50:11.608 | PaintPackInterface | Get frame
17:50:11.644 | PaintPackInterface | Get frame
17:50:11.680 | PaintPackInterface | Get frame
17:50:11.716 | PaintPackInterface | Get frame
17:50:11.752 | PaintPackInterface | Get frame
17:50:11.788 | PaintPackInterface | Get frame
17:50:11.824 | PaintPackInterface | Get frame
17:50:11.860 | PaintPackInterface | Get frame
17:50:11.896 | PaintPackInterface | Get frame
17:50:11.929 | PaintPackInterface | Get frame
17:50:11.962 | PaintPackInterface | Get frame
17:50:11.995 | PaintPackInterface | Get frame
17:50:12.029 | PaintPackInterface | Get frame
17:50:12.062 | PaintPackInterface | Get frame
17:50:12.095 | PaintPackInterface | Get frame
17:50:12.128 | PaintPackInterface | Get frame
17:50:12.161 | PaintPackInterface | Get frame
17:50:12.194 | PaintPackInterface | Get frame
17:50:12.227 | PaintPackInterface | Get frame
17:50:12.260 | PaintPackInterface | Get frame
17:50:12.293 | PaintPackInterface | Get frame
17:50:12.326 | PaintPackInterface | Get frame
17:50:12.359 | PaintPackInterface | Get frame
17:50:12.392 | PaintPackInterface | Get frame
17:50:12.425 | PaintPackInterface | Get frame
17:50:12.458 | PaintPackInterface | Get frame
17:50:12.493 | PaintPackInterface | Get frame
17:50:12.526 | PaintPackInterface | Get frame
17:50:12.559 | PaintPackInterface | Get frame
17:50:12.592 | PaintPackInterface | Get frame
17:50:12.625 | PaintPackInterface | Get frame
17:50:12.658 | PaintPackInterface | Get frame
17:50:12.692 | PaintPackInterface | Get frame
17:50:12.725 | PaintPackInterface | Get frame
17:50:12.758 | PaintPackInterface | Get frame
17:50:12.791 | PaintPackInterface | Get frame
17:50:12.825 | PaintPackInterface | Get frame
17:50:12.858 | PaintPackInterface | Get frame
17:50:12.891 | PaintPackInterface | Get frame
17:50:12.921 | PaintPackInterface | Get frame
17:50:12.951 | PaintPackInterface | Get frame
17:50:12.981 | PaintPackInterface | Get frame
17:50:13.011 | PaintPackInterface | Get frame
17:50:13.041 | PaintPackInterface | Get frame
17:50:13.071 | PaintPackInterface | Get frame
17:50:13.101 | PaintPackInterface | Get frame
17:50:13.131 | PaintPackInterface | Get frame
17:50:13.161 | PaintPackInterface | Get frame
17:50:13.191 | PaintPackInterface | Get frame
17:50:13.221 | PaintPackInterface | Get frame
17:50:13.251 | PaintPackInterface | Get frame
17:50:13.281 | PaintPackInterface | Get frame
17:50:13.311 | PaintPackInterface | Get frame
17:50:13.341 | PaintPackInterface | Get frame
17:50:13.371 | PaintPackInterface | Get frame
17:50:13.401 | PaintPackInterface | Get frame
17:50:13.431 | PaintPackInterface | Get frame
17:50:13.461 | PaintPackInterface | Get frame
17:50:13.491 | PaintPackInterface | Get frame
17:50:13.521 | PaintPackInterface | Get frame
17:50:13.551 | PaintPackInterface | Get frame
17:50:13.581 | PaintPackInterface | Get frame
17:50:13.612 | PaintPackInterface | Get frame
17:50:13.642 | PaintPackInterface | Get frame
17:50:13.672 | PaintPackInterface | Get frame
17:50:13.702 | PaintPackInterface | Get frame
17:50:13.732 | PaintPackInterface | Get frame
17:50:13.762 | PaintPackInterface | Get frame
17:50:13.792 | PaintPackInterface | Get frame
17:50:13.822 | PaintPackInterface | Get frame
17:50:13.852 | PaintPackInterface | Get frame
17:50:13.882 | PaintPackInterface | Get frame
17:50:13.909 | PaintPackInterface | Get frame
17:50:13.936 | PaintPackInterface | Get frame
17:50:13.963 | PaintPackInterface | Get frame
17:50:13.990 | PaintPackInterface | Get frame
17:50:14.017 | PaintPackInterface | Get frame
17:50:14.044 | PaintPackInterface | Get frame
17:50:14.071 | PaintPackInterface | Get frame
17:50:14.098 | PaintPackInterface | Get frame
17:50:14.125 | PaintPackInterface | Get frame
17:50:14.152 | PaintPackInterface | Get frame
