LCD plate - trying to read data from it
by bbkiwi on Thu Jan 31, 2013 10:55 pm
I'm trying to add to the Python code to be able read data from the LCD namely: Read Busy Flag and Address Counter and
Read Data from RAM as described on pg. 24 and 58 in the data sheet HD44780.pdf
I have not been successful yet. It may be that I don't understand setting pins of the MCP23017 as input or output.
Any suggestions or references would be appreciated. Thanks.
In Adafruit_ChartLCDPlate.py I have added code similar to write4 but for reading. I've experimented with various combinations
of making pins input or output, but so far no luck. Also the hi and low 4 bits always turn out the same even though I give the enable
pulse twice. Also there is a bug related to the saving of the direction information (fix at end of this post)
Attempted routine to read
   def readBFandACv(self):
        """ Send command  01 to LCD to read busy flag and Address counter """
        self.mcp.output(self.pin_rs, 0)
        self.mcp.output(self.pin_rw, 1) #set rw to 1
#  Configure pins for input optionally
        makeinput = 1 #1 to make input, 0 to leave as output pin
        self.pulseEnable() #send E pulse to set pins to 4 high bits BF,AC6,AC5,AC4
        if makeinput:
                for pin in self.pins_db:
                        self.mcp.config(pin,  self.INPUT)
        bits = range(8)
         # get the pins values
        for i in range(4):
            bt = self.mcp.inputnocheck(self.pins_db[::-1][i])
            bits[i]=bt
#           print i,bt,bits[i]
        # restore to pins to output (tried with and without)
                self.mcp.config(pin,  self.OUTPUT)
        self.pulseEnable() #send E pulse to set pins to next 4 bits AC3,AC2,AC1,AC0
        if makeinput:
        for i in range(4,8):
            bt = self.mcp.inputnocheck(self.pins_db[::-1][i-4])
            bits[i]=bt
        # restore to pins to output and rw to 0
        self.mcp.output(self.pin_rw, 0) # return rw to 0
#        print "Last :", bin(self.mcp.direction)[2:].zfill(16)
        return bits;
In Adafruit_MCP230xx.py added a version of input with assertion removed so can input from any
combination of input/output pins
    def inputnocheck(self, pin):
        assert pin >= 0 and pin < self.num_gpios, "Pin number %s is invalid, only 0-%s are valid" % (pin, self.num_gpios)
        #assert self.direction & (1 << pin) != 0, "Pin %s not set to input" % pin
        print self.num_gpios, "pin ", pin
        if self.num_gpios <= 8:
            value = self.i2c.readU8(MCP23008_GPIOA)
        elif self.num_gpios > 8 and self.num_gpios <= 16:
            value = self.i2c.readU16(MCP23017_GPIOA)
            print value, bin(value)[2:].zfill(16)
            temp = value >> 8
            value <<= 8
            value |= temp
#bb fix return value & (1 << pin)
        return (value & (1 << pin))>>pin # to make 0 or 1
Bug in Adafruit_ChartLCDPlate.py
    def config(self, pin, mode):
            self.direction = self._readandchangepin(MCP23017_IODIRA, pin, mode)
# this code produces only 8 bits and loses the information about the input/output state of the
#other pins - the MCP23012_IODIRA and B are set correctly however
#the code that follows is my correction
#        if self.num_gpios <= 16:
#            if (pin < 8):
#                self.direction = self._readandchangepin(MCP23017_IODIRA, pin, mode)
#            else:
#                self.direction = self._readandchangepin(MCP23017_IODIRB, pin-8, mode)
            if (pin < 8):
                # replace low bits
                self.direction = (self.direction >> 8)<<8 |  self._readandchangepin(MCP23017_IODIRA, pin, mode)
            else:
                # replace hi bits
                self.direction = (self.direction & 0xff) | self._readandchangepin(MCP23017_IODIRB, pin-8, mode) << 8
#       print "config ", pin, mode, self.direction, bin(self.direction)[2:].zfill(16)
        return self.direction
bbkiwi
Re: LCD plate - trying to read data from it
by adafruit_support_bill on Fri Feb 01, 2013 7:28 am
Hi, Thanks for posting your findings so far. If you can post the bug-report to Github that would be very helpful also.
by bbkiwi on Sat Feb 02, 2013 12:40 am
I put it on github.
bbkiwi
