Code for OLED Character display with RW pin grounded
by nachoHacker on Sat Feb 23, 2013 9:07 pm
I've got this display.
I want to free up a pin on my arduino. I want to tie the RW pin of the OLED display to ground.
How can I use the Adafruit OLED library when the RW pin is grounded?
This line, for example, forces me to declare a RW pin, but I don't want the arduino to deal with a RW pin:
Adafruit_CharacterOLED lcd(4, 5, 6, 7, 8, 9, 10);
nachoHacker
Re: Code for OLED Character display with RW pin grounded
by adafruit_support_bill on Sun Feb 24, 2013 9:55 am
You can't. At least not with our library. The command timing data in the manufacturer's spec sheet is 100% fictitious and after many-many hours of trying to determine the appropriate delays required for various command sequences, we were unable to come up with a reasonable set of timings that worked reliably in all cases. No-one to my knowledge has been able to run these reliably without the RW pin.
Here is another take on the subject: viewtopic.php?f=8&t=29207&p=183258
