120" Projector Screen 150LED Adalight
by r4d0n on Thu Mar 21, 2013 8:42 am
Hi Everyone!
I just wanted to add my Solution of Mounting the LEDs on a Projector Screen. Maybe it is useful for somone who is planning to build one. The Screen Size is 120" with 150LEDs.
2013-03-21 13.26.12.jpg (867.19 KiB) Viewed 682 times
2013-03-21 10.21.16.jpg (900.37 KiB) Viewed 682 times
2013-03-21 10.21.16.jpg (811.33 KiB) Viewed 682 times
r4d0n
r4d0n
Re: 120" Projector Screen 150LED Adalight
by swissarmy on Thu Mar 21, 2013 5:00 pm
Nice m8! :)
What type of screen do you use?
Mine is built with aluminium profiles which are 7 cm wide. Your frame is very thin and looks really cool. Is it DIY screen?
Here is my setup:
http://www.youtube.com/watch?v=aZ8mShdI88Y
swissarmy
by r4d0n on Fri Mar 22, 2013 6:40 am
Funny! I got the Idea to build the backlight for my Projector screen after watching your first video! Thanks for the inspiration! Yes, it is a DIY Screen. Adapted the black edges to look better with the lights. It was pretty easy because its a wooden frame.
r4d0n
by adafruit_support_mike on Fri Mar 22, 2013 11:34 am
Nice work!
I like the trick of using cable ties to hold the LED pixels.. that's a nice compromise between 'holds it securely' and 'can be undone if necessary'. What's the clip/bracket you're using under the pixel?
by Kev1000000 on Mon Apr 22, 2013 1:50 pm
That is awesome! I am actually looking to achieve a similar result, but I have no idea what I am doing. Can anyone provide a parts list for this large 150 LED setup?
My setup I am adding Adalight to: http://imgur.com/a/ujNyN
Thanks for any help with this!
Kev1000000
by SativaNL on Sun Jun 16, 2013 6:02 am
I want to make a comparing screen like this one. Can you also give me a part list?
Which Arduino did you use? How many adapters?
SativaNL
