Winter Storm Juno: Blizzard Warning! All shipping and UPS service guarantees are suspended due to weather and blizzard conditions.
SSD1306_128X32_i2c.ino won't compile
by mgapilot on Mon Jan 21, 2013 11:45 pm
Keep getting the same error when compiling this driver. Using a 128X32 i2c OLED display with Arduino Mega 2560 using Arduino 1.0.3
I have redownloaded and tried moving folders. ( I get separate errors when folders are not correct)
Any ideas for a newbee?
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
mgapilot
Re: SSD1306_128X32_i2c.ino won't compile
by adafruit_support_bill on Tue Jan 22, 2013 7:08 am
The library supports different display sizes. You need to select which one you are using in Adafruit_SSD1306.h.
For a 128x32 display, comment out the "#define SSD1306_128_64" and un-comment the "#define SSD1306_128_32" as below.
SSD1306 Displays
The driver is used in multiple displays (128x64, 128x32, etc.).
Select the appropriate display below to create an appropriately
sized framebuffer, etc.
SSD1306_128_64 128x64 pixel display
SSD1306_128_32 128x32 pixel display
You also need to set the LCDWIDTH and LCDHEIGHT defines to an
appropriate size
//   #define SSD1306_128_64
by mgapilot on Tue Jan 22, 2013 11:59 am
That did it!
Thank you.
mgapilot
by hjojo on Wed Mar 20, 2013 5:15 pm
Sorry for my english, I'm French.
I have the same problem but once I set the correct display is the message on arduino
ssd1306_128x32_spi.cpp:70:2: error: #error ("Height incorrect, please fix Adafruit_SSD1306.h!");
thank you for your answer
hjojo
