Large led strip project
by Aryxo on Thu Jan 24, 2013 3:08 pm
first please excuse my approximate English
I want to drive above 48 meters of rgb led strips, three strips of 16 meters in paralell. Actually, I really have to control only 16 meters but i want to put three pieces side by side.
I have a lot of questions, first what should i use to drive those 1536 Leds? Unforntunately i don't think an Arduino Uno will be enough :wink: Maybe a "biggest" arduino? or a raspberry pi?
Then, what alimentation needed? Would this be a problem for the strips to be connected with so others strips? Thanks!!
Aryxo
Re: Large led strip project
by adafruit_support_bill on Fri Jan 25, 2013 9:07 am
Running three strips in parallel with the same pattern should not be a problem. A Due or a Raspberry Pi should have the cpu power & memory for 16 meters worth of pixels. You will need a lot of power though. Probably 75A or so - depending on what kinds of patterns you will be running. You will want to feed power at multiple points on the strips. Every couple meters or so should be sufficient.
by Aryxo on Sun Jan 27, 2013 2:31 pm
Thank you! I will post again when the project will be more advanced
Aryxo
