do not print in the screen
by tlerdrden on Tue Mar 19, 2013 11:50 pm
Recently I bought the 2.8" TFT Touch Shield for Arduino - http://www.adafruit.com/products/376-. I like it and it works fine.
Now I am trying to create a menu and print the buttons in the screen, but unfortunately, the TFT doesn't print what I push.
In the example I atach the code, I am trying to print a "7". I've checked with the Serial.print that I get correctly the number...but for some reason the TFT can't print on the screen.
I attach the code:
void loop()
Point p = ts.getPoint();
if (p.z > MINPRESSURE && p.z < MAXPRESSURE) { // Si apreto un boto
p.x = map(p.x, TS_MINX, TS_MAXX, tft.width(), 0); // Recalculo les posicions X i Y
p.y = map(p.y, TS_MINY, TS_MAXY, tft.height(), 0);
if (p.y >H1 && p.y<H5 ) {
if (p.x>X1 && p.x<X6){
if (p.x>X1 && p.x<X2){
if (p.y>H1 && p.y<H2){
tft.print(7);
Do you have any idea to solve it?
Thanks in advance,
A.
tlerdrden
Re: do not print in the screen
by adafruit_support_bill on Wed Mar 20, 2013 5:36 am
If you want to print the digit "7", use:
tft.print("7");
The quotes tell it that you want the literal character "7", not the ASCII character code 7 or BEL (In the old days, that was the character to send to the teletype machine to ring the bell :) )
by tlerdrden on Wed Mar 20, 2013 7:29 am
Yes, I was checked that before, sorry.
I have tried using:
tft.print(7);
tft-.print("7");
tft.println("7");
But anything happens, I don't know why. If I try to print it in other place of the code, it works with no problems, but the problem is that I want only that the number 7 appears when I push the key I've drawn in the screen.
I guess that I have to put the "tft.print" command in other place of the code, but where? Any idea to sync printings and touches to screen?
A.
tlerdrden
by adafruit_support_bill on Wed Mar 20, 2013 8:18 am
I don't see where you are positioning the text cursor. Try setting the cursor position before you print.
by tlerdrden on Wed Mar 20, 2013 8:23 am
I am sorry
I attach the code:
void loop()
            Serial.println(p.x); // Only to check I push the button
            Serial.println(p.y);  //Only to check I push the button
            Serial.println(7);     //Only to check that I am getting the button
             tft.setCursor(30, 70); <-- SetCursor
             tft.setTextColor(WHITE);
             tft.setTextSize(2);
             tft.println("7"); <-- Nothing happens!
          } //END (p.y>Y1 && p.y<Y2
          }//END (p.x>X1 && p.x<X2)
      } // END (p.x>X1 && p.x<X6)
   } // END (p.y >H1 && p.y<H5
   } // END (p.z > MINPRESSURE && p.z < MAXPRESSURE)
tlerdrden
by adafruit_support_rick on Wed Mar 20, 2013 11:07 am
Can you please post the entire sketch, so that we can try to reproduce the problem? Please use the 'Code' tags (tab at the top of the edit window) when posting code.
by tlerdrden on Wed Mar 20, 2013 12:32 pm
Yes of course:
Here is:
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
#include <TouchScreen.h>
#define LCD_CS A3    // Chip Select goes to Analog 3
#define LCD_CD A2    // Command/Data goes to Analog 2
#define LCD_WR A1    // LCD Write goes to Analog 1
#define LCD_RD A0    // LCD Read goes to Analog 0
#define LCD_RESET A4
#define MINPRESSURE 10
#define MAXPRESSURE 1000
// Color definitions
#define   BLACK           0x0000
#define   BLUE            0x001F
#define   RED             0xF800
#define   GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
// Nuevos colores
#define   GREY      50712
#define ORANGE      64800
#define   PINK      63733
#define   BROWN      35362
//BASIC PER FER UN MAP
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
#define YP A1  // must be an analog pin, use "An" notation!
#define XM A2  // must be an analog pin, use "An" notation!