17:50:14.179 | PaintPackInterface | Get frame
17:50:21.081 |x64 notepad.exe | + Attached (winver: 6.3 build 9600) 00007FFB90F30000
I don't see major errors on the logs.30-11-2014 17:49:55.192 [Message] APPLICATION::
30-11-2014 17:49:55.192 [Message] APPLICATION::Application version: AmbiBox 2.1.6
30-11-2014 17:49:55.192 [Message] OS VERSION::Microsoft Windows 7 Professional (64-bit, version 6.1, Build 7600)
30-11-2014 17:49:55.192 [Message] APPLICATION::Inizialize components
30-11-2014 17:49:55.229 [Message] APPLICATION::Application inizialised
30-11-2014 17:49:55.265 [Message] TAmbiBox::InitProgramm::Settings loaded
30-11-2014 17:49:55.301 [Message] TAmbiBox::InitProgramm::DLL loaded
30-11-2014 17:49:55.301 [Message] TAmbiBox::InitProgramm::Language loaded
30-11-2014 17:49:55.302 [Message] TAmbiBox::InitProgramm::Start create program interface
30-11-2014 17:49:55.502 [Message] TAmbiBox::InitProgramm::Created program interface
30-11-2014 17:49:55.518 [Message] DISPLAYS RESOLUTION::Display_0 - 1920 x 1080
30-11-2014 17:49:55.528 [Message] TAmbiBox::SelectVirtualDevice::VIRTUAL_DEVICE::ADALIGHT MODE = CLOSE
30-11-2014 17:49:55.529 [Message] TAmbiBox::SelectVirtualDevice::VIRTUAL_DEVICE::ADALIGHT MODE = OPEN
30-11-2014 17:49:55.531 [Message] TAmbiBox::SelectVirtualDevice::VIRTUAL_DEVICE::ADALIGHT OPENED
30-11-2014 17:49:55.533 [Message] TAmbiBox::SelectVirtualDevice::VIRTUAL_DEVICE::IHID MODE = OPEN
30-11-2014 17:49:55.533 [Message] TAmbiBox::SelectVirtualDevice::VIRTUAL_DEVICE::IHID NOT OPENED
30-11-2014 17:49:55.534 [Message] TAmbiBox::InitProgramm::Created events and timers
30-11-2014 17:49:55.534 [Message] TAmbiBox::InitProgramm::Hook installed
30-11-2014 17:49:55.534 [Message] TAmbiBox::SendSerialNumber::www.ir-max.ru/updates.php?message=SYS_MESSAGE_ID
30-11-2014 17:49:55.679 [Message] TAmbiBox::OnProfileChange::Select mode STATIC_LAMP
30-11-2014 17:49:55.783 [Message] Select profile::Default
30-11-2014 17:49:55.838 [Message] TAmbiBox::InitProgramm::Resources initialized
30-11-2014 17:49:55.839 [Message] APPLICATION::Initialized
30-11-2014 17:49:55.922 [Message] TAmbiBox::SendSerialNumber::www.ir-max.ru/updates.php?message=SYS_M ... ge=English
30-11-2014 17:50:02.912 [Message] TAmbiBox::OnProfileChange::Select mode CAPTURE_SCREEN
30-11-2014 17:50:03.017 [Message] TAmbiBox::OnProfileChange::CAPTURE_SCREEN set grabber PlayClaw
30-11-2014 17:50:03.199 [Message] Select profile::Jeux
30-11-2014 17:50:05.885 [Message] DISPLAYS CHANGE RESOLUTION::Display_0 - 1920 x 1080
30-11-2014 17:50:14.548 [Message] DISPLAYS CHANGE RESOLUTION::Display_0 - 1920 x 1080
30-11-2014 17:50:20.551 [Message] TAmbiBox::OnProfileChange::Select mode STATIC_LAMP
30-11-2014 17:50:20.664 [Message] Select profile::Default
Well,
I reinstalled all my adalight system (Arduino firmware etc etc), reinstalled everything could be, except my Win 8.1 of course.
Now it works. :D
edit : I restored my previous Ambibox configuration backup, the profile which has Playclaw mode capture don't work. If I made a new profile, it works well. I think it's something with my old Ambibox profiles are not correctly compatible with the last Playclaw app, or anything like that. :D
Now it works. :D
Win 8.1 has been reinstalled?
Hi demmax2004,demmax2004 wrote:Win 8.1 has been reinstalled?
Nope, still my "old" 8.1 installation. I just reinstalled everything about my adalight system :
- Re-uploaded the Arduino firmware with the latest processing engine.
- Reinstalled Ambibox and Playclaw.
- Created new profiles for games using Playclaw capture.
Everything is ok now.
When I restore an old ambibox backup, the playclaw profile don't work. Only a new profile with playclaw capture work, not the old ones. :)
So, I deleted all of my old Ambibox Backup and re-worked a new one. :p
