Problem with OLED 128x32 SPI
by bluszcz on Sun Feb 17, 2013 6:49 pm
Hey,
I purchased OLED 128x32 and the examples from Adarfuit_GFX work properly :)
However, I am trying to use it along with the sensor od DHT11 - and besides of the logo in setup() I am not able to display anything in the setup()
My code is here: http://pastebin.com/FKjh3AEB leds are working with other examples - so I am doing something wrong, help :shock:
Cheers,
bluszcz
bluszcz
Re: Problem with OLED 128x32 SPI
by adafruit_support_rick on Sun Feb 17, 2013 8:07 pm
I don't see where you have instantiated the DHT object, as is done in the example sketch, below:
#include "DHT.h"
#define DHTPIN 2     // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);   //Instantiate DHT object
