Memorial day is 05/25/2015 – Orders will ship out on May 26th. There will not be any deliveries or shipping on Monday. Any order placed after 11am ET on Friday May 22nd will not start to ship out until Tuesday May 26th.
LCD plate - trying to read data from it
by bbkiwi on Thu Jan 31, 2013 10:55 pm
I'm trying to add to the Python code to be able read data from the LCD namely: Read Busy Flag and Address Counter and
Read Data from RAM as described on pg. 24 and 58 in the data sheet HD44780.pdf
I have not been successful yet. It may be that I don't understand setting pins of the MCP23017 as input or output.
Any suggestions or references would be appreciated. Thanks.
In Adafruit_ChartLCDPlate.py I have added code similar to write4 but for reading. I've experimented with various combinations
of making pins input or output, but so far no luck. Also the hi and low 4 bits always turn out the same even though I give the enable
pulse twice. Also there is a bug related to the saving of the direction information (fix at end of this post)
Attempted routine to read
   def readBFandACv(self):
        """ Send command  01 to LCD to read busy flag and Address counter """
        self.mcp.output(self.pin_rs, 0)
        self.mcp.output(self.pin_rw, 1) #set rw to 1
#  Configure pins for input optionally
        makeinput = 1 #1 to make input, 0 to leave as output pin
        self.pulseEnable() #send E pulse to set pins to 4 high bits BF,AC6,AC5,AC4
        if makeinput:
                for pin in self.pins_db:
                        self.mcp.config(pin,  self.INPUT)
        bits = range(8)
         # get the pins values
        for i in range(4):
            bt = self.mcp.inputnocheck(self.pins_db[::-1][i])
            bits[i]=bt
#           print i,bt,bits[i]
        # restore to pins to output (tried with and without)
                self.mcp.config(pin,  self.OUTPUT)
        self.pulseEnable() #send E pulse to set pins to next 4 bits AC3,AC2,AC1,AC0
        if makeinput:
        for i in range(4,8):
            bt = self.mcp.inputnocheck(self.pins_db[::-1][i-4])
            bits[i]=bt
        # restore to pins to output and rw to 0
        self.mcp.output(self.pin_rw, 0) # return rw to 0
#        print "Last :", bin(self.mcp.direction)[2:].zfill(16)
        return bits;
In Adafruit_MCP230xx.py added a version of input with assertion removed so can input from any
combination of input/output pins
    def inputnocheck(self, pin):
        assert pin >= 0 and pin < self.num_gpios, "Pin number %s is invalid, only 0-%s are valid" % (pin, self.num_gpios)
        #assert self.direction & (1 << pin) != 0, "Pin %s not set to input" % pin
        print self.num_gpios, "pin ", pin
        if self.num_gpios <= 8:
            value = self.i2c.readU8(MCP23008_GPIOA)
        elif self.num_gpios > 8 and self.num_gpios <= 16:
            value = self.i2c.readU16(MCP23017_GPIOA)
            print value, bin(value)[2:].zfill(16)
            temp = value >> 8
            value <<= 8
            value |= temp
#bb fix return value & (1 << pin)
        return (value & (1 << pin))>>pin # to make 0 or 1
Bug in Adafruit_ChartLCDPlate.py
    def config(self, pin, mode):
            self.direction = self._readandchangepin(MCP23017_IODIRA, pin, mode)
# this code produces only 8 bits and loses the information about the input/output state of the
#other pins - the MCP23012_IODIRA and B are set correctly however
#the code that follows is my correction
#        if self.num_gpios <= 16:
#            if (pin < 8):
#                self.direction = self._readandchangepin(MCP23017_IODIRA, pin, mode)
#            else:
#                self.direction = self._readandchangepin(MCP23017_IODIRB, pin-8, mode)
            if (pin < 8):
                # replace low bits
                self.direction = (self.direction >> 8)<<8 |  self._readandchangepin(MCP23017_IODIRA, pin, mode)
            else:
                # replace hi bits
                self.direction = (self.direction & 0xff) | self._readandchangepin(MCP23017_IODIRB, pin-8, mode) << 8
#       print "config ", pin, mode, self.direction, bin(self.direction)[2:].zfill(16)
        return self.direction
bbkiwi
Re: LCD plate - trying to read data from it
by adafruit_support_bill on Fri Feb 01, 2013 7:28 am
Hi, Thanks for posting your findings so far. If you can post the bug-report to Github that would be very helpful also.
by bbkiwi on Sat Feb 02, 2013 12:40 am
I put it on github.
bbkiwi