#define YM 7   // can be a digital pin
#define XP 6   // can be a digital pin
//MIDAS RECUADRO BOTONES
#define X1 20   //
#define X2 60   //
#define X3 100  //
#define X4 140  //
#define X5 180  //
#define X6 220  //
#define DESCARX 15 // El desplazamiento en X respecto a las lineas horizontales de cada caracter
#define H1 150  //
#define H2 190  //
#define H3 230  //
#define H4 270  //
#define H5 310  //
#define DESCARY 10 // El desplazamiento en X respecto a las lineas horizontales de cada caracter
//Intentaré crear una calculadora amb les caixes de les pintures
#define TAMBOTON 40
// Creamos objetos "tft" y ts
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, 0);
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
void setup(void) {
  //Inicialización
  Serial.begin(9600);
  Serial.println("Paint!");
  tft.reset();
  uint16_t identifier = tft.readRegister(0x0);
  if (identifier == 0x9325) {
    Serial.println("Found ILI9325");
  } else if (identifier == 0x9328) {
    Serial.println("Found ILI9328");
  } else if (identifier == 0x7575) {
    Serial.println("Found HX8347G");
  } else {
    Serial.print("Unknown driver chip ");
    Serial.println(identifier, HEX);
    while (1);
//Inicialización
  tft.begin(identifier);
  tft.fillScreen(BLACK);
  //Fico el titol
  tft.setTextColor(RED);
  tft.setTextSize(2);
  tft.setCursor(30, 10);
  tft.println("Opiron");
 //Dibujo rectangulo de Operaciones
  tft.drawRect(X1, 30, 200, 110, WHITE);
 // Creo el cuadro donde habrá botones
  tft.fillRect(X1, H1, X6-X1, H5-H1, GREY);
  //Divido en lineas verticales el recuadro
  tft.drawFastVLine(X2, H1, H4-H1, BLACK);
  tft.drawFastVLine(X3, H1, H5-H1, BLACK);
  tft.drawFastVLine(X4 , H1, H5-H1, BLACK);
  tft.drawFastVLine(X5, H1, H5-H1, BLACK);
  //Divido en lineas horizontales el recuadro
  tft.drawFastHLine(X1, H2, X6-X1, BLACK);
  tft.drawFastHLine(X1, H3, X6-X1, BLACK);
  tft.drawFastHLine(X1, H4, X5-X1, BLACK);
  //Ponemos numeros
  tft.setTextSize(2);
  tft.setCursor(X1+DESCARX, H1+DESCARY);
  tft.println("7");
  tft.setCursor(X2+DESCARX, H1+DESCARY);
  tft.println("8");
  tft.setCursor(X3+DESCARX, H1+DESCARY);
  tft.println("9");
  tft.setCursor(X4+DESCARX, H1+DESCARY);
  tft.println("/");
  tft.setCursor(X5+DESCARX, H1+DESCARY);
  tft.println("M");
  tft.setCursor(X1+DESCARX, H2+DESCARY);
  tft.println("4");
  tft.setCursor(X2+DESCARX, H2+DESCARY);
  tft.println("5");
  tft.setCursor(X3+DESCARX, H2+DESCARY);
  tft.println("6");
  tft.setCursor(X4+DESCARX, H2+DESCARY);
  tft.println("*");
  tft.setCursor(X5+DESCARX, H2+DESCARY);
  tft.println("C");
  tft.setCursor(X1+DESCARX, H3+DESCARY);
  tft.println("1");
  tft.setCursor(X2+DESCARX, H3+DESCARY);
  tft.println("2");
  tft.setCursor(X3+DESCARX, H3+DESCARY);
  tft.println("3");
  tft.setCursor(X4+DESCARX, H3+DESCARY);
  tft.println("-");
  tft.setCursor(X2-5,H4+DESCARY);
  tft.println("0");
  tft.setCursor(X3+DESCARX, H4+DESCARY);
  tft.println(".");
  tft.setCursor(X4+DESCARX, H4+DESCARY);
  tft.println("+");
  tft.setCursor(X5+DESCARX, H4-5);
  tft.println("=");
  pinMode(13, OUTPUT);
void loop()
            Serial.println(7);
             tft.setTextSize(2);
             tft.println("7");
          } //FI (p.y>Y1 && p.y<Y2
          }//FI (p.x>X1 && p.x<X2)
      } // FI (p.x>X1 && p.x<X6)
   } // FI (p.y >H1 && p.y<H5
   } // FI evaluar boto (p.z > MINPRESSURE && p.z < MAXPRESSURE)
tlerdrden
by adafruit_support_rick on Wed Mar 20, 2013 2:37 pm
You must have an old version of the library. Where did you get it?
Your code gives me the following compilation error :
sketch_mar20a.ino: In function 'void setup()':
sketch_mar20a:72: error: 'class Adafruit_TFTLCD' has no member named 'readRegister'
There is no 'readRegister' function in our library.
Anyway, the problem is that ts.getPoint changes pins YM and XP to input. You need to change them back to output after you call it, as is done in the example sketches:
void loop()
  // if sharing pins, you'll need to fix the directions of the touchscreen pins
  //pinMode(XP, OUTPUT);
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
  //pinMode(YM, OUTPUT);
by tlerdrden on Thu Mar 21, 2013 7:52 am
Brilliant!
I got the library from github. I guess it was an old library from Adafruit. Anyway, now it works with no problem, thank you very muchh!
tlerdrden
by adafruit_support_rick on Thu Mar 21, 2013 11:24 am
Good luck! Looks like a fun project :D
by tlerdrden on Sat Mar 23, 2013 7:53 pm
Thanks again!
Let me share with you a video about the project
http://www.opiron.com/calcuino-video/163
See you!
tlerdrden
by adafruit_support_rick on Mon Mar 25, 2013 1:30 pm
