Wiring RGB LED
Wiring RGB LED
by maggiemouse on Mon Mar 18, 2013 10:17 am
I'm working on a prop gun that I am putting LEDS in. Due to size constraints and because the LEDs do not need to be individually controllable instead of using 12mm RGB strands I opted to solder leads onto 5mm RGB LEDS (http://www.adafruit.com/products/302). Ideally they are going to be hooked up and controlled by an Arduino but since there are quite a few LEDs (38) I was wondering how to wire them without frying anything.
Is it ok to wire them in parallel? (red to red blue to blue) I know I will need resistors but will I need a transistor to run them with an Arduino?
maggiemouse
Re: Wiring RGB LED
by adafruit_support_bill on Mon Mar 18, 2013 10:34 am
You can wire them in parallel, but you will want separate current limiting resistors for each cathode (R, G and B leads) on each led. With 38 leds wired together, you will need to sink 760 mA on each of the R G and B channels. That is too much for an Arduino pin. You would need transistors like the PN2222: https://www.adafruit.com/products/756
